Re: Running Code in Debug Mode | Power Hawks 1111
Ok, i have downloaded the .pdf and on the very first set up (The Debug Settings window) it says "Connection to use: " and our drop down menu is empty, although the direstions seem to assume that there is already an entry there.
Thanks guys for helping the noobs out |
| cRIO Not Running Code?!? | JohnFogarty | Programming | 11 | 17-01-2010 19:08 |
| Running camera code wirelessly | windell747 | NI LabVIEW | 4 | 09-02-2009 21:27 |
| code example to set 4x encoder decoding mode mode | fdelagarza | C/C++ | 1 | 02-02-2009 17:14 |
| Problem running compiled code | jskene | Programming | 10 | 23-01-2005 21:13 |
| auton mode running motors incorrectly | BK36 | Programming | 2 | 12-03-2003 02:43 |
