Go to Post Why, yes. I do use Windows, why do you ask? - dtengineering [more]
Unread 21-01-2010, 08:46
Jstack14 Jstack14 is offline
Team Role: CAD
Jstack14 is infamous around these parts
Re: Robot Lifting
After considering all situations that could happen in the last 20-30 seconds when handing will be attempted i came to the conclusion that it is best if 2 robots hang and one continues to score. This is simply because there will be potentially ungarded goals and more then likely 2+ balls in the scoring end, or a ton in the middle. If you have a good kicker it may be best to score even if you could hang. 2 teamates can easily hang off of the tower, any more and you have to hang off eachother. I think this will be a challenge and not all teams will be able to do this quickly. So if two teams hang off the tower and the third scores the team will have 4+(i would guess anywhere from 2-5 points) The other team will have from 6-8 if there whole team hangs. If 2 of the opposing team hangs then its even. If you run through all the senarios and make some assumptions you will see what i am saying. I think, but i may be wrong, that scoring with no deffender will be easy in the last 20-30 seconds (depending on when the enemy has to start hanging) and therfore it will be benifical to build the best kicker you can because if teams realize this they will want you.
Of course if no one builds a hanging bot then this doesn't matter.
My team is focusing on our kicker now and if we finish with time left we will build a hanging mechanism. This will give us time to practce while we build the hanging mechanism and then attach it on in the end if we decide to. I think this strategy will be great because we will then have a ton of driving practice, and the ability to do any task.
Unread 21-01-2010, 09:15
Taylor's Avatar
Taylor Taylor is offline
Professor of Thinkology, ThD
AKA: @taylorstem
FRC #3487 (Red Pride Robotics)
Re: Robot Lifting
Originally Posted by CraigHickman View Post
It would be beneficial for teams to examine alternate lifting methods. Why is everyone so focused on hanging from the horizontal bar, when there are four vertical bars that would work just as well with a smaller, simpler mechanism?
We've looked into a system much like this; the trouble we're having is limiting degrees of freedom while elevating.
Hi!
Unread 21-01-2010, 11:25
Sunshine's Avatar
Sunshine Sunshine is offline
Mr. S
FRC #2062 (C.O.R.E)
Sunshine is a splendid one to beholdSunshine is a splendid one to beholdSunshine is a splendid one to beholdSunshine is a splendid one to beholdSunshine is a splendid one to beholdSunshine is a splendid one to beholdSunshine is a splendid one to beholdSunshine is a splendid one to behold
Re: Robot Lifting
Here is an idea that our team came up with that we believe would work and is outside the norm of lifting a robot that others may not think of. I was extremely proud of all of the ideas that the students generated this year for lifting. Besides this idea, they also came up with a great idea for lifting using the vertical bars. For the record, we are not using either idea. We are using the KISS method (Keep It Simple Students) and believe that we will have a lifting robot that can do the job quickly, efficiently and is simple.
I include this diagram within the spirit of Gracious Professionalism
C.O.R.E. Community Of Robotic Engineers
2015 Wisconsin Regional Champs, Safety Award
2015 Midwest Regional Champs, Safety Award, Industrial Controls Award
2014 Midwest Regional Judges Award
2013 Lake Superior Champs
2012 World Championship Safety Award, World Finalist for the Autodesk Award
2011 Wisconsin Regional - Website Award 10,000 Lakes - Innovation in Control, Safety Award
2010 World Championship - Archimedes Semi-Finalists -World Finalist for the Autodesk Award
2010 10,000 Lakes Regional Champs, Entrepreneurship Award; Wisconsin Regional- Entrepreneurship Award, Safety Award
2009 WI Regional- Quality Award, Safety Award 10,000 Lakes - Safety Award, Motorola Quality Award, Animation Award
2008 World Championship Safety Award
2008 Wisconsin Regional Champs, Safety Award
2008 St. Louis Regional Entrepreneurship Award, Safety Award, Website Award
2007 Wisconsin Regional All-Star Rookie Award
Unread 21-01-2010, 11:43
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Re: Robot Lifting
Neat idea! did anyone calculate the load on the winch? that low angle will make it pretty tough.
Unread 21-01-2010, 13:35
thefro526's Avatar
Mentor for Hire.
AKA: Dustin Benedict
no team (EWCP, MAR, FRC 708)
Re: Robot Lifting
That is a quite awesome idea.
