Go to Post Also, the judges don't give out awards for money. They give out awards for hard work and effort. - BigJ [more]
Unread 21-01-2010, 12:31
kE7JLM's Avatar
kE7JLM kE7JLM is offline
KE7JLM `
AKA: John Harris
FRC #0842 (Falcon Robotics)
Team Role: Driver
kE7JLM is a name known to allkE7JLM is a name known to allkE7JLM is a name known to allkE7JLM is a name known to allkE7JLM is a name known to allkE7JLM is a name known to all
Send a message via MSN to kE7JLM
Re: Questions about mecanum wheels
What is your wheel config?
Here is the code I've done for off season projects, you may want to add dead zones. This also does not have the power problems -
                if (ws.ButtonState.Two == true)
                    leftmotorcontrol.motors[0].Velocity = -100 * (ws.AccelState.Values.X - ws.AccelState.Values.Y + turn); // front left
                    leftmotorcontrol.motors[1].Velocity = -100 * (ws.AccelState.Values.X + ws.AccelState.Values.Y + turn); // rear left
                    rightmotorcontrol.motors[0].Velocity = 100 *(ws.AccelState.Values.X + ws.AccelState.Values.Y - turn); // front right
                    rightmotorcontrol.motors[1].Velocity = 100 * (ws.AccelState.Values.X - ws.AccelState.Values.Y - turn); // rear right
                else
                    leftmotorcontrol.motors[0].Velocity = 0.00;
                    leftmotorcontrol.motors[1].Velocity = 0.00;
                    rightmotorcontrol.motors[0].Velocity = 0.00;
                    rightmotorcontrol.motors[1].Velocity = 0.00;
The if statement is a safety measure
I was using a wiimote so the "joystick values" (Really i used the accelerometers) gave an output of -1 to 1, you get a 0 - 255?. Its really simple just add up the x,y,z(rotation) and give each wheel the values they need.Diagrams help alot.
Are you using two or one joystick?
Take a look at this thread -
http://www.chiefdelphi.com/forums/sh...hlight=wiimote
PM me if you need more help
Team 842 Programmer
Pictures at:
http://picasaweb.google.com/KE7JLM
http://picasaweb.google.com/john.h.842
Videos -
http://www.youtube.com/user/KE7JLM
When your not busy with FIRST try NURC
Unread 21-01-2010, 12:35
whytheheckme's Avatar
whytheheckme whytheheckme is offline
AKA: Jacob Komar
whytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond repute
Send a message via ICQ to whytheheckme Send a message via AIM to whytheheckme Send a message via MSN to whytheheckme Send a message via Yahoo to whytheheckme
A piece of advice that I'd give is to also use a PID controller. This way you can tweak values to however you'd like them. Also makes for smoother control.
Jacob
need help about Mecanum Wheels mahmosh Technical Discussion 4 18-01-2008 11:50
A few Questions about Omni Wheels.... kSniper Technical Discussion 4 08-01-2008 00:15
Friction coefficients for Omni wheels and Mecanum wheels from AndyMark Andy Baker Technical Discussion 11 16-12-2006 19:40
Mecanum Wheels chaolin2007 Control System 1 25-02-2006 19:16
Mecanum Wheels TheFerret Technical Discussion 8 16-01-2006 09:23
