Go to Post I've got a couple team members who have an incredible knack for destroying robot parts... - Tom Line [more]
Unread 20-01-2010, 23:40
bobosalad's Avatar
bobosalad bobosalad is offline
FRC #2518 (Spartans of St. Jude)
Team Role: Driver
bobosalad is an unknown quantity at this point
Robot Lifting
It is pretty obvious that people are spending a lot of time into the chassis, wheels, motors and even kickers. Well this thread is to bring attention to the lifting portion of the robot. I realize that a lot of people havent started that part yet, and i also realize that others have it made. Leave ideas, pictures, plans, problems, and everything you can think of about a device in order to lift the robot at the end of the competition. Thanks a lot.
Unread 20-01-2010, 23:52
IndySam's Avatar
IndySam IndySam is offline
FRC #0829 (Digital Goats)
Re: Robot Lifting
So far we have a Harbor Freight winch coupled to a AM 3 stage GEM transmission with a CIM that can seams like it is strong enough lift a small car
Eventually we will make a custom winch with the GEM but if we run out of time at least we have something.
Unread 21-01-2010, 00:08
Chris is me's Avatar
AKA: Pinecone
Re: Robot Lifting
I like it. I was thinking about using the 5th CIM with stacked GEMs for extra torque and it doesn't sound like such a bad idea.
I've got nothing else to show, other than that I've been inspired by the Pink team and the Poofs. I really have no idea how to do this. :3
Unread 21-01-2010, 00:18
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Re: Robot Lifting
don't need the torque so much as you need to slow it down
Unread 21-01-2010, 00:40
Tom Line's Avatar
Tom Line Tom Line is online now
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
Re: Robot Lifting
We had the shooter concept in 2 days. The chassis in 4. Just today we had a major breakthrough on a simple way to hang and we're cadding it to check feasibility. We've spent time in every meeting so far discussing hanging.
I believe the difficulty hanging is disproportionate to the returns. Consider that if you didn't hang for those 20 seconds, you could probably get 1 more ball in the goal, rendering the hanging only really worth 1 point. Consider if non of your bots could hang, you could potential score 2 or 3 balls in that 20 seconds. Perhaps matches will be decided by a couple points, but this is NOTHING like 2007 where a single bot with a good ramp system could win 80% of it's seeding matches just by virtue of having those ramps.
Finally, the difficultly of suspending means that I doubt very many matches will see robots suspended. Even if they do manage to suspend, that extra 1 point *probably* won't be all that important: I certainly would not make it a design priority.
I look forward to someone building a bot specifically for the finale - there are ways to do it (twin ramps, lifting the other 2 robots on your team, etc). That bot could be a very valuable asset, but I don't think it's a game breaker like a good ramp bot was in '07.
Unread 21-01-2010, 00:43
RRLedford RRLedford is offline
FTC 3507 Robo Theosis -- FRC 3135
AKA: Dick Ledford
FRC #3135 (Robotic Colonels)
RRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond repute
Re: Robot Lifting
We are going for 3-5 seconds for BOTH cable attachment to tower bar using a latex tubing snap bar, and then fast elevation of our bot with pneumatic cable tensioning speed, having saved all of our air for the end game ( our kicker is a winder that stores bungee tension & releases at any point during the wind up for variable kick power). If you can't make this happen quickly there is little time left to help partners get off the floor. Yeah, the two points is marginal, but 5 or 8 starts looking worth it.
The initial pneumatic pull up will be supplemented by having more winder pulling available at a stronger than pneumatic force levels from our same kick winder mechanism. So, if partners can get hooked on to our deployed hanging Kevlar cables, even with a mere static hook at top of their frame, we can still hoist them up off ground using our kick winder drive pulling at 250+ pounds of lift. Heck, we will even loan them a hook to mount on their frame before the match begins!
-RRLedford
Unread 21-01-2010, 01:12
MrForbes's Avatar
AKA: Jim
Re: Robot Lifting
5 seconds to attach and lift would make it worth doing. 20 seconds...not so much.
Unread 21-01-2010, 01:24
dtengineering's Avatar
AKA: Jason Brett
Re: Robot Lifting
Right now the plan is no winch, no cables... you will elevate us, and we will suspend you.
With a bit of credit to 1114's rack'n'roll design, we're looking at ramps.
It's still in the design stage, however, and if it doesn't pan out, well... winches work, too.
Jason
Unread 21-01-2010, 01:25
bhsrobotics1671's Avatar
bhsrobotics1671 bhsrobotics1671 is offline
Andrew Nabors
AKA: Andrew Nabors
FRC #1671 (Buchanan Bird Brains)
bhsrobotics1671 is a splendid one to beholdbhsrobotics1671 is a splendid one to beholdbhsrobotics1671 is a splendid one to beholdbhsrobotics1671 is a splendid one to beholdbhsrobotics1671 is a splendid one to beholdbhsrobotics1671 is a splendid one to beholdbhsrobotics1671 is a splendid one to behold
Re: Robot Lifting
I couldn't agree more.
Buchanan Bird Brains - FRC Team 1671
2015 FIRST World Champions
118, 1678, 1671, 5012
Unread 21-01-2010, 01:28
run the trap!!!
Team Role: Human Player
Re: Robot Lifting
Has anyone considered a compound pulley system to lift their robot?
This would be considerably easier to build than a large gearbox, could potentially be lighter, and would result in less mechanical strain on the gears and axels.
-Philip J. Fry
Unread 21-01-2010, 03:05
CraigHickman
Posts: n/a
Re: Robot Lifting
It would be beneficial for teams to examine alternate lifting methods. Why is everyone so focused on hanging from the horizontal bar, when there are four vertical bars that would work just as well with a smaller, simpler mechanism?
Unread 21-01-2010, 03:19
AKA: Pinecone
Re: Robot Lifting
I don't see the smaller, simpler mechanism I could employ to hang from the horizontal bars. I've thought about it and anything that comes to mind isn't easy to detach. Vertical hooks just slide over the bar and pull up.
Unread 21-01-2010, 03:21
R.C.'s Avatar
R.C. R.C. is offline
2017... Oooh Kill em, Swerve!
FRC #1323 (MadTown Robotics)
Re: Robot Lifting
Would have to agree with Chris here. You can't really get much simpler then up, over, and pull.
Unless you could magically lift yourself up with a bag of air?
-RC
R.C.
MadTown Robotics Team 1323
Unread 21-01-2010, 03:25
CraigHickman
Posts: n/a
Re: Robot Lifting
Add in the mechanism to get the hook up there, and you'll see where my concept of complexity comes from. I've been working on a design that literally has two hinges, and can hang the robot.
Edit: Bag of air?! Heck yes!
Unread 21-01-2010, 03:39
AKA: Dick Ledford
Re: Robot Lifting
Tension elements are the best approach for elevating, being lightest and strongest. Yes, you still need an arm to hook cable onto horizontal bar, but 1000 lb kevlar is light, and bar can be reached with the arc of a single arm rotation. Multiple long stroke air cylinders spreading pulleys apart in a compound array can give rapid cable tensioning lift to the required height, especially if you don't deplete your air reserves doing a pneumatic kicker.
-RRLedford
1070's 2007 Robot Lifting AznPrincess3089 Robot Showcase 8 19-03-2007 19:37
Team 192, Robot Lifting Teaser Joobacca Robot Showcase 7 02-02-2007 17:46
Lifting one vs. lifting two jgannon Rules/Strategy 1 14-01-2007 17:37
robot lifting doomsdaytank Rules/Strategy 2 14-01-2003 16:41
Lifting goals patrickrd Rules/Strategy 6 17-01-2002 17:58
