Go to Post canadians are amazing.. - Ashley Christine [more]
Unread 20-01-2010, 19:24
smannlymann smannlymann is offline
FRC #2474
smannlymann is an unknown quantity at this point
Flexible Frame & Chassi
Has anyone experimented with a jointed frame w/ the segment in the center? Have the results been favorable? - Steven 2474
Unread 20-01-2010, 19:54
Re: Flexible Frame & Chassi
Do you mean an articulated frame perimeter? If so, it's illegal under <R11>. (insert your favorite reminder to read the manual here)
If, on the other hand, you simply mean to have the wheels articulate, then there are a number of threads out there with various ideas for how to do that. Search can be found in the orange bar at the top of this page. Results have been somewhat variable.
Unread 21-01-2010, 12:53
Best Available Data
FRC #1778 (Chill Out!)
While not applicable this year, BERT 133 built one in 2008 to play Overdrive. It worked really well throughout practice actually, but to meet weight they needed to replace the steel gears that did the actuating with aluminum, and the aluminum had a nasty habit of shearing mid match. I'll see if I can track down some pictures from BAE that year.
Unread 21-01-2010, 14:14
Matt C's Avatar
Matt C Matt C is offline
FRC #1468 (J-Birds)
Matt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond repute
Send a message via AIM to Matt C
190 had a flex chassis with a horizontal pivot in 2005 to allow all 4 mechanum wheels to maintain contact with the floor at all times.
Last edited by Matt C : 21-01-2010 at 16:10. Reason: Missed year in original post.
Unread 21-01-2010, 16:09
Best Available Data
There are likely pictures of it somewhere in this archive, but it's a lot of pictures to look through, so it's left as an exercise to the reader.
Here's their first match at BAE in 2008. The camera moves quite a bit, but there's a little bit of video of them turning (particularly at about 1:10).
Flexible Material Robertoell Technical Discussion 10 07-02-2009 12:58
flexible materials Adama Inventor 4 26-12-2006 16:28
Flexible, Bendable Rod blue_crew Technical Discussion 7 30-03-2006 19:18
Super flexible Wire want2modmygt Electrical 10 18-01-2006 18:39
pic: The Bobcats 2001 &amp; 2003 &amp; Admirers CD47-Bot Robot Showcase 19 28-02-2004 12:36
