Go to Post You can't stop trying to look for other ways to do things, or that really defeats the whole purpose of inovation. - AmoryG [more]
Unread 19-01-2010, 18:18
Tanner's Avatar
Tanner Tanner is offline
FRC #1261 (Roblions)
Tanner is a splendid one to beholdTanner is a splendid one to beholdTanner is a splendid one to beholdTanner is a splendid one to beholdTanner is a splendid one to beholdTanner is a splendid one to behold
8020 Mass
Hi,
Does anyone know how I would put the mass of 8020 into a part?
I found the iProperties' Physical settings, but I don't know the density of it to put in. I'm not even sure if that is the right place to go.
Ideas?
-Tanner
Unread 19-01-2010, 18:23
vivek16's Avatar
vivek16 vivek16 is offline
Whoa! college pilot.
AKA: vivek
FRC #2264 (trojan robotics)
vivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond repute
Send a message via AIM to vivek16 Send a message via MSN to vivek16
Re: 8020 Mass
8020 is made out of aluminum. Use the density setting for aluminum and Inventor will do the rest.
"we don't build robots, we build people"
Unread 19-01-2010, 18:27
Tanner's Avatar
Re: 8020 Mass
Correct me if I'm wrong, but not if I'm doing something quickly using just a solid material, not a actual drawing of 8020.
-tanner
Unread 19-01-2010, 18:29
vivek16's Avatar
AKA: vivek
Re: 8020 Mass
Ah, in that case I am not quite sure how to help you. I think it would be easier to get a drawing of 8020 and find it's density.
Unread 19-01-2010, 18:37
Tanner's Avatar
Re: 8020 Mass
Heh. I can't even type in that field. Grr.
Guess I have to remodel this piece as a assembly of 8020? That doesn't sound like fun.
-Tanner
Unread 19-01-2010, 18:51
sgreco's Avatar
sgreco sgreco is offline
AKA: Steven Greco
FRC #2079
sgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond repute
Re: 8020 Mass
You can use this link to get some 8020 models. This may help you.
http://team1323.com/cad/pages/extrusion.html
Unread 19-01-2010, 18:57
Tanner's Avatar
Re: 8020 Mass
Someone correct me, as I don't know if this is how to do a CAD model of a chassis in 8020. Should it be broken up so that pretty much each piece is a stick, i.e. a separate part, or something else?
-Tanner
Unread 19-01-2010, 19:04
sgreco's Avatar
AKA: Steven Greco
FRC #2079
Re: 8020 Mass
Yeah, each piece would be used as a rod. They make nuts that slip into the frames. You'll also notice that a 1/4 20 button head bolt will slip right into the extrusion. If you use 1x1 inch, you can tap the end with an 1/4 20 thread, then connect it by slipping a bolt head into one piece and tightening it to the tapped end of the other. You can tighten it by drilling a hole right behind the head of the bolt, so you can get an allen key to it. It's hrad to describe so this may not make sense. If you use Loctite it will suffice for a frame. My did it in 2008 and it worked just fine.
keehun's Avatar
keehun keehun is offline
Team Captain
AKA: Keehun Nam
FRC #2502 (EP Robotics)
keehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond repute
Send a message via AIM to keehun
Re: 8020 Mass
Here is a good site to get custom length 80/20 CAD/Inventor/SolidWorks files.
http://www.3dcontentcentral.com/part...-Inc/9/13.aspx
Choose 10 or 15 series. The "most common" is the 10 series. 1" sides.
For by grace you have been saved through faith, and that not of yourselves; it is the gift of God, not of works, lest anyone should boast. -- Ephesians 2:8-9
2010: Quarter Finalist (MN 10,000 Lakes)
2010: Website Award (MN 10,000 Lakes)
2009: Quarter Finalist (MN 10,000 Lakes)
2009: GM Industrial Award (MN 10,000 Lakes)
Unread 19-01-2010, 19:06
Tanner's Avatar
Re: 8020 Mass
Originally Posted by sgreco View Post
Yeah, each piece would be used as a rod. They make nuts that slip into the frames. You'll also notice that a 1/4 20 button head bolt will slip right into the extrusion. If you use 1x1, you can tap the end with an 1/4 20 thread, then connect it to the other piece by slipping a bolt head into the other piece and tightening it. You can tighten it by drilling a hole right behind the head of the bolt, so you can get an allen key to it. It's hrad to describe so this may not make sense. If you use Loctite it will suffice for a frame. My did it in 2008 and it worked just fine.
I think I understood. Our team has used 8020 for years, just I'm one of the few surviving people who know how to use CAD.
This is going to be fun. Whee...
I wish I could drag Inventor windows to my second monitor, would be soo much easier than flipping back and forth to see my measurements.
-Tanner
Unread 20-01-2010, 19:49
joek's Avatar
joek joek is offline
Team Welder and CAD tech
FRC #2052 (KnightKrawler)
joek is an unknown quantity at this point
Re: 8020 Mass
go to where you would edit the color- then go all the way down to material styles, then open that, then double click on aluminum 6061, it should turn bold, then the entire solid is recognized as aluminum 6061, including the mass
2012 Record (13-2-0)
lake superior regional finalists- thank you WAVE (2826) and Blue Twilight (2220)
Unread 20-01-2010, 20:34
Tanner's Avatar
Re: 8020 Mass
Thanks, but as far as I know if I model a rectangle 1"x1"x12" it'll model the mass as a solid piece of Aluminum with the same volume.
-Tanner
Unread 20-01-2010, 20:38
joek's Avatar
Re: 8020 Mass
yes, you must put the thickness of the tubing into the sketch, but if you use extruded 80/20, it will do the shape
Unread 20-01-2010, 20:39
joek's Avatar
Re: 8020 Mass
you can shell stuff too. to make it a hollow piece
Unread 21-01-2010, 16:43
mplanchard mplanchard is offline
Marie Planchard, SolidWorks
mplanchard has a reputation beyond reputemplanchard has a reputation beyond reputemplanchard has a reputation beyond reputemplanchard has a reputation beyond reputemplanchard has a reputation beyond reputemplanchard has a reputation beyond reputemplanchard has a reputation beyond reputemplanchard has a reputation beyond reputemplanchard has a reputation beyond reputemplanchard has a reputation beyond reputemplanchard has a reputation beyond repute
Re: 8020 Mass
I would also verify the weight of your piece. Library components may have simplified fillets. 80-20 is a complex extrusion, some components dont model all the detail and then your weight will be off a bit.
Marie
pic: What goes on those 8020 Rails?? Thermal Extra Discussion 7 10-01-2009 08:12
pic: 8020 Chain Tensioning idea Andy L Extra Discussion 12 03-11-2008 16:08
Center of Mass question Alex1072 Technical Discussion 11 26-01-2005 17:03
Mass properties in Inventor telkanuru Inventor 2 26-02-2004 21:59
Need help in Mass.? CaptainPlaid General Forum 1 16-12-2002 12:15
