#7
Re: No Robot Code
Same issue... and nothing mention in this post is working yet. We are using the same cRio as last year. We tried to re-image the cRio but it gave us an error stating that our IP was not correct.
We are currently trying to re-format the cRio. We put the cRio in safe mode and are currently re-formatting. The cRio has been in the reformating mode for over an hour. Is this normal? Any other advice if this does not work? Thanks in advance! |
| Robot Code? | leftylink | Programming | 0 | 18-02-2008 14:34 |
| Compiling Robot code... | greatman05 | Programming | 5 | 11-02-2008 21:50 |
| Robot Timing Code | robotrobot2 | Programming | 8 | 19-01-2008 14:18 |
| 2006 Robot Code Download | Chris_Elston | Programming | 2 | 05-05-2006 10:42 |
| Default Robot Code | lvhsrobotics | Programming | 2 | 10-01-2003 16:55 |
