Go to Post Once you go hex you'll never go back. - sdcantrell56 [more]
Unread 20-01-2010, 18:00
windell747 windell747 is offline
FRC #2477
windell747 will become famous soon enoughwindell747 will become famous soon enough
cylinder count
Does anyone know if there is a limit to how many storage cylinders we can use on the bot? This is just to reduce the load on the compressor and to keep the recharge times short.
Unread 20-01-2010, 18:02
Re: cylinder count
Yes, there is. <R01-B> specifies no more than 4 of the Clippard tanks; <R72-A> repeats that.
Unread 20-01-2010, 18:03
Matt H. Matt H. is offline
Long Distance Mentor
FRC #1726 (N.E.R.D.S.)
Matt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond repute
Re: cylinder count
Four storage tanks may be used see:
Section 8.3.1 <R01> B
Any number of pneumatic cylinders (with a piston) may be used.
Unread 21-01-2010, 09:35
abross's Avatar
abross abross is offline
FRC #5113 (Combustible Lemons)
abross is on a distinguished road
Re: cylinder count
Is there a limit to how much tubing you can use? Because in theory, you can store air in large coils of tubing. A little impractical if you think about it considering the fact that you would need a lot and it would probably get in the way, but it would be interesting to try.
2009-2010: Storm Robotics 2729 (Student)
2014-****: Combustible Lemons 5113 (Lead Mentor)
Unread 21-01-2010, 09:41
MrForbes's Avatar
AKA: Jim
Re: cylinder count
Did you read the rules?
(it's specifically prohibited)
Unread 21-01-2010, 10:48
Engineer at Medrobotics
AKA: Dr. Joe
FRC #0088 (TJ2)
Re: cylinder count
Suppose you want to increase capacity. Are you allowed to have air cyclinder that act like accumulators? Sorry, for not having the rules ready to hand.
Joe J
Team #88, TJ2
Unread 21-01-2010, 11:26
Re: cylinder count
For starts...
<R01> Energy used by FRC ROBOTS, (i.e., stored at the start of a MATCH), shall come only from the following sources:
A. Electrical energy derived from the onboard 12V battery (see Rule <R40> for specifications and further details).
B. Compressed air stored in the pneumatic system, stored at a maximum pressure of 120 PSI in no more than four Clippard Instruments tanks. Extraneous lengths of pneumatic tubing shall not be used to increase the storage capacity of the air storage system.
C. A change in the altitude of the ROBOT center of gravity.
D. Storage achieved by deformation of ROBOT parts.
Followed by..
R72> In addition to the items included in the KOP, pneumatic system items specifically permitted on 2010 FRC ROBOTS include the following items...
A. One or two additional Clippard air storage tanks (Clippard Part Number AVT-32-16), equivalent to those provided in the kit. This means that up to four, and no more, Clippard air storage tanks can be used on the ROBOT.
And:
<R76> “Working” air pressure on the ROBOT must be no greater than 60psi. All working air must be provided through one primary Norgen adjustable pressure regulator.
A. All “working” pneumatic components (e.g. valves, cylinders, rotary actuators, etc.) must be downstream from this regulator.
B. Only the compressor, relief valve, pressure switch, pressure vent plug valve, pressure gauge, storage tanks, tubing, and connecting fittings may be in the high-pressure pneumatic circuit upstream from the regulator.
Yes Virginia, Inspectors know how much tubing is too much.
Unread 21-01-2010, 11:36
AKA: Dr. Joe
FRC #0088 (TJ2)
Re: cylinder count
For starts...
Followed by..
And:
So if I understand it correctly, then we could use a large gas piston as a sort of accumulator, but only it has to be on the 60psi side of the regulator (not too big a deal, just half the energy). I haven't used pneumatics in years but I suppose that it is a way out if I need a bigger capacity than the 2 Clippards provide (and I have the weight to burn.)
Am I right?
Joe J.
Team #88, TJ2
Unread 21-01-2010, 11:54
Ted Weisse's Avatar
Ted Weisse Ted Weisse is offline
AKA: xMentor/Inspector/Referee
Ted Weisse is a glorious beacon of lightTed Weisse is a glorious beacon of lightTed Weisse is a glorious beacon of lightTed Weisse is a glorious beacon of lightTed Weisse is a glorious beacon of light
Re: cylinder count
Am I right?
Joe J.
A resource that you should take advantage of is the FIRST Q&A. Here is a link to your answer... http://forums.usfirst.org/showthread.php?t=13842
So Yes you may.
ted yz
If I am not for myself, who will be for me?
If I am not for others, what am I?
And if not now, when?
-Rabbi Hillel
Jewish scholar & theologian (30 BC - 9 AD)
Unread 21-01-2010, 11:55
Re: cylinder count
4 Clippards
Unread 21-01-2010, 13:12
Re: cylinder count
Joe,
That first part relates to the only storage can be at 120psi in up to four of the tanks and no where else. Sorry.
Unread 21-01-2010, 13:23
Re: cylinder count
Joe,
Al, the linked Q&A shows that you can in fact store air in a cylinder on the downstream side of the regulator. You just have to do it after the start of the match. How you do that is up to you.
Unread 21-01-2010, 14:11
Re: cylinder count
I believe there is a typo in that answer. R76B relates only to the high side pressure components.
Unread 21-01-2010, 15:36
Re: cylinder count
I don't think so. What the GDC said was that under <R76-B>, any rod-locked cylinders used for storage must be downstream from the primary regulator. <R76-B> calls out what components are allowed to be in the high-pressure side, and states that those are the only ones. I don't see any cylinders in there.
<R76-A> states that cylinders must be downstream of the regulators.
So, under <R76> in general, if you do manage to figure out how to use a cylinder as a storage tank, it has to be downstream of the primary regulator.
Unread 21-01-2010, 15:51
Matt C's Avatar
Matt C Matt C is offline
FRC #1468 (J-Birds)
Matt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond repute
Send a message via AIM to Matt C
Re: cylinder count
Do Watermarks Count? Dorienne Chairman's Award 8 03-02-2005 16:45
Does it count? PureMachine4 General Forum 1 18-03-2003 22:21
Count Limits? Ephi Programming 1 04-02-2003 14:25
Post Count Wetzel CD Forum Support 28 09-09-2002 11:46
Dave Count... Quain Chit-Chat 48 22-05-2002 15:34
