Go to Post I think it would be beneficial for us frogs to be in the new hopper division - zsm150 [more]
  #31   Spotlight this post!
Unread 19-01-2010, 22:13
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
Re: pic: Ramp Video
Yep Joe, Update #3 today also green-lighted it. I really look forward to seeing this design in action! Be sure to post some videos of it during competition.
GitHub
  #32   Spotlight this post!
Unread 20-01-2010, 09:32
betsy888 betsy888 is offline
FRC #2713
betsy888 is an unknown quantity at this point
Question Re: pic: Ramp Video
Originally Posted by Chris is me View Post
There's a ball differential so if the front and back wheels are spinning in opposite directions, the omnis don't turn.
Thanks so much for the feedback. Our team has decided against having an articulating 6-wheel approach due to the complexity and the limitations of our team but I must say I'm still curious. How does your ball-differential work? From what I understand of ball differentials, there is one drive gear and 2 driven axles. So I assume your center omni wheels are on the driven axles. But you have 2 driving chains coming from the omni wheels and only one drive gear. Do you have a special type of ball differential? Can you explain a bit more?
Thanks again! Good luck with your design. Congrats on getting the green light in Q&A!!
  #33   Spotlight this post!
Unread 20-01-2010, 09:47
joeweber's Avatar
joeweber joeweber is offline
Coach team 1322
FRC #1322 (G.R.A.Y.T. Leviathons)
joeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant future
Re: pic: Ramp Video
The Mechanum wheels are driven, the chains drive sprokets on the ball differential, between the sprockets are steel balls that are inside a round flange with holes for the balls. The flange is attached to the drive shaft with the omni wheels. Pictures are on our wesite http://www.team1322.org/ideas.htm
If your not dirty than you must be just watching.
Thank's to http://weberelectric.biz/
FRC Team sitehttp://team1322.org/
2004 Great Lakes Xerox Creativity Award, 2008 Web Site Excellence Award, 2010 Kettering District and Western Michigan District Excellence in Engineering award, 2011 Kettering District Gracious Professionalism Award. 2011 Ann Arbor and State Cooperation Awards.2013 Kettering Xeroc Creativity Award.2015 Escanaba Chairman's Award.2015 Kettering Spirit Award.2016 Kettering Chairman's Award
FTC Lightining Boltz 5954, Thunder Botz 7032http://team1322.org/vex.htm
  #34   Spotlight this post!
Unread 20-01-2010, 09:57
the man's Avatar
the man the man is offline
AKA: Jacob Overla
FRC #4004
the man is on a distinguished road
Re: pic: Ramp Video
Is that the 45degree angle of the ramp? it looked to shalow, and you should build a real bump if possible because it is much harder to test with out the real thing if you know what i mean.
Every day is a new adventure!!!
  #35   Spotlight this post!
Unread 20-01-2010, 10:08
joeweber's Avatar
Coach team 1322
Re: pic: Ramp Video
That picture is from one year ago. You can view a video http://www.youtube.com/watch?v=jQMcw4QNCLI
The video ramp is a 45 degree ramp but we had to cut the corners for the low ground clearence of the 6 inch wheels. We will be using 8 inch
  #36   Spotlight this post!
Unread 20-01-2010, 11:07
DynamiteHack DynamiteHack is offline
FRC #2988
DynamiteHack is an unknown quantity at this point
Re: pic: Ramp Video
Originally Posted by joeweber View Post
As you can see from the drawing the frame is stationary on level ground and does not articulate. When it goes over the ramp the drive system articulates but the frame remains solid. ( the frame is where the bumpers are attached).
Correct me if I'm wrong, but wouldn't the sections connecting the omnis to the mountings have to get longer/shorter as it tilted? Adding height to the slope gives a longer line.
Unless the mountings can tilt in and out?
  #37   Spotlight this post!
Unread 20-01-2010, 11:39
joeweber's Avatar
Coach team 1322
Re: pic: Ramp Video
The rear virtical strut will pivot at the frame.
  #38   Spotlight this post!
Unread 20-01-2010, 21:44
FRC #2713
Re: pic: Ramp Video
[quote=joeweber;902964]The Mechanum wheels are driven, the chains drive sprokets on the ball differential, between the sprockets are steel balls that are inside a round flange with holes for the balls. The flange is attached to the drive shaft with the omni wheels. Pictures are on our wesite http://www.team1322.org/ideas.htm
I think I know the source of my confustion. I assumed the omni wheels could move independent of each other. Now that I see your ball differential drawing and photos it looks like they are attached to the same shaft so must move together. If this is true, why do you have 2 omni wheels at each location, why not just one?
As always, thanks and good luck!
  #39   Spotlight this post!
Unread 20-01-2010, 21:51
Re: pic: Ramp Video
It provides a smoother ride than having one single omni at each point. A number of teams have tried single; I believe most of them switched to double at some point.
pic: SWAT 2008 Robot--Short Video Clip at http://smithvillehighrobotics.com/video.htm SWAT1806 Robot Showcase 5 27-02-2008 14:00
Ramp Driving Video NOV8R Robot Showcase 14 13-02-2007 23:49
1583 Ramp Deployment Video NOV8R Robot Showcase 9 11-02-2007 12:09
VIDEO: Our robot VS. the ramp Cody Carey Robot Showcase 9 09-02-2006 21:45
Ramp Riot '05 Opening Video hockeydaisy341 Off-Season Events 6 02-11-2005 14:24
