Go to Post Wow, what a regional at St. Louis! ... It's gonna be a good year for FIRST. - Andy Baker [more]
Unread 20-01-2010, 18:07
ellisk ellisk is offline
FRC #1540
ellisk is on a distinguished road
New Jaguars on CAN bus
I'm trying to get the code for the new Jaguars to compile in C++ using Windriver. Here is my setup and the errors I'm getting:
I got the sources for the CAN jaguar code off of http://firstforge.wpi.edu/sf/frs/do/...r_c_revision_6
I then imported the files "CANJaguar.cpp", "can_proto.h", "CANJaguar.h", and "JaguarCANDriver.h" into my project. In the file which I wanted to use the new Jaguars, I put:
#include "CANJaguar.h"
When I compiled my new project, I got a ton of compiler errors. They were:
In file included from C:/windriver/workspace/Spy/CANJaguar.cpp:3:
C:/WindRiver/vxworks-6.3/target/h/WPILib/ChipObject/NiRioStatus.h:13: error: `tNIRIO_i32' does not name a type
C:/WindRiver/vxworks-6.3/target/h/WPILib/ChipObject/NiRioStatus.h:16: error: `tRioStatusCode' does not name a type
C:/WindRiver/vxworks-6.3/target/h/WPILib/ChipObject/NiRioStatus.h:19: error: `tRioStatusCode' does not name a type
C:/WindRiver/vxworks-6.3/target/h/WPILib/ChipObject/NiRioStatus.h:28: error: `tRioStatusCode' does not name a type
C:/WindRiver/vxworks-6.3/target/h/WPILib/ChipObject/NiRioStatus.h:35: error: `tRioStatusCode' does not name a type
C:/WindRiver/vxworks-6.3/target/h/WPILib/ChipObject/NiRioStatus.h:38: error: `tRioStatusCode' does not name a type
C:/WindRiver/vxworks-6.3/target/h/WPILib/ChipObject/NiRioStatus.h:47: error: `tRioStatusCode' does not name a type
C:/WindRiver/vxworks-6.3/target/h/WPILib/ChipObject/NiRioStatus.h:50: error: `tRioStatusCode' does not name a type
C:/WindRiver/vxworks-6.3/target/h/WPILib/ChipObject/NiRioStatus.h:53: error: `tRioStatusCode' does not name a type
C:/WindRiver/vxworks-6.3/target/h/WPILib/ChipObject/NiRioStatus.h:56: error: `tRioStatusCode' does not name a type
C:/WindRiver/vxworks-6.3/target/h/WPILib/ChipObject/NiRioStatus.h:64: error: `tRioStatusCode' does not name a type
C:/WindRiver/vxworks-6.3/target/h/WPILib/ChipObject/NiRioStatus.h:67: error: `tRioStatusCode' does not name a type
C:/WindRiver/vxworks-6.3/target/h/WPILib/ChipObject/NiRioStatus.h:70: error: `tRioStatusCode' does not name a type
C:/WindRiver/vxworks-6.3/target/h/WPILib/ChipObject/NiRioStatus.h:74: error: `tRioStatusCode' does not name a type
C:/WindRiver/vxworks-6.3/target/h/WPILib/ChipObject/NiRioStatus.h:78: error: `tRioStatusCode' does not name a type
C:/WindRiver/vxworks-6.3/target/h/WPILib/ChipObject/NiRioStatus.h:84: error: `tRioStatusCode' does not name a type
C:/WindRiver/vxworks-6.3/target/h/WPILib/ChipObject/NiRioStatus.h:87: error: `tRioStatusCode' does not name a type
C:/WindRiver/vxworks-6.3/target/h/WPILib/ChipObject/NiRioStatus.h:90: error: `tRioStatusCode' does not name a type
C:/WindRiver/vxworks-6.3/target/h/WPILib/ChipObject/NiRioStatus.h:98: error: `tRioStatusCode' does not name a type
C:/WindRiver/vxworks-6.3/target/h/WPILib/ChipObject/NiRioStatus.h:101: error: `tRioStatusCode' does not name a type
C:/WindRiver/vxworks-6.3/target/h/WPILib/ChipObject/NiRioStatus.h:104: error: `tRioStatusCode' does not name a type
