Go to Post Once I see that it is black with aluminum ends, I only care about the inside. Sort of like Oreo's. - Al Skierkiewicz [more]
Thread Tools Rating: Thread Rating: 32 votes, 5.00 average. Display Modes
Unread 21-01-2010, 00:10
kE7JLM's Avatar
kE7JLM kE7JLM is offline
KE7JLM `
AKA: John Harris
FRC #0842 (Falcon Robotics)
Team Role: Driver
kE7JLM is a name known to allkE7JLM is a name known to allkE7JLM is a name known to allkE7JLM is a name known to allkE7JLM is a name known to allkE7JLM is a name known to all
Send a message via MSN to kE7JLM
Re: 842 Final Kicker Desgin
Originally Posted by bhsrobotics1671 View Post
So if I understand this correctly, you pull back causing it to latch, then you push the same cylindar forward, but the gate latch stops it, then you open the gate latch, causing a quicker release. Am I understanding this correctly?
Thanks so much on behalf of team 1671!
Could not be more correct, but let me give credit to team 1726. They devolved this technique in 08... Good luck to all, hope the vid helps and we will make this as safe as possible.
Team 842 Programmer
Pictures at:
http://picasaweb.google.com/KE7JLM
http://picasaweb.google.com/john.h.842
Videos -
http://www.youtube.com/user/KE7JLM
When your not busy with FIRST try NURC
Unread 21-01-2010, 00:50
Scott358 Scott358 is offline
Engineer/Mentor
AKA: Scott5736
FRC #5736 (Kingsmen)
Scott358 is just really niceScott358 is just really niceScott358 is just really niceScott358 is just really niceScott358 is just really nice
Very nice, simple, hybrid elastic band-cylinder design!
Do you know the difference in distance by simply using the elastic band in the exact set-up, as even though you are "preloading" the cylinder and dumping the pressure on the "front" side of the piston, there still may be a negative effect by having the cylinder in the loop on the kick?
We are considering a design where the gate latch is attached to the end of the cylinder, cylinder extends to engage the kicker, cylinder retacts pulling back the kicker, and the gate latch is released when ready to kick (therefore being powered only by the elastic band). This would pretty much be the same parts, with a bit more complication in moving the latch to engage the kicker, but we're thinking we'll get higher velocity.
Any thoughts?
Scott5736 (formerly Scott3137(formerly Scott358))
Unread 21-01-2010, 00:55
Cow Bell Solo's Avatar
Cow Bell Solo Cow Bell Solo is offline
No Stolte No
AKA: Chris
FRC #2194 (Fondy Fire)
Cow Bell Solo is a jewel in the roughCow Bell Solo is a jewel in the roughCow Bell Solo is a jewel in the roughCow Bell Solo is a jewel in the rough
Send a message via AIM to Cow Bell Solo Send a message via MSN to Cow Bell Solo Send a message via Yahoo to Cow Bell Solo
Any thoughts?
Yes my thoughts i'm thinking off, how durable is that latch to deal with having to pull back with the force of of the elastic band instead of just having to hold it back into position.
Who let the Blue Smoke Out
Team 2194 Mentor - 2012-Present - http://fondyfire.com
Team 2207 Alumni - http://whitebearlakerobotics.com
Iowa FIRST LEGO League Planning Team Member - 2010-Present - http://www.isek.iastate.edu/fll
FIRST LEGO League volunteer - 2008-Present
2008: MN Regional Quarterfinalists, Website Excellence
2009: MN North Star Quarterfinalists, recognized for safety, Website Excellence
Unread 21-01-2010, 01:00
kE7JLM's Avatar
KE7JLM `
AKA: John Harris
Team Role: Driver
Any thoughts?
Without using the preloaded cylinder we get about 5 feet... So the cylinder plays a big role. With the hybrid we get on average of 30 feet. With just preload (no elastic) we get about 20-25.
Good luck with your elastic design, we decided against using it because the room need to use them... and the difficulty to bringit back, but hopefully you get it!
Thanks
Team 842 Programmer
Pictures at:
Videos -
Unread 21-01-2010, 01:03
Bill_B Bill_B is offline
You cannot not make a difference
FRC #2170
Bill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond repute
Originally Posted by Matt H. View Post
In my mind an important safety practice is using parts as they were designed. I also believe safety should be a priority for FIRST teams.
As such I don't think it is unreasonable to encourage teams to purchase load rated release mechanisms such as McMaster-Carr #3899T54.
You weren't always in Arizona, right? That type device is in widespread use for holding and releasing nautical loads established by sails and rigging. While I appreciate the thought about load testing, this particular device would not close by itself, even though it might be possible to get it engaged on the retraction stroke of the piston. I will take a look through that massive online catalog to see if there is a better choice with a load specification.
Unread 21-01-2010, 01:18
RRLedford RRLedford is offline
FTC 3507 Robo Theosis -- FRC 3135
AKA: Dick Ledford
FRC #3135 (Robotic Colonels)
RRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond repute
Looks quite solid and consistent. Pneumatics are nice for eliminating cables & tangles.
