Go to Post Now, if that team were to split...would it be dividing by zero? - Karibou [more]
Unread 20-01-2010, 21:49
Team 2811's Avatar
Team 2811 Team 2811 is offline
WHAT DID YOU DO!? ..umm... whoops!
AKA: Ian Heffron
FRC #2811 (Stormbots)
Team Role: Electrical
Team 2811 is on a distinguished road
Exclamation Size limit for controller station?
I am just wondering if there is a size restriction on the maximum size for the driver station.
If you have any insight on this, please help me.
Thanks
Ian Heffron
Team 2811 Rules man
Its about a day out!
Once, there were two marshmallows roasting over a campfire.
First marshmallow, "It is really hot up here."
Second marshmallow, "OH MY GOD ITS A TALKING MARSHMALLOW!!!"
The more you learn the more you know
The more you know the more you forget
The more you forget the less you know
So why learn?
Unread 20-01-2010, 21:56
Re: Size limit for controller station?
Thanks
Ian Heffron
Team 2811 Rules man
Section 8.3.10 has all the rules on the operator console.
In this case, you want <R81>, which tells you that you have a 60" by 12" inch shelf that the console has to fit on.
But wait, there's more! According to Section 6.2.10 , there is a 54" x 2" strip of loop-side Velcro tape running down the middle of that shelf. You are highly advised to have a matching hook-side strip on the bottom of your operator console. (I've seen control boards go flying before that strip of Velcro was added. Trust me, it's worth it.)
Unread 20-01-2010, 23:11
Team 2811's Avatar
AKA: Ian Heffron
Is there a maximum height restriction on the controller station?
So why learn?
Unread 20-01-2010, 23:15
There is not a height restriction, but you may want to use common sense--your drivers will want to see over or through it, and if they don't, your coach will. (And quite possibly other coaches will, too.)
I would also highly discourage going higher than the top of the alliance station wall; there may be a few missed shots/trident hits up there.
Unread 20-01-2010, 23:37
Team 2811's Avatar
AKA: Ian Heffron
Hey Eric,
How do you write "...has read the 2010 manual" with your name and avatar at the top of all of your posts? Plus, how do you get a reputation?
So why learn?
Unread 20-01-2010, 23:39
Hey Eric,
I'll PM you about that.
Controller size limit? KGood Technical Discussion 5 09-02-2008 16:27
Wire Size Limit? (InsrtNameHere) Electrical 2 15-02-2006 20:20
[OCCRA]: Size limit of Operator Control Station Alex Golec OCCRA Q&A 1 11-10-2005 05:33
Robot Controller File Size Limit ?? RoboGeek Programming 1 17-01-2005 19:59
Operator Station Size ktrussell Technical Discussion 0 15-01-2003 15:57