C:/WindRiver/vxworks-6.3/target/h/WPILib/ChipObject/NiRioStatus.h:107: error: `tRioStatusCode' does not name a type
C:/WindRiver/vxworks-6.3/target/h/WPILib/ChipObject/NiRioStatus.h:110: error: `tRioStatusCode' does not name a type
C:/WindRiver/vxworks-6.3/target/h/WPILib/ChipObject/NiRioStatus.h:117: error: `tRioStatusCode' does not name a type
C:/WindRiver/vxworks-6.3/target/h/WPILib/ChipObject/NiRioStatus.h:120: error: `tRioStatusCode' does not name a type
C:/WindRiver/vxworks-6.3/target/h/WPILib/ChipObject/NiRioStatus.h:123: error: `tRioStatusCode' does not name a type
C:/WindRiver/vxworks-6.3/target/h/WPILib/ChipObject/NiRioStatus.h:130: error: `tRioStatusCode' does not name a type
C:/WindRiver/vxworks-6.3/target/h/WPILib/ChipObject/NiRioStatus.h:133: error: `tRioStatusCode' does not name a type
C:/WindRiver/vxworks-6.3/target/h/WPILib/ChipObject/NiRioStatus.h:136: error: `tRioStatusCode' does not name a type
C:/WindRiver/vxworks-6.3/target/h/WPILib/ChipObject/NiRioStatus.h:143: error: `tRioStatusCode' does not name a type
C:/WindRiver/vxworks-6.3/target/h/WPILib/ChipObject/NiRioStatus.h:146: error: `tRioStatusCode' does not name a type
C:/WindRiver/vxworks-6.3/target/h/WPILib/ChipObject/NiRioStatus.h:149: error: `tRioStatusCode' does not name a type
C:/WindRiver/vxworks-6.3/target/h/WPILib/ChipObject/NiRioStatus.h:152: error: `tRioStatusCode' does not name a type
C:/WindRiver/vxworks-6.3/target/h/WPILib/ChipObject/NiRioStatus.h:162: error: `tRioStatusCode' does not name a type
C:/WindRiver/vxworks-6.3/target/h/WPILib/ChipObject/NiRioStatus.h:165: error: `tRioStatusCode' does not name a type
C:/WindRiver/vxworks-6.3/target/h/WPILib/ChipObject/NiRioStatus.h:168: error: `tRioStatusCode' does not name a type
C:/WindRiver/vxworks-6.3/target/h/WPILib/ChipObject/NiRioStatus.h:171: error: `tRioStatusCode' does not name a type
C:/WindRiver/vxworks-6.3/target/h/WPILib/ChipObject/NiRioStatus.h:174: error: `tRioStatusCode' does not name a type
C:/WindRiver/vxworks-6.3/target/h/WPILib/ChipObject/NiRioStatus.h:177: error: `tRioStatusCode' does not name a type
C:/WindRiver/vxworks-6.3/target/h/WPILib/ChipObject/NiRioStatus.h:180: error: `tRioStatusCode' does not name a type
C:/WindRiver/vxworks-6.3/target/h/WPILib/ChipObject/NiRioStatus.h:183: error: `tRioStatusCode' does not name a type
C:/WindRiver/vxworks-6.3/target/h/WPILib/ChipObject/NiRioStatus.h:186: error: `tRioStatusCode' does not name a type
C:/WindRiver/vxworks-6.3/target/h/WPILib/ChipObject/NiRioStatus.h:189: error: `tRioStatusCode' does not name a type
C:/WindRiver/vxworks-6.3/target/h/WPILib/ChipObject/NiRioStatus.h:192: error: `tRioStatusCode' does not name a type
C:/WindRiver/vxworks-6.3/target/h/WPILib/ChipObject/NiRioStatus.h:195: error: `tRioStatusCode' does not name a type
C:/WindRiver/vxworks-6.3/target/h/WPILib/ChipObject/NiRioStatus.h:198: error: `tRioStatusCode' does not name a type
C:/WindRiver/vxworks-6.3/target/h/WPILib/ChipObject/NiRioStatus.h:206: error: `tRioStatusCode' does not name a type
C:/WindRiver/vxworks-6.3/target/h/WPILib/ChipObject/NiRioStatus.h:209: error: `tRioStatusCode' does not name a type
