Go to Post I mean, there is a 40 second period where your alliance has to play defense, so you might as well play it well. - Jeff Rodriguez [more]
Unread 19-01-2010, 17:16
FRC1612's Avatar
FRC1612 FRC1612 is offline
FRC #1612 (Robo-Sharks)
FRC1612 is an unknown quantity at this point
CRIO is CrAzY
Our crio is going crazy... for some reason our "Safe Mode" dip switch is inverted. When we set it to "off" the crio imaging tool says that safe mode is "on". Also we will get absolutely no communication with the robot unless we physically press the reset button on our crio.
My question is will a robot inspector see this at competition and want us to turn safe mode off (or in our case ON)?
~Robo-Sharks
Unread 19-01-2010, 18:46
Re: CRIO is CrAzY
I assume you've called NI and reported the problem?
Unread 19-01-2010, 19:44
whytheheckme's Avatar
whytheheckme whytheheckme is offline
AKA: Jacob Komar
whytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond repute
Send a message via ICQ to whytheheckme Send a message via AIM to whytheheckme Send a message via MSN to whytheheckme Send a message via Yahoo to whytheheckme
Re: CRIO is CrAzY
Ours appears to be identical. I don't know if it's a problem, or if the picture in the manual is incorrect?
Unread 19-01-2010, 21:56
Re: CRIO is CrAzY
Is it possible that the dip works, but that the pressed state isn't clear? Press on the side that you want to transition to.
Greg McKaskle
Unread 20-01-2010, 20:14
FRC1612's Avatar
Re: CRIO is CrAzY
Currently we have not contacted NI. As we figured well it still works its not broken just a little confused if it wants to be safe.
As for the dip switch we are fine as long as there is no rule stating the crio safe mode having to be in the "OFF" position.
But for having to physically press the reset button on the controller now thats a problem for NI. Will contact NI and post a reply for all those with similar issues.
Just glad we aren't the only ones with this issue.
~Robo-Sharks
Unread 20-01-2010, 20:36
AKA: Jacob Komar
Re: CRIO is CrAzY
Yes, the DIP switch is simply unclear. It works in the counter-intuitive state.
Unread 20-01-2010, 20:38
Re: CRIO is CrAzY
But for having to physically press the reset button on the controller...
Are you saying that you have to press and hold the button? Or that the cRIO doesn't reset via DS or other means?
As for the dip switch, I was able to look at one today, and with normal usage, all dip switches should be pressed down/in on the left side. If using a serial cable, the console out needs to be turned on.
Greg McKaskle
Unread 20-01-2010, 22:46
FRC1612's Avatar
Re: CRIO is CrAzY
Greg McKaskle
According to the way you described it, our dip switch is correct then. I am guessing that in the picture(s) in the FIRST documentation the safe mode switch is incorrectly set.
Yeah for having to reset I mean:
That when we first boot up our crio the classmate and robot cannot communicate with each other. The only way to solve the communication error is to press and hold the reset button on the crio. It's strange... Doesn't seem normal.
~Robo-Sharks
Reimaging the cRio Issues there are no cRio devices on the subnet Stuart FRC Control System 2 25-02-2009 23:41
I am going crazy sweetie_pi Programming 9 07-02-2008 18:30
Crazy Loops whytheheckme Programming 16 05-02-2007 00:51
Is this crazy or am I? russell General Forum 16 03-03-2005 22:50
crazy game Mike Ciance Fantasy FIRST 22 25-05-2004 11:37
