842 Final Kicker Desgin
http://www.youtube.com/watch?v=eiLiwS8p-QY
Let us know what you think, detail in the description We can do consecutive shot with 5 seconds between shots without having to wait for air to reload, we will also have these mounted on all four sides. |
Re: 842 Final Kicker Desgin
Pretty impressive
They will all shoot about the same maximum distance. We will use programming to vary the distance the kicks need to cover.
I liked the fence latch idea enough to steal it.
Hope you don't mind, FIRSTers are constantly told to steal from the best. |
The angles and distances of the components mounted in relation to each other are critical though from what we've tested. |
#7
Yup we had that all worked out. It was until I saw your other video that we were overcomplicating the release mechanism.
#8
I hate to be a kill-joy, but I feel the fence latch release system is extremely unsafe. Those latches are not designed to be used under any significant loading and may jostle free at unexpected times.
#9
we've used these before with larger volume cylinders and didn't have any problems and I don't believe there's any chance of them coming open especially since there's a pneumatic cylinder holding them closed.
#10
I will agree that was pretty impressive, now lets just see it on a robot and mobing
Also I hope that the camera operator is okay after that last hit |
#11
They can easily be spring loaded and held with small actuators.
#12
In my mind an important safety practice is using parts as they were designed. I also believe safety should be a priority for FIRST teams.
As such I don't think it is unreasonable to encourage teams to purchase load rated release mechanisms such as McMaster-Carr #3899T54. My other major concern is that fence latches aren't subject to quality control w.r.t. their load bearing ability (because that is not the intended purpose). Although the latches have worked in the past, they may fail later on. |
#13
John,
Are you doing anything special to get the air out of the front of the cylinder faster when you kick the ball. A pressure relief valve? |
#14
We haven't added anything to increase the speed the air leaves the non-pressurized side of the cylinder.
#15
Thanks so much on behalf of team 1671! |
| #1860 kicker prototype | sloteera | General Forum | 12 | 04-02-2010 14:27 |
| 987 Kicker Destruction | JM987 | General Forum | 29 | 23-01-2010 16:46 |
| FRC114 Kicker Teaser | James114 | Robot Showcase | 10 | 22-01-2010 16:56 |
| Hybrid Kicker | falconmaster | General Forum | 15 | 20-01-2010 14:27 |
| pic: The final...final match | CD47-Bot | Extra Discussion | 4 | 17-04-2003 16:24 |
