Go to Post it's not because the kids look up to him that [Dave] gets picked on, it's really because it's just so much fun. - MissInformation [more]
Unread 21-01-2010, 12:03
lollypop2020 lollypop2020 is offline
FRC #2733 (Pigmice)
lollypop2020 is an unknown quantity at this point
Questions about mecanum wheels
My team decided to use mecanum wheels this year, which are currently being assembled, but are not yet on our test robot. Using the advice that has already been posted, our programming team made some code that we think is correct. It wasn't quite as simple as converting xy to polar, we had to make our brains hurt with radian-degree conversions,and angles being shifted 90deg, but the code we have seems to work correctly. Since the wheels aren't actually on the robot yet, we can't see how it moves, but from what I've read about mecanum wheels, the motors are spinning in the correct directions based on the input from the joystick. My only concern is that often times the motors are not going at full speed:
Rotation(which we have on a separate joystick) works fine, pushing it all the way one direction sets -1 or 1 to each side based on which direction we're tuning.
However, for all other situations, the motors are rarely at full power. I have a feeling this is the way the sin and cos functions in holomicdrive.vi inherently are going to work to make sure your speed is consistent in any direction, but I am still worried.
When we push the main joystick full forward, and give the holonomicdrive.vi the equivalent of 1 magnitude, 0 heading, and 0 rotation, the motors all go in the same direction but at about ~70% power. A similar thing happens when we strafe straight sideways, the motors are all going in the correct direction to cancel force vectors for sideways motion, but it is not at 100%.
The only other time any motor ever gets to 100% besides purely rotating, is when we push the joystick into one of its corners. In that case, two motors go to 100%.
We want to get as much power out of our drive system as possible, even if it means the robot will move slower in certain directions. Even just for full forward or backward, I would like to be able to set all the motors to 100% forward without any extra functions.
Is there anything we can do about this? Is this how mecanum wheels are supposed to work? I could always make a button that sets full power to all the wheels, but having it built into the regular control system would be better.
Thanks.
Unread 21-01-2010, 12:31
kE7JLM's Avatar
kE7JLM kE7JLM is offline
KE7JLM `
AKA: John Harris
FRC #0842 (Falcon Robotics)
Team Role: Driver
kE7JLM is a name known to allkE7JLM is a name known to allkE7JLM is a name known to allkE7JLM is a name known to allkE7JLM is a name known to allkE7JLM is a name known to all
Send a message via MSN to kE7JLM
Re: Questions about mecanum wheels
What is your wheel config?
Here is the code I've done for off season projects, you may want to add dead zones. This also does not have the power problems -
                if (ws.ButtonState.Two == true)
                    leftmotorcontrol.motors[0].Velocity = -100 * (ws.AccelState.Values.X - ws.AccelState.Values.Y + turn); // front left
                    leftmotorcontrol.motors[1].Velocity = -100 * (ws.AccelState.Values.X + ws.AccelState.Values.Y + turn); // rear left
                    rightmotorcontrol.motors[0].Velocity = 100 *(ws.AccelState.Values.X + ws.AccelState.Values.Y - turn); // front right
                    rightmotorcontrol.motors[1].Velocity = 100 * (ws.AccelState.Values.X - ws.AccelState.Values.Y - turn); // rear right
                else
                    leftmotorcontrol.motors[0].Velocity = 0.00;
                    leftmotorcontrol.motors[1].Velocity = 0.00;
                    rightmotorcontrol.motors[0].Velocity = 0.00;
                    rightmotorcontrol.motors[1].Velocity = 0.00;
The if statement is a safety measure
I was using a wiimote so the "joystick values" (Really i used the accelerometers) gave an output of -1 to 1, you get a 0 - 255?. Its really simple just add up the x,y,z(rotation) and give each wheel the values they need.Diagrams help alot.
Are you using two or one joystick?
Take a look at this thread -
http://www.chiefdelphi.com/forums/sh...hlight=wiimote
PM me if you need more help
Team 842 Programmer
Pictures at:
http://picasaweb.google.com/KE7JLM
http://picasaweb.google.com/john.h.842
Videos -
http://www.youtube.com/user/KE7JLM
When your not busy with FIRST try NURC
Unread 21-01-2010, 12:35
whytheheckme's Avatar
whytheheckme whytheheckme is offline
AKA: Jacob Komar
whytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond repute
Send a message via ICQ to whytheheckme Send a message via AIM to whytheheckme Send a message via MSN to whytheheckme Send a message via Yahoo to whytheheckme
A piece of advice that I'd give is to also use a PID controller. This way you can tweak values to however you'd like them. Also makes for smoother control.
Jacob
Unread 21-01-2010, 12:38
Racer26 Racer26 is offline
You could always write your own "HolonomicDrive.vi" to make the calculations the way you expect them to be made.
Unread 21-01-2010, 13:01
byteit101's Avatar
WPILib maintainer (WPI)
AKA: Patrick Plenefisch
the WPILib Joystick class has a GetDirectionDegrees and GetDirectionRadians, I'm sure Labview has something similar
Watchdog.Kill();
Unread 21-01-2010, 21:57
Todd's Avatar
Todd Todd is offline
Software Engineer
FRC #1071 (Team Max)
Todd is just really niceTodd is just really niceTodd is just really niceTodd is just really niceTodd is just really nice
Actually it unfortunately doesn't (At least as far as we can tell). We also had to do the conversion from X/Y axis to direction/magnitude.
This is also true and is how the holonomic vi is coded.
If you want to change it so that your motors are running at full power I'd advise making a copy of the holonomic vi and reworking the math inside of it to your liking.
Unread 21-01-2010, 22:51
willson.thomas willson.thomas is offline
FRC #1595
willson.thomas is just really nicewillson.thomas is just really nicewillson.thomas is just really nicewillson.thomas is just really nicewillson.thomas is just really nice
I don't know how you are doing your direction and magnitude calculations but in LabVIEW, we used the ATAN2 function for direction which takes the joystick x and y as inputs. While you still have to do Radian-Degree conversions, I believe this will handle the Quadrant issues for you. Then, for the magnitude, we simply did sqrt(x^2+y^2).
Team Leader
Team 1595
Unread 21-01-2010, 23:06
In LabVIEW, you can also use "Re/Im To Polar Function".
Unread 21-01-2010, 23:30
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
Actually, labview DOES have this function in an easy-to-use VI that can output degrees and magnitude from your joystick direction.
Edit: Doh, Joe beat me to it. That's what I get for leaving the window open while I go out to a machine breakdown
need help about Mecanum Wheels mahmosh Technical Discussion 4 18-01-2008 11:50
A few Questions about Omni Wheels.... kSniper Technical Discussion 4 08-01-2008 00:15
Friction coefficients for Omni wheels and Mecanum wheels from AndyMark Andy Baker Technical Discussion 11 16-12-2006 19:40
Mecanum Wheels chaolin2007 Control System 1 25-02-2006 19:16
Mecanum Wheels TheFerret Technical Discussion 8 16-01-2006 09:23
