Go to Post Only think of Gracious Professionalism as a standard to work toward personally. Never use it as a gauge to point out someone else’s shortcomings. - Rich Kressly [more]
Unread 19-01-2010, 16:56
nikRbokRz nikRbokRz is offline
FRC #1683
nikRbokRz is an unknown quantity at this point
Where can I find camera tracking code for Java?
My team has installed NetBeans and updated for FRC files without using the provided CD.
We've searched for the CircleTrackerDemo code, but cannot find it. Can someone please help me find this code? It will hopefully give us some idea of how the camera code will work in Java.
Thanks
Unread 20-01-2010, 03:21
Derschatten Derschatten is offline
FRC #1203 (Pandemonium)
Derschatten is an unknown quantity at this point
Re: Where can I find camera tracking code for Java?
File -> New Project -> Scroll to Samples then FRC Java Your choice will be their.
Unread 20-01-2010, 21:55
flameout flameout is offline
AKA Ryan Van Why
FRC #0957 (SWARM)
flameout is a name known to allflameout is a name known to allflameout is a name known to allflameout is a name known to allflameout is a name known to allflameout is a name known to all
Under New Project -> Samples -> FRCJava, I found the TrackerDemo project. However, it appears to be for Lunacy's vision target, instead of the Breakaway target demo. Also, the copyright is 2008, while for Breakaway it would probably be 2009.
Can this be found online, or is the TrackerDemo project the right one?
Thank you for any help.
Unread 20-01-2010, 23:03
Are you sure you installed the plugins from the right update site? http://first.wpi.edu/FRC/java/netbea...te/updates.xml
Unread 20-01-2010, 23:35
AKA Ryan Van Why
FRC #0957 (SWARM)
Well, since we did the beta test, I suspected that demo was left over from the beta. Therefore, I checked the URL, it hadn't changed, and NetBeans didn't find any updates.
However, randomly, I suddenly got a message that there were six updates available (after looking for them in Tools -> Plugins.) I updated, and got the code.
Now, I just need to check for v19 of the cRio image (I thought we were updated, but apparently not.)
Thank you for your help.
where can I find it? kDude Control System 3 22-01-2008 17:50
Using kevin's code for driving and camera tracking razzoc Programming 3 18-02-2007 08:50
Where is the multi object tracking code for the RC? EHaskins Programming 52 17-01-2007 11:55
Where can I find motor control in Camera.c? sjung9442 Programming 3 31-01-2006 15:49
where can I find the code for the first 15 seconds? CompMaster Programming 2 16-02-2005 16:23
