Go to Post Paper is not so bad. It is really rare for it to crash or run out of battery, for example... - DonRotolo [more]
Unread 21-01-2010, 09:23
lostkhaos lostkhaos is offline
FRC #1307
lostkhaos is an unknown quantity at this point
Festo Solenoid
Our team can't seem to get the new Festo solenoid to open/close. We're using LabView and are using the Solenoid Bumper. We tried different channels and swapping the wires. Also, any ideas what the blue switches at top do? We figured they were for manual override, but they don't appear to do anything. Thanks in advance!
Unread 21-01-2010, 09:27
Jones571's Avatar
Jones571 Jones571 is offline
AKA: Corey
FRC #0571 (Paragon)
Jones571 has much to be proud ofJones571 has much to be proud ofJones571 has much to be proud ofJones571 has much to be proud ofJones571 has much to be proud ofJones571 has much to be proud ofJones571 has much to be proud ofJones571 has much to be proud ofJones571 has much to be proud of
Send a message via AIM to Jones571
Re: Festo Solenoid
I'm not electrical so I hope some one better comes along to help but is it wired correctly as the new festo's in the KOP this year are 24v not 12v.
Unread 21-01-2010, 09:33
FRC #1307
Re: Festo Solenoid
Yes, the light on the solenoid turns on when the solenoid is supposed to be open and the light turns off when the solenoid is supposed to be closed.
Unread 21-01-2010, 09:42
Jones571's Avatar
AKA: Corey
FRC #0571 (Paragon)
Re: Festo Solenoid
If it is set and wired like mark described in post #3 I would think it is a bad unit... http://www.chiefdelphi.com/forums/sh...ad.php?t=80740
Unread 21-01-2010, 10:04
FRC #1307
Re: Festo Solenoid
Oh, I re-read that and discovered we were in fact not giving it the full 24V. Thanks so much it's working now!
Unread 21-01-2010, 10:15
Jones571's Avatar
AKA: Corey
FRC #0571 (Paragon)
Re: Festo Solenoid
Glad I could help and it was a quick fix... I wish all the problems that came up during build were like this
Festo Solenoid Doesn't Work frank.pendzich Pneumatics 20 11-02-2009 20:33
Wiring for FESTO solenoid S Godez Pneumatics 1 09-02-2009 13:02
Festo Single solenoid JP_1163 Pneumatics 4 24-02-2006 15:07
Festo solenoid wiring? computhief263 Pneumatics 1 15-02-2004 12:25
festo solenoid maxgebhardt Pneumatics 19 21-01-2004 23:06
