Re: Any way to speed up the camera feed fps?
I think he means legal software-wise, not Game-Manual-wise
Yes, legal software-wise. For instance, if the camera is looking to receive a value between 1 and 100 then 200 would not be a legal value. If the code was not written with the proper error checking who knows what would happen. Apparently legal was not the best term to use when dealing with a game with so many rules.I would assume that because the GUI interface for the camera allows a setting between 1 and 100 that the writeCompression function would also use these values. - Bryce Last edited by Bryscus : 21-01-2010 at 15:59. |
our resolution is at the lowest we can get it. I will try Delians idea.
- Bryce |
From posts on other threads, it seem that some teams are using Fast User Switch to run both the developer and driver accounts. Running the tools and the DS in the different accounts seems to have slow screen updates.
A better approach seems to be to run all of the programs under the developer account. Run the dev tool and then run the driver station from the Start menu. Greg McKaskle |
| Speed of the camera | nickmagus | Programming | 86 | 20-02-2009 21:40 |
| Can we use Hot Glue on the robot in any way?? | Leo 1529 | Technical Discussion | 11 | 10-02-2006 17:29 |
| camera panning the oppsite way | TheHolyLancer | Programming | 3 | 04-02-2006 13:53 |
| Any way to see all of the reputation I recieved? | Elgin Clock | CD Forum Support | 8 | 21-07-2004 12:32 |
| Need way to fix power feed on OI | Shu Song | Electrical | 11 | 25-04-2004 15:03 |
