Go to Post As a Mississippi boy, I'm especially proud that I could read - Natchez [more]
Unread 20-01-2010, 20:56
DRH2o's Avatar
DRH2o DRH2o is offline
AKA: Dan Waters
FRC #1598 (Team Talon)
DRH2o is a glorious beacon of lightDRH2o is a glorious beacon of lightDRH2o is a glorious beacon of lightDRH2o is a glorious beacon of lightDRH2o is a glorious beacon of lightDRH2o is a glorious beacon of light
Chain contacting BUMP
I have posted to Q&A. Opinions: Chain dragging on BUMP while crossing. Not supporting the weight of the robot, just dragging on the corners of the
BUMP. Violation of <R08> or not.
Unread 20-01-2010, 21:09
Dad1279 Dad1279 is offline
FRC #1279 (Cold Fusion)
Re: Chain contacting BUMP
IMHO Violation of <R08> & <R36>
If the chain is not supporting, why not just design a guard to protect the field?
Unread 20-01-2010, 21:14
RoboTigers1796 RoboTigers1796 is offline
FRC #1796 (RoboTigers)
RoboTigers1796 is a glorious beacon of lightRoboTigers1796 is a glorious beacon of lightRoboTigers1796 is a glorious beacon of lightRoboTigers1796 is a glorious beacon of lightRoboTigers1796 is a glorious beacon of lightRoboTigers1796 is a glorious beacon of light
I know you referenced the rule so its not like you haven't read it. Simply showing it for visual purposes.
<R08> ROBOT wheels, tracks, and other parts intended to provide traction on the FIELD may be purchased or fabricated (“traction devices” include all parts of the ROBOT that are designed to transmit any propulsive and/or braking forces between the ROBOT and the FIELD). In no case will traction devices that damage the carpet or other playing surfaces be permitted. Traction devices shall not have surface features such as metal, sandpaper, hard plastic studs, cleats, or other attachments. Anchors (i.e. devices that are deployed/used to keep one’s ROBOT in one place and prevent if from being moved by another ROBOT) shall not use metal in contact with the carpet to “stay put.” Gaining traction by using adhesives or Velcro-like fastener material is not allowed.
I also see you say it isn't to gain traction so it is slightly in conflict with the rule. Even with that in mind I don't think it would permitted. Simply because there is too high a chance of it possibly getting caught in the rug as your moving over it and ripping the rug or simply because it will dirty the rug with the grease/oil transmitted from the chain to carpet. Last year we had to cover up a chain system that was a foot above the floor just because it was splashing too much grease/oil supposdly. It also violates the general rule that metal should not be in contact with the carpet. So I would have to say no, the GDC would not permit it, and also your inspector at your regional would not allow it.
Is there that much if an issue you cant bring your chain system higher to avoid contact with the bump while moving over it?
2014 Attended: NYC Regional, SBPLI Regional NYC Regional- Imagery Award in honor of Jack Kamen
2013 Attended: NYC Regional, SBPLI Regional, FIRST Championships NYC Regional- Gracious Professionalism Award sponsored by Johnson & Johnson,SBPLI Regional- #4 Alliance Captain & Regional Winner- With our impeccable alliance 358 and 3171
2012 Attended: NYC Regional, SBPLI Regional, FIRST Championships NYC Regional- #7 Ranked Seed & Semi-Finalists, SBPLI Regional- #3 Seed & Regional Winner- With our very awesome alliance 527 and 870, Industrial Design Award sponsored by General Motors
2011 Attended: NYC Regional, SBPLI Regional SPBLI Regional- Xerox Creativity Award and #5 Alliance Captain
2009 Attended: NYC Regional, FIRST Championships NYC Regional Winner- With our amazing alliance 1807 and 56
Unread 20-01-2010, 21:17
DRH2o's Avatar
AKA: Dan Waters
We will probably either guard the chain or re-route it. Would rather leave it alone if you know what I mean.
Unread 20-01-2010, 21:20
Better to be safe then sorry. Wouldn't want to show up to a regional and have to redesign your drive system because an inspector won't allow your robot on the field! Good luck.
