Go to Post They are "Human Dream and Inspiration Enablement Devices" but since that takes too long to say and explain I use the word "robot". - Foster [more]
Unread 20-01-2010, 18:44
Patrick Chiang Patrick Chiang is offline
Programming
FRC #3070 (Team Pronto)
Patrick Chiang is a name known to allPatrick Chiang is a name known to allPatrick Chiang is a name known to allPatrick Chiang is a name known to allPatrick Chiang is a name known to allPatrick Chiang is a name known to all
Exclamation cRIO random connection failure
Our team uses a cRIO from last year, which should be the same as they have this year. Our software and firmwares are all updated to the latest version. Today, we flashed the cRIO because our laptops were not connecting to it last night, and it connected once and deployed code just fine. But we turned the robot off and when we deployed code the second time, it no longer connects. Same thing happened last night: works some of the time after we power cycle everything but mostly refuses to connect. How would we fix this?
Our configurations:
Laptop IP: 10.30.70.6
Wireless Router IP: 10.30.70.4 (gateway)
Robot Wifi IP: 10.30.70.1
cRIO IP: 10.30.70.2
Setup:
Laptop-(eth)->Router-(wifi)->Robot Wifi-->cRIO
Testing results:
ping 10.30.70.6: pinging localhost works
ping 10.30.70.4: connects to router fine
ping 10.30.70.1 or 2: request timed out
Driver Station Output: "No Robot Communication"
Unread 20-01-2010, 19:24
synth3tk's Avatar
synth3tk synth3tk is offline
Volunteer / The Blue Alliance
AKA: David Thomas
synth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond repute
Re: cRIO random connection failure
Have you tried a hardwire setup, just to see if it's a networking issue? Plug an Ethernet cable from the router to port #1 on the cRIO, just to see what happens.
EDIT: You're not alone, apparently: http://www.chiefdelphi.com/forums/sh...ad.php?t=80393
The difference between theory and application is that in theory, theory and application are the same; In application, they are not.
Unread 21-01-2010, 08:33
Ziaholic's Avatar
Ziaholic Ziaholic is offline
Elec/SW Mentor
AKA: Marc
FRC #1164 (Project NEO)
Ziaholic is a jewel in the roughZiaholic is a jewel in the roughZiaholic is a jewel in the roughZiaholic is a jewel in the rough
Thanks for that cross-link to the other thread. It's a little confusing to have discussions in the "parent" forum, and the "child" forum at the same time.
I have 2 theories in that other thread. One involves problems when going back and forth between tethered and wireless ... and the other is related to wireless only.
I'm leaning towards a theory involving a boot-up race condition. See the other thread for the details, but, in a nutshell, our theory is that the cRIO boots up faster than the wireless bridge causing the cRIO network port to time-out.
Resetting the cRIO after the bridge is up appears to fix the problem for us.
(your mileage may vary)
edit: I just posted a question on the NI forums. Perhaps their engineers could shed some light on this theory.
There are 10 types of people. Those who understand binary, and those that do not.
Team #1164 - Project NEO Robotics
Unread 22-01-2010, 20:59
Programming
Thanks for your help. Unplugging and plugging the cRIO back in works for us too.
Unread 22-01-2010, 21:40
The boot order does seem to provoke an issue, and we are investigating it. It appears to be an issue with how the game adapter/bridge computes its routing table. In the meantime, the warm reboot of the cRIO will correct the issue.
Greg McKaskle
Unread 23-01-2010, 05:38
jhersh jhersh is offline
National Instruments
AKA: Joe Hershberger
FRC #2468 (Appreciate)
Please see the explanation of the issue and resolution here: http://www.chiefdelphi.com/forums/sh...071#post905071
Windriver connection to cRio avolkov Programming 6 05-05-2009 08:40
cRio keeps on staying red on the lab view connection test bio hazard Programming 1 14-02-2009 19:45
Connection with cRIO nadavsen2 Programming 4 29-01-2009 03:13
cRIO configuration issue- serial connection to laptop Torbots 1197 FRC Control System 5 28-01-2009 22:28
cRio losing connection when "run as startup" mgurgol Programming 2 12-01-2009 12:18
