Go to Post So my mom gave up most of the house to robotics.... - ElfMaster [more]
Unread 21-01-2010, 06:08
Tanner's Avatar
Tanner Tanner is offline
FRC #1261 (Roblions)
Tanner is a splendid one to beholdTanner is a splendid one to beholdTanner is a splendid one to beholdTanner is a splendid one to beholdTanner is a splendid one to beholdTanner is a splendid one to behold
Re: So i have another problem >.<
From my experience, Joe's answer explains the problem. Otherwise, I don't see anything else that is wrong.
Originally Posted by Joe Ross View Post
One thing to keep in mind is that telop.vi is called 50 times a second by robot main. Thus, 50 times a second you are opening robot drive. If it works at all, I'd expect a lot of error messages in the diagnostics window of the driver station.
If Robot Drive VIs are only going to be used in telop, you could open robot drive in the init case of telop.vi and use feedback to save the device reference. However, this becomes cumbersome if you have a lot of devices, or if you want to access them other places (such as autonomous).
The better thing to do is put your open in begin.vi, and then set the device reference. In telop.vi, you can get the device reference and then use it.
You could open all your motors/joysticks in Teleop.vi, but it gets complicated in just setting that up.
-Tanner
another festo problem Team2883 Pneumatics 4 11-02-2009 20:22
Another IR Board Problem C222 Electrical 2 13-01-2008 17:36
Problem solved but now another question Adam Y. Programming 1 03-05-2006 08:54
Got it working now theres another problem! cdennisxlx2 Programming 11 25-03-2006 21:58
Houston, we have a problem Cauê Fundraising 0 03-03-2005 11:13
