Re: Dog Gear?
Isn't there 2 inherent weaknesses in a AM shifter used as a release mechanism given the forces the kicker could be putting on the dog. There is a small 3/32 pin through the dog to connect it to the internal pull shaft. If you use the air cylinder connector, it has a tiny bearing with an smaller roll pin running against it. Last I heard both pins have occasionally broken using 26lbs of pull force with a 3/4 air cylinder. Now I hear people have to use 1.5" air cylinders to trigger a release. Surely those pins are going to break.
Re: Dog Gear?
Re: Dog Gear?
We've never sheared a pin after a few seasons of use; We later switched to bolts (which were actually weaker), and still haven't sheared any. |
Re: Dog Gear?
My team ordered an AM Shifter, Gen1, and we realized that there is no output shaft, but instead, there is an output sprocket. Now, the sprocket faces a lot of resistance to turning. Is there something that we can do to modify that? Should we try and order the supershifter? Or did you guys just use it like it came?
Re: Dog Gear?
We are designing a similar system since we don't have room in our budget for 1 or 2 Super-Shifters. Unfortunately, I am having trouble understanding just one concept about this method of power transmission.
My understanding is that the power source (crankshaft) is connected to the output rod (driveshaft) by a pair of gears. The input gear is rigidly coupled to the crankshaft. The output gear is connected by a bearing to the driveshaft so it can rotate freely if the dog collar is not engaged. The dog collar is coupled to the driveshaft so that it rotates with the shaft, but can move axially to engage or disengage the output gear. First, is my understanding of this system correct? Second, how can a piston push or pull the dog collar as it rotates on the shaft? In other words, I need to undestand the linkage from the piston to the dog collar. Thank you very much in advance for any help you can provide. |
Re: Dog Gear?
This is about as far as we got on our Inventor design yesterday.
![]() The black shaft is driven by the motor/gearbox. The pink spool has bushings which allow it to rotate and slide on the shaft. The light gray pin is pressed into the black shaft, it turns with it. Not shown is the "fork" and it's actuating pneumatic cylinder. The fork fits into the groove at the left end of the spool, and slides the spool along the black shaft to allow the two pins on the end of the spool to engage or disengage the other pin. To wind the winch, the spool is slid by the cylinder/fork to the right to engage the pins, then the motor runs, then stops. The cylinder is energized the other way to disengage the pins, pulling the spool to the left, and allowing the winch to unwind suddenly. This still in the design/fabrication stage, if you see any problems, please let us know! |
#7
Re: Dog Gear?
i cant believe i didnt think of that one! haha
looks good. Only concern that i have is if your going to move the shaft, how to keep the spool in place? and im curious, anywhere that sells doggears that we could use? |
#8
Re: Dog Gear?
You could probably buy the gears from one of their shifting transmissions and make your own housing if you wanted to make a cheap and easy dog gear release system. http://store.andymark.biz/gearssprockets.html |
#9
Re: Dog Gear?
thanks for the links, but we purchased a few shifters from Andy Mark this year...and im not impressed at all...maybe my standards are a bit high(who knows)...we are looking to design our own next year but having trouble finding someone who sells dog gears ![]() |
#10
Re: Dog Gear?
Make your own.
or get some that were made for a motorcycle transmission? might take quite a bit of adapting |
#11
Re: Dog Gear?
Another solution would be to adapt the 2 speed from a 1/5 or 1/8 RC 2 speed transmission. |
#12
Re: Dog Gear?
I'm curious what you're not impressed about? We never buy shifters from AndyMark, but our robots always use a boatload of their products and pretty much everything they sell is a good value compared to us making it ourselves.
#13
Re: Dog Gear?
If you're servo shifting, "well there's your problem". Pneumatic shifting is the way to go. Most complaints I've heard about the gearbox are that they don't shift well enough without pneumatics. |
#14
Re: Dog Gear?
I'm curious too, AndyMark is our first stop for just about any sort of gearing, and we've ran their shifters (pneumatic) on many of our robots with no complaints about reliability.
#15
Re: Dog Gear?
| Hot Dog | Schnabel | Chit-Chat | 41 | 01-10-2006 21:40 |
| Dog Gears | Joe_Widen | Technical Discussion | 4 | 17-05-2006 15:01 |
| Exploding dog | Cody Carey | Chit-Chat | 9 | 16-03-2006 22:33 |
| Help Me Understand Dog Shifting | Crazy | Technical Discussion | 11 | 30-10-2005 10:18 |
