Go to Post I was thinking (dangerous I know) - EricH [more]
Unread 16-01-2010, 12:36
correnos correnos is offline
FRC #2342
correnos is an unknown quantity at this point
Re: Obscure Wind River Workbench Problem
Great. So I have to get a VM running just to download code to the stupid bot?
Does anyone know if there's a c compiler and downloader usable from the command line? Linux compatibility is a definite plus.
Unread 21-01-2010, 10:11
AKA: Brad
#0190 ( Gompei and the Herd)
The point wasn't that you need a VM to do this, the idea was that it works on a cleanly installed computer...
Here is some advice from WindRiver:
I've seen Workbench fail before with this message: "cannot execute command: cmd", this basically means the Windows the customer is running on cannot find cmd.exe in it's path, this is very unusual indeed.
The last time we saw this we made the customer add "%SystemRoot%\system32\" to his path and then run workbench, in this case I'd suggest to alter the path and then re-install from scratch since postinstall might not work in such cases either...
You can update the path variable in the System properties (right click on the computer name in explorer), then properties, then "Advanced" tab. Then "Environment variables", then under the "System variables" area, edit the one called PATH. Make sure that "%SystemRoot%\system32\" is in the list, and if not add it using a semicolon to separate it from the other items in the list.
Since I can't duplicate the problem, I can't know for sure if this will fix your situation.
Brad Miller
Robotics Resource Center
Wind River Printing from cRio Mr.Macdonald C/C++ 6 12-01-2009 20:42
Wind River header issues dpeterson3 C/C++ 6 11-01-2009 18:17
Wind River Help BenB Programming 3 02-01-2009 21:42
Open Wind River excel2474 Programming 12 31-12-2008 17:36
Windriver Workbench Demo Videos neutrino15 Programming 8 27-11-2008 00:06
