Go to Post Silly, Silly, don't you realize there are no borders in FIRST:) - HW [more]
Unread 16-01-2010, 11:29
joshholat joshholat is offline
FRC #0930
joshholat is an unknown quantity at this point
Deploying code from the 2010 driver station - Netbeans
Team 930 currently has their Classmate PC driver station controlling our robot wirelessly with the bridge. However, we aren't able to actually deploy code from the driver station wirelessly, just run code that was deployed from another laptop and remains on the cRIO. Is it even possible to deploy wirelessly from the driver station, or will it only work with cRIOs that were imaged already? It seems to me as if we should be able to deploy from the classmate PC. Am I right in this assumption?
Unread 17-01-2010, 04:43
jhersh jhersh is offline
National Instruments
AKA: Joe Hershberger
FRC #2468 (Appreciate)
Re: Deploying code from the 2010 driver station - Netbeans
Yes... you should be able to deploy from the classmate. What problem are you having?
Unread 17-01-2010, 10:12
Did you install the updated netbeans plugins on the classmate?
Unread 21-01-2010, 07:04
FRC #0930
Yes, all of the updates were installed on the Netbeans.
Can you deploy wirelessly from the driver station using the router? If so, you'll have to set a static IP on the driver station, correct?
Unread 21-01-2010, 22:45
Yes... you can deploy wirelessly or wired.
Wireless or not has nothing to do with static IP or not. In general, you want your IP address set based on the FRC control system IP addressing scheme, where the middle two octets are your team number.
Unread 23-01-2010, 15:01
FRC #0930
We got it working, thanks guys. We were missing a few updates via the cRIO image, the netbeans plugins, and other stuff.
2010 Driver Station Netbook Driver Account and Java joshholat FRC Control System 2 10-01-2010 15:04
2010 Driver Station Pictures Chadius012 Rumor Mill 4 03-01-2010 14:26
Driver Station 2010 - Netbook? Greg Marra Control System 16 09-07-2009 19:48
using digital inputs from the driver station SL8 NI LabVIEW 2 04-02-2009 15:53
Save code to Driver Station Comatose Programming 5 17-01-2009 18:48
