Go to Post the whole process is the most valuable part, not the award itself - Rich Kressly [more]
Unread 20-01-2010, 18:41
Tank2010's Avatar
Tank2010 Tank2010 is offline
Draftsman. Ammoknights Rule!
AKA: Dave
FRC #1566 (Ammoknights)
Tank2010 is an unknown quantity at this point
Lightbulb Sprinkler system valve as a pneumatics quick Release valve
We are playing with the idea of using a sprinkler system valve as a quick release valve for releasing the air out of the cylinder quickly. We were wondering if someone has done this and would mind sharing or is it against the rules?
Team 1566 Rules!!!!!!!!
Unread 20-01-2010, 18:56
Andrew Schuetze's Avatar
Andrew Schuetze Andrew Schuetze is offline
499 Founder / Alamo FTC & FLL AP
Andrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond repute
Re: Sprinkler system valve as a pneumatics quick Release valve
Not legal and please at least download and look at the competition manual before posting and asking if it is allowed.
Here is a link to the pneumatics manual if you want to learn about how to incorporate them into your robot. And from the Robot Manual, see section 8.3.9 Pnuematic system
specifically rule
<R71> To satisfy multiple constraints associated with safety, consistency, robot inspection, and constructive innovation, no pneumatic parts other than those explicitly permitted by the Pneumatic System Rules may be used on the ROBOT.
And
<R72> In addition to the items included in the KOP, pneumatic system items specifically permitted on 2010 FRC ROBOTS include the following items. All included items must be "off the shelf" pneumatic devices rated by their manufacturers for pressure of at least 125psi, and used in their original, unaltered condition (except as required for assembly with other components).
A automatic water sprinkler value is by definition not a pneumatic device.
APS
Founder FRC 499
Parent alumni FRC 2745 & 4219
Co-Coach FTC 4549 & 6407
Alamo FTC Affiliate Partner
Alamo FLL Affiliate Partner
Unread 20-01-2010, 18:57
martin417's Avatar
Opinionated old goat
AKA: Martin Wilson
Wow, how many ways does this violate the rules?
1) all components must be rated for 125 PSI air pressure. Sprinkler valves are generally PVC, and as such are not rated for pressurized gas (air)
2) Max Cv =.32 for all valves. I don't know what sprinkler valves are rated at, but I would guess >3.2, an order of magnitude more than allowed.
3) max inlet size 1/8 NPT. The smallest sprinkler valve with which I am familiar is 3/4" NPT. again, way out of bounds.
In short, don't even think about it.
Former Mentor Team 1771
Former mentor Team 4509
Unread 20-01-2010, 20:02
eaglecat eaglecat is offline
AKA: John
eaglecat is on a distinguished road
Send a message via AIM to eaglecat Send a message via Yahoo to eaglecat
4) No other solenoid actuators are permitted except for the one(s) in the festo pneumatic valve. (OR equivalent specs of another manufacturer... I had recalled there being a "NOTE 1" on the excel file for KoP... there is not such a note, a hydraulic sprinker valve is not an equivalent pneumatic valve. Look for purpose built. Maybe a paint ball gun has a device for air release quickly where a servo could power the "trigger"?)
- eaglecat (John)
Unread 20-01-2010, 20:27
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
Originally Posted by eaglecat View Post
LOL
- eaglecat (John)
LOL
Wrong!
It is important to know the rules well when responding to questions here and even more important if you are going to poke fun at others due to their lack of rules knowledge.
The appropriate rule here is <R72-C>
<R72> In addition to the items included in the KOP, pneumatic system items specifically permitted on 2010 FRC ROBOTS include the following items. All included items must be “off the shelf” pneumatic devices rated by their manufacturers for pressure of at least 125psi, and used in their original, unaltered condition (except as required for assembly with other components).
C. Solenoid valves. All such valves must have a maximum ⅛” NPT port diameter, and a maximum Cv of 0.32 (if non-KOP valves are used, the team will be required to provide part documentation validating that the valves meet these constraints).
Any valve that meets the Cv, port size and pressure rating spec may be used (unless it violates another rule, I can think of at least one that is possible, but very unlikely)
Unread 21-01-2010, 00:55
AKA: John
As an engieneer of heavy machinery, we often use solenoid actuators. Specifically they are located in the pilot hydraulic valves that actuate the main hydraulic valves on our wheel loaders. (Electro-hydraulic designs.)
We have at times tested these on the bench. They get very warm if accidentally left on at full current. To say the least. They are large electro magnets. Will easily melt nearby electronics and burn tiny hands.
