Go to Post To borrow a slogan from the last place KC Royals "It's Our Time" The curse will be broken! ;) - Alpha Beta [more]
Unread 12-01-2010, 18:18
Jonnadiah's Avatar
Jonnadiah Jonnadiah is offline
Yeah, I remember SME Cards
Jonnadiah is an unknown quantity at this point
2010 Denso WIN motor specs
Hey,
Does anyone have the full specs for this year's Denso WIN motors? We're having a heck of a time finding them.
Thanks in advance.
Unread 12-01-2010, 23:25
bmusser bmusser is offline
Brian Musser
FRC #1504 (Desperate Penguins)
bmusser has a spectacular aura aboutbmusser has a spectacular aura aboutbmusser has a spectacular aura about
Re: 2010 Denso WIN motor specs
I have these specs from 2007.
Unread 20-01-2010, 15:19
DaLolzReaper DaLolzReaper is offline
Kevin Peake
AKA: kevin peake
FRC #0612 (Chantilly Robotics)
DaLolzReaper is an unknown quantity at this point
Hi team 612 is looking for connectors from the Denso motors. We need connectors so that we can attach gears to the motors.
Unread 20-01-2010, 15:43
Dad1279 Dad1279 is offline
FRC #1279 (Cold Fusion)
4 couplers came in the kit this year.
Unread 20-01-2010, 16:31
Teched3 Teched3 is offline
Hodge1
FRC #0175 (BuzzRobotics)
Teched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud of
Smile Re: 2010 Denso WIN motor specs
Here is a link to a spreadsheet for all the FIRST motors in the kit. CIMs are listed first, but you can pull down a menu to select a different motor in B13, and a new curve will appear.
http://www.chiefdelphi.com/media/papers/2320?
Hope this helps.
Sweat the details
Why is there never enough time to do it right, but always enough time to do it again!
Even if you're on the right track, if you sit still, you'll get run over!!!
Unread 21-01-2010, 07:33
Kevin Peake
AKA: kevin peake
Thank you,
We have found the connectors.
Unread 28-01-2010, 09:59
trilogy2826's Avatar
trilogy2826 trilogy2826 is offline
Mentor - 2826
AKA: Jake Fischer
FRC #2826 (Wave Robotics)
trilogy2826 has a reputation beyond reputetrilogy2826 has a reputation beyond reputetrilogy2826 has a reputation beyond reputetrilogy2826 has a reputation beyond reputetrilogy2826 has a reputation beyond reputetrilogy2826 has a reputation beyond reputetrilogy2826 has a reputation beyond reputetrilogy2826 has a reputation beyond reputetrilogy2826 has a reputation beyond reputetrilogy2826 has a reputation beyond reputetrilogy2826 has a reputation beyond repute
Thank you,
Can you help the rest of us out and tell us where you procured the connectors?
Unread 31-01-2010, 19:29
matt 1923's Avatar
matt 1923 matt 1923 is offline
MATT o.O
AKA: Matt Ragana
FRC #1923 (MiDkNiGhT InVeNtErS)
Team Role: Driver
matt 1923 is a glorious beacon of lightmatt 1923 is a glorious beacon of lightmatt 1923 is a glorious beacon of lightmatt 1923 is a glorious beacon of lightmatt 1923 is a glorious beacon of light
Send a message via AIM to matt 1923
please?
Unread 01-02-2010, 07:42
chris janney chris janney is offline
FRC #3266
chris janney is an unknown quantity at this point
hey is anyone else using the denso motors to lift their robot? if so, what gears are you using and where can I get some at?
Unread 07-02-2010, 14:25
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
FRC #0095 (The Grasshoppers)
You might want to think about using a CIM motor to lift, the denso motors are good for 13watts or so while the CIM motor is good for almost 200watts.
Unread 16-02-2010, 23:03
kevinb999 kevinb999 is offline
FRC #2951
kevinb999 is an unknown quantity at this point
Where in the KoP are the connectors? I cannot find them in the check list!
Unread 01-02-2011, 19:53
Lafleur Lafleur is offline
AKA: Tom Lafleur
FRC #0812
Lafleur will become famous soon enoughLafleur will become famous soon enough
2011 Denso WIN motor specs
any one know where to find the connectors for the denso motors?? or the part number?
tom@lafleur.us
Unread 01-02-2011, 20:04
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
I found it elsewhere on this forum. I haven't ordered these myself, so I'm not sure if it is correct. Here is what someone else referenced:
Connector housing - Mouser p/n 829-12129487 - Delphi p/n 12129487
Connector seal - Mouser p/n 829-15300020 - Delphi p/n 15300020
Terminal (14ga) - Mouser p/n 829-12110845 - Delphi p/n 12110845-L
There are several different terminals available, for different wire gauges:
http://connectors.delphi.com/DCSGDMC...=Y&vE xact=0&
2010 Mabuchi Motor Specs.... PhilBot Motors 13 27-01-2010 19:38
Denso motor specs? Mikhail_Pham Motors 3 21-01-2008 07:10
Attaching Denso motor adapter to the motor? Billfred Motors 3 19-02-2007 20:07
Denso motor Lead Gear specs? billbo911 Motors 5 07-02-2006 16:22
Nippon Denso Window Motor Specs RichardBCR Motors 13 26-01-2003 07:01
