Go to Post Dean Kamen, you deserve a cookie. - Jessica Boucher [more]
Unread 21-01-2010, 14:11
Re: cylinder count
I believe there is a typo in that answer. R76B relates only to the high side pressure components.
Unread 21-01-2010, 15:36
Re: cylinder count
I don't think so. What the GDC said was that under <R76-B>, any rod-locked cylinders used for storage must be downstream from the primary regulator. <R76-B> calls out what components are allowed to be in the high-pressure side, and states that those are the only ones. I don't see any cylinders in there.
<R76-A> states that cylinders must be downstream of the regulators.
So, under <R76> in general, if you do manage to figure out how to use a cylinder as a storage tank, it has to be downstream of the primary regulator.
Do Watermarks Count? Dorienne Chairman's Award 8 03-02-2005 16:45
Does it count? PureMachine4 General Forum 1 18-03-2003 22:21
Count Limits? Ephi Programming 1 04-02-2003 14:25
Post Count Wetzel CD Forum Support 28 09-09-2002 11:46
Dave Count... Quain Chit-Chat 48 22-05-2002 15:34
