Re: Cypress Layout (over wires?)
I'll go through test and correct my chart for the Digital Outputs, as well as, checkout that hidden documentation too.
Once everything calms down a bit maybe I'll have time to go through the various environment-specific documentation. So far I've been pretty much skimming everything. It's hard to confirm that something is "nowhere," only that we can't find it "anywhere," and even that's suspect... ![]() Last edited by Mark McLeod : 21-01-2010 at 11:39. |
My mistake is confirmed. The Digital Outputs were reversed.
In the LabVIEW code the I/O counts begin at 0 not 1, so just be aware that Digital Output 1 is referenced in the code by "0". In C++ the reference matches as 1-8. These labels are how the Driver Station sees them. Here is the corrected chart: Last edited by Mark McLeod : 21-01-2010 at 11:23. |
I'm not sure what LabVIEW code you are referring to. If you mean that the array index is 0 for digital input 1, for instance, then you are correct, but that is simply because the index array primitive in LabVIEW is 0-based. Nothing in the API (compatibility or enhanced) is "0-based". |
The way I read the <R82> rule change in Team Update #4, posted yesterday, it appears that we are no longer required to use the breadboard with the Cypress PSoC 3 FirstTouch Kit I/O module, and we can now use the eStop Cypress Carrier and Enclosure available from AndyMark for more safe and robust mounting and I/O pin access. It would also appear that the Jan. 18 posting by the Game Design Committee on the FIRST Q&A Forum, saying that we can only use the breadboard, is now out of date. Does anyone disagree? (I am hoping to post this question also to the FIRST Q&A Forum through our Team Rules Expert, who has access.)
Please let me know if you read this rule change differently. Many thanks! |
I believe that does obsolete the posting on Q&A.
It does appear that they have drawn a line through
"the breadboard," removing it as a requirement, and refer to "carrier board" now. Clarification via QandA would be important, but the plain English of the reworded rules is what it is. Eugene |
| Cypress board | bls0620 | Electrical | 4 | 17-01-2010 23:22 |
| Cypress Board Configuration | Geek 2.0 | FRC Control System | 12 | 17-01-2010 04:23 |
| Cypress IO board connect | SteveD | FRC Control System | 12 | 16-01-2010 16:46 |
| Cypress soc? | sp33chy | FRC Control System | 2 | 15-01-2010 08:58 |
| Legal? Hurdling Over Overpass and Over Lane Divider | 7-11number1 | Rules/Strategy | 11 | 20-01-2008 14:58 |
