Go to Post The real key to drive team coaching is to tie your jacket around your waist. Got a couple championship rings that way. - TravusCubington [more]
Unread 21-01-2010, 17:13
ahudson ahudson is offline
FRC #3179
ahudson is infamous around these parts
ROOKIE TEAM STUCK!!!!
When trying to configure the IO Module, we can not seem to find the saved hex file needed. We have added every update to everything we can possibly find, but it is still not there.When following the CS Manual we get to p 56 and are stuck. Where it says file path we have a message that says file not found. If anyone knows where we might have went wrong or how to find what we need we would appreciate the help!
Unread 21-01-2010, 17:26
mgurgol mgurgol is offline
FRC #1094
mgurgol is just really nicemgurgol is just really nicemgurgol is just really nicemgurgol is just really nicemgurgol is just really nice
Re: ROOKIE TEAM STUCK!!!!
Have you looked in C:\Documents and Settings\Developer\My Documents\?
I couldn't find mine at first, so I did a search for partial file name of FRC_IO and I found it.
Hope this helps.
Unread 22-01-2010, 21:01
I thought the hex file was installed in the All Users/Documents location. Note this is called different things on different OSes.
Greg McKaskle
Unread 22-01-2010, 22:12
flameout flameout is offline
AKA Ryan Van Why
FRC #0957 (SWARM)
flameout is a name known to allflameout is a name known to allflameout is a name known to allflameout is a name known to allflameout is a name known to allflameout is a name known to all
You may have to re-run the driver station update, uninstall the Cypress component, then re-install it. This worked for us (we also had to do this to the driver station to get the update.)
For us, I believe it was under the All Users document folder.
I hope this helps.
pic: Team 180 S.P.A.M. Stuck in Team 386 Voltage at Tempest N Tampa 2008 volcom248 Extra Discussion 5 29-10-2008 14:03
pic: Team 2520 Best Rookie Team Award Winner team2061 Extra Discussion 4 30-03-2008 15:48
pic: Team 1595 Final Robot Rookie TEAM L@@K!!!! sgsdragons Robot Showcase 4 01-03-2005 16:21
FIRST was an awesome experience for our rookie team (team overview) TheGreatPF General Forum 6 05-04-2004 00:15
TEAM 121 and a rookie team on CBS SAT MORNING! Joe Menassa General Forum 7 21-03-2002 00:47