C:/WindRiver/vxworks-6.3/target/h/WPILib/ChipObject/NiRioStatus.h:212: error: `tRioStatusCode' does not name a type
C:/WindRiver/vxworks-6.3/target/h/WPILib/ChipObject/NiRioStatus.h:215: error: `tRioStatusCode' does not name a type
C:/WindRiver/vxworks-6.3/target/h/WPILib/ChipObject/NiRioStatus.h:218: error: `tRioStatusCode' does not name a type
C:/WindRiver/vxworks-6.3/target/h/WPILib/ChipObject/NiRioStatus.h:221: error: `tRioStatusCode' does not name a type
C:/WindRiver/vxworks-6.3/target/h/WPILib/ChipObject/NiRioStatus.h:224: error: `tRioStatusCode' does not name a type
C:/WindRiver/vxworks-6.3/target/h/WPILib/ChipObject/NiRioStatus.h:227: error: `tRioStatusCode' does not name a type
C:/WindRiver/vxworks-6.3/target/h/WPILib/ChipObject/NiRioStatus.h:230: error: `tRioStatusCode' does not name a type
C:/WindRiver/vxworks-6.3/target/h/WPILib/ChipObject/NiRioStatus.h:233: error: `tRioStatusCode' does not name a type
C:/WindRiver/vxworks-6.3/target/h/WPILib/ChipObject/NiRioStatus.h:236: error: `tRioStatusCode' does not name a type
C:/WindRiver/vxworks-6.3/target/h/WPILib/ChipObject/NiRioStatus.h:239: error: `tRioStatusCode' does not name a type
C:/WindRiver/vxworks-6.3/target/h/WPILib/ChipObject/NiRioStatus.h:242: error: `tRioStatusCode' does not name a type
C:/WindRiver/vxworks-6.3/target/h/WPILib/ChipObject/NiRioStatus.h:245: error: `tRioStatusCode' does not name a type
C:/WindRiver/vxworks-6.3/target/h/WPILib/ChipObject/NiRioStatus.h:248: error: `tRioStatusCode' does not name a type
C:/WindRiver/vxworks-6.3/target/h/WPILib/ChipObject/NiRioStatus.h:251: error: `tRioStatusCode' does not name a type
C:/WindRiver/vxworks-6.3/target/h/WPILib/ChipObject/NiRioStatus.h:258: error: `tRioStatusCode' does not name a type
C:/WindRiver/vxworks-6.3/target/h/WPILib/ChipObject/NiRioStatus.h:261: error: `tRioStatusCode' does not name a type
C:/WindRiver/vxworks-6.3/target/h/WPILib/ChipObject/NiRioStatus.h:264: error: `tRioStatusCode' does not name a type
C:/WindRiver/vxworks-6.3/target/h/WPILib/ChipObject/NiRioStatus.h:267: error: `tRioStatusCode' does not name a type
C:/WindRiver/vxworks-6.3/target/h/WPILib/ChipObject/NiRioStatus.h:270: error: `tRioStatusCode' does not name a type
C:/WindRiver/vxworks-6.3/target/h/WPILib/ChipObject/NiRioStatus.h:277: error: `tRioStatusCode' does not name a type
C:/WindRiver/vxworks-6.3/target/h/WPILib/ChipObject/NiRioStatus.h:280: error: `tRioStatusCode' does not name a type
C:/WindRiver/vxworks-6.3/target/h/WPILib/ChipObject/NiRioStatus.h:287: error: `tRioStatusCode' does not name a type
C:/WindRiver/vxworks-6.3/target/h/WPILib/ChipObject/NiRioStatus.h:293: error: expected `,' or `...' before "status"
C:/WindRiver/vxworks-6.3/target/h/WPILib/ChipObject/NiRioStatus.h:294: error: ISO C++ forbids declaration of `tRioStatusCode' with no type
C:/WindRiver/vxworks-6.3/target/h/WPILib/ChipObject/NiRioStatus.h: In function `bool rioStatusIsFatal(int)':
C:/WindRiver/vxworks-6.3/target/h/WPILib/ChipObject/NiRioStatus.h:295: error: `status' undeclared (first use this function)
C:/WindRiver/vxworks-6.3/target/h/WPILib/ChipObject/NiRioStatus.h:295: error: (Each undeclared identifier is reported only once for each function it appears in.)
