Go to Post Patents are an issue of law which, alas, has little to do with engineering or common sense. - Mike Betts [more]
Unread 16-01-2010, 12:29
Lucario231's Avatar
Lucario231 Lucario231 is offline
FRC #0033 (Killer Bees)
Lucario231 is an unknown quantity at this point
Labview 8.6: Xbox 360 wired controller Questions
Hi
I was wondering if LabVIEW 8.6 can use a usb xbox 360 controller for the driver station or would a gamepad be ideal to use.
any help would be fine.
thanks
Unread 16-01-2010, 21:33
Re: Labview 8.6: Xbox 360 wired controller Questions
Some teams have already demonstrated using an Xbox controller, with the appropriate driver loaded.
"Ideal" depends on personal preference and on what you need it to do.
Unread 20-01-2010, 16:42
Brian Holford Brian Holford is offline
GrimsleyEE
FRC #3215 (Prion)
Brian Holford is an unknown quantity at this point
The 360 controller works really well with Labview (in XP and Vista)...
You can bring it in using the built in joystick handling in Labview. From there you can pick what buttons and thumb sticks you want to use and scale the analog portions to suit the inputs of the drive VI's using basic math and logic.
Make sure you handle the dead zones (non-zero when released) on the analog thumb sticks or you you will find your robot wandering inadvertently...
Unread 20-01-2010, 18:03
Lucario231's Avatar
ok thanks for the info
Xbox 360 controller LabView CJBrick General Forum 12 17-12-2008 13:58
xbox 360 controller installation kuelin Technical Discussion 17 07-01-2008 19:43
Chicklet with MS XBOX 360 controller 354.FIRST Control System 2 19-04-2007 16:29
chicklet USB/xbox 360 controller spsteam1512 Control System 1 10-01-2007 23:14
