Go to Post If we all keep our "secrets" about our robots, the rest of us don't learn as much. - Rick TYler [more]
Unread 21-01-2010, 08:47
dungeonmonkey dungeonmonkey is offline
FRC #2458
dungeonmonkey is an unknown quantity at this point
Question WindRiver 2010 license problems
Since the laptop we recieved is not very good and going to be used on the driver station, we have decided to continue to use the laptop from the past year. when i went to install the software on it, after the operation was succesful, i went to run windriver, set the new directory, and then it came up and said that the license was invalid. I cant figure out why. please help!
Unread 21-01-2010, 11:45
byteit101's Avatar
WPILib maintainer (WPI)
AKA: Patrick Plenefisch
Re: WindRiver 2010 license problems
Did you put in the new activation file? when you open the installer, the 2nd (i think) has a radio option, use current activation or enter new activation (or something like that). select the new activation, and browse for the key (D:\distributions\windriver\FRC_install_key_or_som ething_of_that_sort.txt). Hit next, select Custom, Next, check all boxes, Install, and finish the installer
Watchdog.Kill();
Unread 21-01-2010, 16:04
FRC #2458
thanks. that helped alot. they kinda stuck that in there at the bottom, didn't they
Windriver 2010 Installation Windows SDK function Error Captain Fink C/C++ 1 01-06-2010 13:52
WindRiver license expiring in 1 day SuperBK C/C++ 3 17-01-2010 12:00
[FTC]: RobotC License Terms - Only good through May 1, 2010 charrisTTI FIRST Tech Challenge 1 16-10-2009 21:01
Control Mapping problems in WindRiver ExarKun666 C/C++ 1 02-02-2009 23:33
WindRiver WPILib problems Dr Nick C/C++ 5 13-01-2009 16:17