C:/WindRiver/vxworks-6.3/target/h/WPILib/ChipObject/NiRioStatus.h: At global scope:
C:/WindRiver/vxworks-6.3/target/h/WPILib/ChipObject/NiRioStatus.h:298: error: expected `,' or `...' before "status"
C:/WindRiver/vxworks-6.3/target/h/WPILib/ChipObject/NiRioStatus.h:299: error: ISO C++ forbids declaration of `tRioStatusCode' with no type
C:/WindRiver/vxworks-6.3/target/h/WPILib/ChipObject/NiRioStatus.h: In function `bool rioStatusIsNotFatal(int)':
C:/WindRiver/vxworks-6.3/target/h/WPILib/ChipObject/NiRioStatus.h:300: error: `status' undeclared (first use this function)
C:/WindRiver/vxworks-6.3/target/h/WPILib/ChipObject/NiRioStatus.h:306: error: expected `,' or `...' before "newStatus"
C:/WindRiver/vxworks-6.3/target/h/WPILib/ChipObject/NiRioStatus.h:307: error: ISO C++ forbids declaration of `tRioStatusCode' with no type
C:/WindRiver/vxworks-6.3/target/h/WPILib/ChipObject/NiRioStatus.h: In function `T& rioSetStatus(T&, int)':
C:/WindRiver/vxworks-6.3/target/h/WPILib/ChipObject/NiRioStatus.h:308: error: `newStatus' undeclared (first use this function)
C:/windriver/workspace/Spy/CANJaguar.cpp: In member function `void CANJaguar::InitJaguar()':
C:/windriver/workspace/Spy/CANJaguar.cpp:31: error: `kRIOStatusVersionMismatch' undeclared (first use this function)
C:\WindRiver\vxworks-6.3\host\x86-win32\bin\make.exe: *** [SimpleTemplate_partialImage/Debug/Objects/Spy/CANJaguar.o] Error 1
Build Failed in Project 'Spy' (Process Exit Value was 2):   2010-01-20 14:45:55   (Elapsed Time: 00:01)
Does anyone know what's wrong?
Thanks.
Unread 20-01-2010, 19:16
byteit101's Avatar
WPILib maintainer (WPI)
AKA: Patrick Plenefisch
Re: New Jaguars on CAN bus
modify the include header in CANJaguar.cpp
#include "ChipObject/NiRio.h" <-add this line
#include "ChipObject/NiRioStatus.h"
Watchdog.Kill();
Unread 20-01-2010, 20:47
woodk woodk is offline
FRC #2809
woodk has a spectacular aura aboutwoodk has a spectacular aura aboutwoodk has a spectacular aura about
You beat me to it! You'll also find that it only supports the Voltage control mode. Too bad
Unread 20-01-2010, 21:00
If you install the firmware development package from http://www.luminarymicro.com/products/mdl_bdc.html in the docs folder it has the CAN protocol spec, so you could implement whatever mode you want.
Unread 21-01-2010, 09:53
FRC #2809
Thanks! I figured most of that out by monitoring the communication between BDCOM and the Jaguar, but that doc is much easier!
However, it doesn't include the modifications made in the FRC firmware, which we are required to use. I have managed to get speed control working with the FRC firmware, but they seem to have done something to the current control that I haven't figured out yet.
- Kevin
Serial to CAN Gateway in new Black Jaguars? dmcguire3006 Electrical 54 26-01-2010 07:32
How can we drive on this new floor? sPod General Forum 177 14-01-2009 06:34
Can anyone create new commands? Jakenan Programming 5 22-01-2005 21:38
Where can I find the new C compiler? CompMaster Programming 2 13-01-2005 02:28