Unread 20-01-2010, 21:21
DRH2o's Avatar
AKA: Dan Waters
The main reason I posted this was for others to check their design before it is too late and hard to make the correction. We usually do not have to worry about this happening.
Unread 21-01-2010, 00:11
EricH EricH is online now
Q&A has answered: http://forums.usfirst.org/showthread.php?t=14011
Short version: Drag a chain, you've just violated <R08>. Plan accordingly.
Unread 21-01-2010, 00:15
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
this would have been a good "don't ask, don't tell".
Oh well.
I guess if we oil the chain to make it not a traction device, then it has oil, which is a different no-no
Unread 21-01-2010, 00:24
Rich Kressly's Avatar
Rich Kressly Rich Kressly is offline
Robot/STEM troublemaker since 2001
no team (Formerly 103 & 1712. Now run U.P. Robotics (other programs))
Rich Kressly has a reputation beyond reputeRich Kressly has a reputation beyond reputeRich Kressly has a reputation beyond reputeRich Kressly has a reputation beyond reputeRich Kressly has a reputation beyond reputeRich Kressly has a reputation beyond reputeRich Kressly has a reputation beyond reputeRich Kressly has a reputation beyond reputeRich Kressly has a reputation beyond reputeRich Kressly has a reputation beyond reputeRich Kressly has a reputation beyond repute
we had the same issue
some Aluminum skids with 1/16 polycarb extended under/around the chain did the trick. I'll see if we have a good pic somewhere
technology, innovation, and invention without a social conscience will only allow us to destroy ourselves in more creative ways
Unread 21-01-2010, 01:45
dtengineering's Avatar
AKA: Jason Brett
Gates is donating sprockets and belts this year... a belt in contact with the field would likely be less of a problem.
That said, we'll probably stick with good ol' #35 chain... we're familiar with it, and the sprockets are easily accessible.
Jason
Unread 21-01-2010, 02:07
Chris is me's Avatar
AKA: Pinecone
There are some advantages to a belt drive. While you have to calculate exact distances, it never stretches, so you don't have to break and tension it ever. The ability for it to touch the floor, with some traction, may be beneficial for some, though I'd recommend for most people you try to ensure noncontact unless you know what you're doing...
Unread 21-01-2010, 02:09
R.C.'s Avatar
R.C. R.C. is offline
2017... Oooh Kill em, Swerve!
FRC #1323 (MadTown Robotics)
Chris,
Even if you do exact Center to Center distances. It would be a smart move to build/design in a way to tension them. Better to be safe than sorry.
-RC
R.C.
MadTown Robotics Team 1323
Unread 21-01-2010, 02:54
AKA: Pinecone
Originally Posted by R.C. View Post
Chris,
-RC
Thanks. I've only played with belting in prototypes and word of mouth, so I'll keep this in mind in the future.
Unread 21-01-2010, 03:38
JeffChan's Avatar
JeffChan JeffChan is offline
FRC #2854 (EVHS Robotics)
JeffChan is on a distinguished road
Send a message via AIM to JeffChan Send a message via MSN to JeffChan
This is a related question.
Consider an aluminum chassis that rubs against the carpet for <1 second as it climbs over the bump. Is that legal? How does <R08> apply?
Team Website
Unread 21-01-2010, 06:03
engunneer's Avatar
Alumni turned Mentor
AKA: Branden Gunn
FRC #4761
IMO, the frame can touch, as long as it is smooth. It's not attempting to gain traction, and it's not a moving part, which is the most likely way to cause damage to the field.
You may want to avoid it anyway, since the touching means your wheels may not be touching any more, and if you take a kit with the weight of your robot on the frame instead of the wheels, you may get a bent frame out of the deal.
The bump before the bump Jeffy Rules/Strategy 2 16-01-2010 07:25
Contacting Chris Jennings whytheheckme Career 1 21-05-2008 11:16
Chain and chain breaker source? kmcclary Off-Season Events 4 22-10-2001 22:51