I hope you guys make it work.
-Dustin Benedict
Unread 21-01-2010, 13:56
Jon Stratis's Avatar
Mentor, LRI, MN RPC
FRC #2177 (The Robettes)
Re: Robot Lifting
That's a pretty sweet idea, i have to say.
There are some simple ways to get up the vertical bars (for example, clamp onto it with a wheel on each side, and spin the wheels. They'll naturally tighten onto the bar while they pull you up) - the problem we saw with using them is the amount of precision needed to get your mechanism arranged on the bar. I'm sure some team or teams out there will figure out a great way to take care of the precision problem... but we wanted to keep it simpler and fool proof.
So like many others here, we're going with a winch - it's simple, strong, and automatically locks to prevent being back driven. The innovative, and really cool, part is getting the hook up to the horizontal bar - that part takes under 1 second and needs, at most, a servo (we may be able to get the winch motor to work with it, eliminating the servo) in our prototype. It'd be nice to improve that on the real robot
Unread 21-01-2010, 14:11
Madison's Avatar
Madison Madison is offline
Dancing through life...
FRC #0488 (Xbot)
Re: Robot Lifting
If the point about which your robot rotates up into place is within your FRAME PERIMETER, this does not work. The 3.25" bumpers will project through and below an imaginary plane at 20".
The idea is sound, but the implementation is tricky.
--Madison--
...down at the Ozdust!
Unread 21-01-2010, 14:49
Chris is me's Avatar
AKA: Pinecone
Re: Robot Lifting
I love it. Though I wonder how you get yourself pulled up so your bumpers don't break the plane of the PLATFORM, I guess I'll find out after Wisconsin. Good thinking!
Unread 21-01-2010, 15:23
amitz amitz is offline
amitz is an unknown quantity at this point
Re: Robot Lifting
Has anyone managed to lift 120lbs with a 2.5" CIM Motor & 12.76:1 gearbox (TOUGHBOX)?
By my calculations it should be able to do the job. However, in a test I made, it managed to lift only about 55lbs...
Unread 21-01-2010, 15:26
MrForbes's Avatar
AKA: Jim
Re: Robot Lifting
How did you try to lift with it? did you use a winch to wind up cable? if so, how big is the size of the spool that the cable winds on?
If it is too big diameter you will not have enough leverage.
Unread 21-01-2010, 15:32
Re: Robot Lifting
Yes, I have. the diameter of the spool was 1.5" by what I remember.
Btw, I'm asking if anyone managed to do that in order to be sure whether it's the motor's fault, or mine for not building the mechanism frictionless enough
Unread 21-01-2010, 15:34
AKA: Pinecone
Re: Robot Lifting
You'll need to lift 150 pounds factoring in bumpers and stuff.
I think your reduction is a little low... (i.e. not reduced enough)
Unread 21-01-2010, 15:36
MrForbes's Avatar
AKA: Jim
Re: Robot Lifting
If you have some flat nylon strap you could try winding it on the toughbox output shaft to see if it can lift the weight. You might want to put another bearing on the other end of the shaft to support it though!
Unread 21-01-2010, 15:41
Re: Robot Lifting
That's exactly what I've done when I made that test.
But I did it with a piece of metal with a hole, that the spool goes in it. which may have created unnecessary friction.
Btw, thanks a lot for the quick replies.
Unread 21-01-2010, 16:37
run the trap!!!
Team Role: Human Player
Re: Robot Lifting
Well, in order to lift the robot you'll actually have to accelerate its mass, so you'll need more than 150 lbs. of force.
Also keep in mind that you'll need to calculate the output of the reduction at 1/3 the CIM's stall torque for max power. A CIM at stall will not lift your robot
You could add a chain or compound pulley reduction off of your T-Box to get enough force.
We found that a 70:1 reduction with a 2" dia pulley lifted the robot without tripping the breakers.
-Philip J. Fry
1070's 2007 Robot Lifting AznPrincess3089 Robot Showcase 8 19-03-2007 19:37
Team 192, Robot Lifting Teaser Joobacca Robot Showcase 7 02-02-2007 17:46
Lifting one vs. lifting two jgannon Rules/Strategy 1 14-01-2007 17:37
robot lifting doomsdaytank Rules/Strategy 2 14-01-2003 16:41
Lifting goals patrickrd Rules/Strategy 6 17-01-2002 17:58