It would seem that with pneumatic tensioning of the the bungees, you will start dropping pressure if the kicks cycle too often? Have you calculated the point of what maximum # of kicks per minute the compressor can handle before pressure starts dropping steadily?
We opted for a CIM with gear down for a tension winder because we did not feel that pneumatics could BOTH kick far enough AND frequently enough throughout the match. What is your assessment of this concern?
Our winder scheme has different issues to solve. First is how to do a trigger release of tension instantly at any point during the wind cycle (no gate latch scheme for us - we want to have programmable kick distance), . Second is how to get instant recycle to tensioning again without wasting time having winder going 180 degrees before it starts the next pull. Third, is how to keep winder rotating only in one direction without wrapping up the tension cable.
We have engineered the solution to all these issues and will be testing prototypes in the next few days.
-RRLedford
Unread 21-01-2010, 01:36
dude__hi's Avatar
dude__hi dude__hi is offline
Now a CSWA
AKA: Cristian Arcega
dude__hi is an unknown quantity at this point
-RRLedford
http://www.youtube.com/watch?v=g4-8B...eature=related
We got 3 consecutive shots at ~20ft before the tank dropped below 40psi. We only had one storage tank connected though so I think we can get 5 shots if we had all four storage tanks on before we would have to wait a while to shoot over the ramps from a fair distance. However if the other pneumatic actuators are taken into account the number is much higher.
Powerpoint is a distraction, people use it when they don't know what to say...
2008 FIRST Chairman's Award Winner
Unread 21-01-2010, 09:54
thefro526's Avatar
Mentor for Hire.
AKA: Dustin Benedict
no team (EWCP, MAR, FRC 708)
Originally Posted by Akash Rastogi View Post
I liked the fence latch idea enough to steal it.
Hope you don't mind, FIRSTers are constantly told to steal from the best.
Seconded.
Thanks for posting up so much of your kicker design, I know it's helped me understand some concepts a lot better and I'm sure it's helped others too.
-Dustin Benedict
Unread 21-01-2010, 11:15
Alex Cormier's Avatar
Alex Cormier Alex Cormier is offline
www.TwoPencilDesigns.com
AKA: Grizz, Twinkletoes, PitBull1126
FRC #1405
Alex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond repute
This is VERY interesting.
http://forums.usfirst.org/showthread.php?t=13900
Two Pencil Designs - Vinyl Graphics, Bumper Numbers, and Strategy Items!
Like us on Facebook & follow us on Twitter
Facebook.com/TwoPencilDesigns & TwoPencilDesign
Unread 21-01-2010, 11:22
thefro526's Avatar
Mentor for Hire.
Originally Posted by Alex Cormier View Post
You're right, that is VERY interesting.
Theoretically, if a team were to have a kicker spanning the entire 38" side of their robot they could legally kick 4 balls at once...
Shoot, even kicking 2 balls at once would be awesome...
-Dustin Benedict
Unread 21-01-2010, 14:16
Rohan J Rohan J is offline
FRC #1540 (Flaming Chickens)
Rohan J has a spectacular aura aboutRohan J has a spectacular aura aboutRohan J has a spectacular aura about
Earlier in the thread you mentioned that you were working on getting multiple shooting distances/forces. I toyed with the idea of a pneumatic cocking device for my spring-loaded kicker, but went with a motor driven winch instead so we could get multiple powers. How did you manage this with a pneumatic cylinder which only has two positions?
Also, this is what i'm using for my latch/release mechanism. The one I bought is rated to 200lbs. http://www.destaco.com/products.asp?...ory_2=Standard
Unread 21-01-2010, 14:51
dude__hi's Avatar
Now a CSWA
Yeah we're using 4 kickers, each kicker covers its entire side of the robot minus the multiple kicker overlap.
Unread 27-01-2010, 09:58
Re: 842 Final Kicker Design
Originally Posted by kE7JLM View Post
http://www.youtube.com/watch?v=eiLiwS8p-QY
Let us know what you think, detail in the description
The tubing which feeds your cylinder is not KoP, and I did not see any solenoid valves (they might have been off-camera).
Have you tested this yet with KoP tubing and with solenoid valves? The valves are only 1/8" dia port and Cv 0.32 which makes a difference.
Also, are you pre-charging the cylinder?
Unread 27-01-2010, 10:06
kE7JLM's Avatar
KE7JLM `
AKA: John Harris
Team Role: Driver
You are correct, the hose is not KOP but it is exactly the same stuff. We where just saving the super cool green hose for the bot. The solenoid are off camera, we are using the double action SMC.
Team 842 Programmer
Pictures at:
Videos -
Unread 27-01-2010, 10:15
Are you pressurizing the cylinder prior to releasing the latch ("pre-loading")?
Are you using the same valve for both sides of the cylinder?
Would you be willing to share with us what part number SMC you are using?
Thanks.
#1860 kicker prototype sloteera General Forum 12 04-02-2010 14:27
987 Kicker Destruction JM987 General Forum 29 23-01-2010 16:46
FRC114 Kicker Teaser James114 Robot Showcase 10 22-01-2010 16:56
Hybrid Kicker falconmaster General Forum 15 20-01-2010 14:27
pic: The final...final match CD47-Bot Extra Discussion 4 17-04-2003 16:24
