Go to Post "The secret to success is to acknowledge that you have limits, but to never acknowledge that you have reached those limits." - lady_raidan [more]
Unread 20-01-2010, 20:44
Creator Mat Creator Mat is offline
FRC #2338 (Gear it Forward)
Creator Mat is a jewel in the roughCreator Mat is a jewel in the roughCreator Mat is a jewel in the roughCreator Mat is a jewel in the rough
How to attach Bevel Gears to shaft when they are not keyed or have set screws
Ok my team had ordered some bevel gears from mcmaster (6529K11 Steel Plain Bore 20 Deg Angle Miter Gear 16 Pitch, 16 Teeth, 1" Pitch Diameter, 3/8" Bore) and they came without a keyway or a set screw (or a place to put a set screw). This is a problem because as far as my team can figure there is no way to drive a shaft with these bevel gears. Is there a way to drive a shaft without a keyway or a set screw using these bevel gears or did we get shafted and need to return these bevel gears?
2010 Midwest Spirit award
2010 Midwest Quarterfinalists
2010 Wisconsin Quarterfinalists
2009 Midwest Finalists
2009 Wisconsin Quarterfinalists
2008 Midwest Rookie AllStars
Unread 20-01-2010, 20:48
,4lex S.'s Avatar
,4lex S. ,4lex S. is offline
University Mentor
AKA: Alex Strong
FRC #2702 (REBotics)
,4lex S. has much to be proud of,4lex S. has much to be proud of,4lex S. has much to be proud of,4lex S. has much to be proud of,4lex S. has much to be proud of,4lex S. has much to be proud of,4lex S. has much to be proud of,4lex S. has much to be proud of,4lex S. has much to be proud of
Re: How to attach Bevel Gears to shaft when they are not keyed or have set screws
If you want to use them, I guess you have to key them or drill a hole for a set screw then. I think the only other option would be glue (DO NOT GLUE THEM!!! ).
University of Waterloo Mechanical Engineering Class of 2014- 2B School Term
University of Waterloo Formula SAE Race Team 2010-Eternity
FRC 2702: REBotics 2011 Mentor ::: FRC 1006: Fast Eddie Robotics 2005-2009 Alumni ::: FLL 4050: 2004 Alumni
Unread 20-01-2010, 21:00
Madison's Avatar
Madison Madison is offline
Dancing through life...
FRC #0488 (Xbot)
"Plain bore" is an important part of the description of the product. They are furnished with the expectation that you will broach a keyway in them or otherwise modify them to suit your needs.
--Madison--
...down at the Ozdust!
Unread 20-01-2010, 22:06
joeweber's Avatar
joeweber joeweber is offline
Coach team 1322
FRC #1322 (G.R.A.Y.T. Leviathons)
joeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant future
Some times you can drill and tapp a hole between the shaft and gear than run a screw in if you have no way of putting a key way in. Or you can cut it with a small metal blade. You can check with a local machine shop and they may do it for you.
If your not dirty than you must be just watching.
Thank's to http://weberelectric.biz/
FRC Team sitehttp://team1322.org/
2004 Great Lakes Xerox Creativity Award, 2008 Web Site Excellence Award, 2010 Kettering District and Western Michigan District Excellence in Engineering award, 2011 Kettering District Gracious Professionalism Award. 2011 Ann Arbor and State Cooperation Awards.2013 Kettering Xeroc Creativity Award.2015 Escanaba Chairman's Award.2015 Kettering Spirit Award.2016 Kettering Chairman's Award
FTC Lightining Boltz 5954, Thunder Botz 7032http://team1322.org/vex.htm
Unread 20-01-2010, 22:23
Stephen of REX's Avatar
Stephen of REX Stephen of REX is offline
FRC #1727 (REX)
Stephen of REX is an unknown quantity at this point
Funny thing, 1727 also ordered 3/8 inch bore bevel gears. I could have sworn that we ordered them finished, but they came as plain bore. In fact we may have ordered the same gears, did you get them form McMaster?
Anyway... we simply drilled and tapped them to fit 1/4 20 bolts. We will probably order set screws for them. We would be done, but a freshmen went and broke our last tap.
As for attaching the set screws, you may want to dremel a flat part on your shaft, or get the shaft with a flat side to it specifically for set screws. Or you could machine keyways, I guess it depends on your resources.
