Go to Post We like playing with power tools, stripping wire, or just stripping for alliance partners... - Amanda Morrison [more]
Unread 20-01-2010, 23:23
Re: Gyro/Acceler. connections
Originally Posted by fiferdc View Post
The gyro has a three pin connection (ground, power, signal), so how would it connect to the I2C, which has four connections?
There has been some confusion in the answers given. People talking about I2C and SPI are really referring about the accelerometer board, even though they might have slipped up and called it a gyro. The yaw rate sensor ("gyro") board provides a pair of analog outputs.
We have it connected to the analog breakout, but we're having problems getting a reading, so I'm not sure if that is due to a bad connection, or just a programming problem.
I don't know what you mean by "problems" here. What kind of reading do you get, and what are you expecting?
Do you see an appropriate battery voltage display on the Driver Station?
Unread 21-01-2010, 06:04
jtdowney jtdowney is offline
Boiler Up
AKA: John Downey
FRC #4302 (Robophins)
jtdowney has a brilliant futurejtdowney has a brilliant futurejtdowney has a brilliant futurejtdowney has a brilliant futurejtdowney has a brilliant futurejtdowney has a brilliant futurejtdowney has a brilliant futurejtdowney has a brilliant futurejtdowney has a brilliant futurejtdowney has a brilliant futurejtdowney has a brilliant future
I definitely messed up and wrote gyro when I meant accel, another reason I shouldn't post at 4:30am.
John Downey
Lead Robot Inspector - Purdue IndianaFIRST District
Whitney Young Magnet High School/Robophins (FRC 4302) - Mentor (2013-current)
Midwest Regional Planning Committee - Member (2012-current)
Boilermaker Regional Planning Committee - Member (2011-2014)
Robot Inspector (2008-current)
Purdue FIRST Programs - Staff Advisor (2008-2011)
Lafayette-Jefferson High School/Precision Guessworks (FRC 1646) - Mentor (2006-2011)
Unread 21-01-2010, 20:54
TD912 TD912 is offline
AKA: Chris Leung
FRC #1989 (Viking Robotics)
TD912 has much to be proud ofTD912 has much to be proud ofTD912 has much to be proud ofTD912 has much to be proud ofTD912 has much to be proud ofTD912 has much to be proud ofTD912 has much to be proud ofTD912 has much to be proud ofTD912 has much to be proud ofTD912 has much to be proud of
I got it all wired up correctly, but I'm really confused on how to properly connect to it and recieve data from it in LabView. I've looked all over for the ADXL345 LabView example some other people have mentioned, but I cannot find it anywhere. It's not on the "Example" list in LabView, or in the FRC example code in the National Instruments folder, nor anywhere on the Classmate. I even did a file/folder search for "ADXL345" and it didn't return anything).
Unread 21-01-2010, 21:04
Did you install the mandatory LabVIEW update?
Unread 21-01-2010, 22:00
AKA: Chris Leung
Ahh, that was the problem.
I installed the DS update but not the LabView one.
Unread 23-01-2010, 12:00
PortugazD.Ace's Avatar
PortugazD.Ace PortugazD.Ace is offline
AKA: Timothy Gonzales
FRC #1165 (Team Paradise)
Team Role: Student
PortugazD.Ace is an unknown quantity at this point
Also, can anyone tell me where the gyro connects to?
Unread 23-01-2010, 13:08
jhersh jhersh is offline
AKA: Joe Hershberger
FRC #2468 (Appreciate)
Analog input bumper channels 1 or 2 in slot 1 of the cRIO.
Jumper Connections Lord Byron Electrical 4 26-01-2009 20:43
Field Connections? xxMORT11xx FRC Control System 4 24-01-2009 21:51
Connections to Driver Station Zellboy Electrical 1 23-01-2009 16:24
Frame connections manleycor Technical Discussion 15 18-11-2003 01:14
Drill Motor Connections archiver 2001 8 24-06-2002 00:49
