Re: cylinder count
Joe,
That first part relates to the only storage can be at 120psi in up to four of the tanks and no where else. Sorry. |
Re: cylinder count
Al, the linked Q&A shows that you can in fact store air in a cylinder on the downstream side of the regulator. You just have to do it after the start of the match. How you do that is up to you. |
Re: cylinder count
I believe there is a typo in that answer. R76B relates only to the high side pressure components.
Re: cylinder count
<R76-A> states that cylinders must be downstream of the regulators. So, under <R76> in general, if you do manage to figure out how to use a cylinder as a storage tank, it has to be downstream of the primary regulator. |
| Do Watermarks Count? | Dorienne | Chairman's Award | 8 | 03-02-2005 16:45 |
| Does it count? | PureMachine4 | General Forum | 1 | 18-03-2003 22:21 |
| Count Limits? | Ephi | Programming | 1 | 04-02-2003 14:25 |
| Post Count | Wetzel | CD Forum Support | 28 | 09-09-2002 11:46 |
| Dave Count... | Quain | Chit-Chat | 48 | 22-05-2002 15:34 |