Go REX!!!
Unread 20-01-2010, 22:34
Jeffy's Avatar
Jeffy Jeffy is offline
Retired, for now
AKA: Jeff Gier
FRC #2410 (Metal Mustang Robotics) #159 (Alpine Robotics)
Jeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant future
Set screws have never not failed me.
Last year we made lots of shafts with pins.
Just drill a 1/8" hole through the middle and into the shaft. Then we used steel welding rod as the pins.
You *may* also have success using sheet metal screw as pins.
Unread 20-01-2010, 22:39
DonRotolo's Avatar
Back to humble
FRC #0832
Indeed. Plain Bore items come with a hole in them, but as madison noted, it is expected you you will bore the hole to some specific diameter that you need, then add a hole for a set screw or broach a keyway. These items are made of steel that is easier to machine, and not having the keyway or setscrew hole keeps you from breaking lathe tools as they pass over the 'gap'.
Finished bore items are often much harder steel, and more difficult to machine. Then you have the 'gap' (keyway or screw hole) that can break the lathe tools, combine them and it makes you wish you just had ordered them the right size to begin with. Oh, the finished bore sprockets that I have experience with are too hard to drill, too, so you're really in trouble....
Unread 20-01-2010, 23:03
The funny thing is we had bought bevel gears from Mcmaster before and even tho it never specified from what we could tell if they where plain bore or not. The bevels we got all had set screws, so we where kind of surprised when these came plain bored (thanks all for the reminder of the correct term). The good news is we didn't take them out of there package so we can just return them. However we still need to find suitable replacements, does anyone know where we can get keyed or set screwed 3/8" bore bevel gears from besides mcmaster carr?
Unread 20-01-2010, 23:17
big1boom big1boom is offline
Chains=Fun
FRC #2022 (Titan Robotics)
big1boom is a glorious beacon of lightbig1boom is a glorious beacon of lightbig1boom is a glorious beacon of lightbig1boom is a glorious beacon of lightbig1boom is a glorious beacon of lightbig1boom is a glorious beacon of light
This will be our second year running with the plain bore bevel gears.
We just use 1/8" roll pins to attach the bevel to an axle.
Roll pins can be found here
http://www.mcmaster.com/#roll-pins/=5gr639
If you really want to use a set screw, you can purchase those from McMaster as well. On the page with bevel gears. Part number 6843K11 or 7655K1 for a 3/8" axle.
Unread 21-01-2010, 09:01
ajlapp ajlapp is offline
AKA: Anthony Lapp
None #0118 (Team RUSH and Robonauts)
ajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond repute
Finished Bore Miter Gear
Two lines below the plain bore on the McMaster website.
They are twice the price. For the price difference of four of these gears you could but a Dumont #00 broach kit and never have this problem again.
Good luck.
Anthony Lapp
FIRST Engineering Mentor
Owner/Operator 221 Robotic Systems
221 Robotics Systems - Quality Hardware, Made in the USA
RobotOpen
anthony@221robotics.com
Twitter us: @221RobotSystems
Team 1 --> 94 --> 68 --> 221 --> 857 --> 27 --> 118
Design Engineer/Fabricator and 17 year vet
Team Rush (FRC27) and Robonauts (FRC118)
Unread 21-01-2010, 10:20
Racer26 Racer26 is offline
Alternatively, If you're feeling brave, you could weld the gear to the shaft, assuming the metals are appropriate for such.
Unread 01-02-2010, 01:27
NickE's Avatar
NickE NickE is offline
_
I would reccomend pins over setscrews. With bevel gears, both radial and axial position are very important. Even if your setscrew is tightened into a flat on the shaft, the bevel gear could still slide along the shaft.
Spike Relays...How Come they are not in the Inventor files D_Price Technical Discussion 2 28-01-2008 09:20
Does anyone have previous year's gearboxes they are not using? VEN General Forum 2 29-01-2007 17:32
Are these wheels available, anf if not are they ever gonna be? Elgin Clock FIRST Tech Challenge 3 12-11-2005 22:27
How do you attach a wheel to a shaft? SilverStar Technical Discussion 21 21-01-2003 19:52
45 Bevel Gears Ryan Curry Technical Discussion 1 03-04-2002 09:36