Electronic solenoids are EXPLICITLY banned. Given my above experiences, i posit this is due to safety.
Well, banned except for the itsy bitsy tiny 20 wind thing in the Festo.
You have many options, other than that for your design. Pilot pneumatic (though I have not seen it done) is amongst them. Actually would be quite ingenious. HOWEVER please read the rules, it gains you nothing, as the largest tubing you can use and only tubing size you are allowed to use (from what I read there and am told) for pneumatics is the small stuff in the KoP. Just different colors allowed.
But, in short, in searching the FESTO site, they have a "quick release version"... probably (my guess) is they use a finer wire lower O2 wire with 2x the windings to make a more powerful magnet in the same size... maybe neodenium instead of cobalt... same "juice up" linearly used radially in low versus high end model plane motors. (my inspiration for engineering) however, see my post about air resistance. I will be over the next few days finishing one about kicker design. It isn't all about fast. It is a lot about mass. Consider trying to add a lever to your pneumatic design, or looking at the "foot" mass... too high (hard to accelerate) or too low (much less than ball mass)? It is an Inelastic Collision with a CoR of about 60%... give or take, for the lower 0.62 bar inflation compared to FIFA testing at 0.8 bar.
- John (eaglecat)
Unread 21-01-2010, 01:48
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
Once again, the Festo kit valve is NOT the only allowable pneumatic solenoid valve. Please stop posting this to avoid confusing people.
For example this SMC valve is legal:
http://www.coastpneumatics.net/displ...QZ2121-6LO-N7T
This MAC valve is also legal:
http://www.macvalves.com/products/Th...mall/36/36.htm
I'm sure there are MANY, MANY others that meet the specs required by the manual as well.
The distinction is fine, but important for those looking for additional parts.
Unread 21-01-2010, 08:29
ayeckley's Avatar
ayeckley ayeckley is offline
AKA: Alex Yeckley
FRC #2252 (Mavericks)
ayeckley has a reputation beyond reputeayeckley has a reputation beyond reputeayeckley has a reputation beyond reputeayeckley has a reputation beyond reputeayeckley has a reputation beyond reputeayeckley has a reputation beyond reputeayeckley has a reputation beyond reputeayeckley has a reputation beyond reputeayeckley has a reputation beyond reputeayeckley has a reputation beyond reputeayeckley has a reputation beyond repute
Electric solenoid *actuators* are prohibited, but electro-pneumatic solenoid valves are not. This seems to be the misunderstanding.
Unread 21-01-2010, 08:33
fsgond's Avatar
fsgond fsgond is offline
Why aren't you throwing balls?!
AKA: Anthony
FRC #5484 (Memento Vitam)
fsgond has a brilliant futurefsgond has a brilliant futurefsgond has a brilliant futurefsgond has a brilliant futurefsgond has a brilliant futurefsgond has a brilliant futurefsgond has a brilliant futurefsgond has a brilliant futurefsgond has a brilliant futurefsgond has a brilliant futurefsgond has a brilliant future
Without going into the rules, I have used the valves for 120 PSI air and they work fine. the main problem that you would run into is that the system usually run on 48V AC.
Just FYI
Unread 21-01-2010, 09:11
Taylor's Avatar
Taylor Taylor is offline
Professor of Thinkology, ThD
AKA: @taylorstem
FRC #3487 (Red Pride Robotics)
It is against the rules.
HOWEVER
We have done it, we are very satisfied with the results, and we plan to continue using the exact system you described in the future.
On our T-shirt cannon.
Hi!
Unread 21-01-2010, 09:47
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Yet another illegal way to release a lot of air at once is to use a small cylinder to directly actuate a gate valve.
Unread 25-01-2010, 18:54
Tank2010's Avatar
AKA: Dave
Ya sorry every one It was a crazy thought that poped into my head thanx for all the good Ideas that are legal. We werent sure what was out there and couldn't seem to find what we were looking for thats what brought us to post the question here. Thanx to those who gave me a kick in the pants for even thinking about useing the Sprinkler system valve and not even trying to help.
old SMC valve quick question Paul Rodi Pneumatics 4 18-02-2009 18:24
Parker Valve comphappy Pneumatics 4 26-02-2008 01:31
Need Valve DPPT1717 Pneumatics 1 13-01-2007 18:49
Valve Kevin A Off-Season Events 0 19-09-2003 18:58
Two Pneumatics off one Double-Solenoid Valve GrahamS314 Pneumatics 5 24-02-2003 23:49
