Go to Post The longer you play robots, the more you realize that it's not about the robots. - dtengineering [more]
Unread 21-01-2010, 06:40
JMR15RTC JMR15RTC is offline
FRC #2534
JMR15RTC is an unknown quantity at this point
Clutches
Does anyone know if it is legal to use pneumatic or 12 volt clutches?
Thanks!
Unread 21-01-2010, 07:13
RRLedford RRLedford is offline
FTC 3507 Robo Theosis -- FRC 3135
AKA: Dick Ledford
FRC #3135 (Robotic Colonels)
RRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond repute
Re: Clutches
These items are legal as long as they are readily available to all other teams ("common off the shelf" items), do not require violating pneumatic rules (safety rated to 125PSI & operate OK at under 60 PSI max) or voltage limit (no 24V units), and meet perhaps the biggest challenge (especially for the HIGHER TORQUE units) of not exceeding the budgetary co$t limit$!!
-RRLedford
Unread 21-01-2010, 07:57
AJ R's Avatar
AJ R AJ R is offline
RoboGeek
FRC #1714 (More Robotics)
AJ R is a splendid one to beholdAJ R is a splendid one to beholdAJ R is a splendid one to beholdAJ R is a splendid one to beholdAJ R is a splendid one to beholdAJ R is a splendid one to beholdAJ R is a splendid one to behold
Re: Clutches
Electric clutches are electric solenoids, and are prohibited by rule R53.
<R53> Items specifically PROHIBITED from use on the ROBOT include:
A. Electric motors and/or servos different from, or in addition to, those in the KOP, with the exception of those specifically permitted by Rule <R52>.
B. Electric solenoid actuators (note: electric solenoid actuators are NOT the same as pneumatic solenoid valves – the latter are permitted, the former are not).
AJ
If you loose the match and the robot doesn't come back broken, you didn't drive hard enough.
Unread 21-01-2010, 07:58
Re: Clutches
JMR,
The electric clutches have been deemed electric solenoids in the past and as such are not allowed on the robot. Certain eddy current devices have been used in the past as there is no parts that are pulled together as in the operation of the solenoids. Any device of this type requires a closer inspection by the lead inspector and some consultation. My suggestion is to ask the Q&A stating the model you are considering.
Unread 21-01-2010, 08:24
AKA: Dick Ledford
Re: Clutches
Being a rookie I did not catch the <R53> prohibition of electro-MAGNETIC solenoids for linear motion. Too bad, since they are so useful for applying a strong, short-travel force from a small package at a cheap price. I wonder what the concern is about them to prohibit their use? They are integrated into virtually all machines, appliances, etc.
-RRLedford
Unread 21-01-2010, 09:16
jgannon's Avatar
jgannon jgannon is offline
I ᐸ3 Robots
AKA: Joey Gannon
jgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond repute
Re: Clutches
This is pure speculation, but I've always assumed that it was related to this clause from <R54>: "So that the maximum power level of every ROBOT is the same". I can envision converting the linear motion of a large, powerful solenoid into rotary motion, and consequently circumventing the motor rules.
Team 1743 - The Short Circuits
2010 Pittsburgh Excellence in Design & Team Spirit Awards
2009 Pittsburgh Regional Champions (thanks to 222 and 1218)
2007 Pittsburgh Website Award
2006 Pittsburgh Regional Champions (thanks to 395 and 1038)
2006 Pittsburgh Rookie Inspiration & Highest Rookie Seed
Team 1388 - Eagle Robotics
2005 Sacramento Engineering Inspiration
2004 Curie Division Champions (thanks to 1038 and 175)
2004 Sacramento Rookie All-Star
_
Unread 21-01-2010, 11:07
Re: Clutches
Dick,
It is something I have discussed as a change for several years. Among other concerns, their use under our conditions can cause significant electrical loads that are not currently addressed. As the only relay we have at our disposal is a 20 amp device and contains no inductive kick protection, that also may enter into the decision. I would think that a 10-15 amp load restriction would cover that concern and the Spike is certainly capable of driving a single solenoid load with a snubber diode without self destruction. Maybe in the future.
Clutches jbbjjbt FIRST Tech Challenge 10 01-02-2007 15:21
Vex Clutches Now Available... JVN FIRST Tech Challenge 0 18-01-2006 11:30
Clutches Andrew Blair Technical Discussion 10 01-08-2005 23:31
Drill Motor Clutches kacz100 Motors 9 01-02-2002 01:01
