Go to Post Being involved with FIRST is a privilege, not a right. - Katie Reynolds [more]
Unread 21-01-2010, 18:41
Nick Seidl's Avatar
Nick Seidl Nick Seidl is offline
FRC #2867 (ElkLogics)
Nick Seidl is just really niceNick Seidl is just really niceNick Seidl is just really niceNick Seidl is just really nice
Send a message via AIM to Nick Seidl
Thumbs down 2010 Festo Solenoid Problems
We are using the 2010 Festo solenoid valve. We've double/triple checked the wiring, and yes, we got the memo about it being 24v. The plumbing has also been checked. At this point, we only get the light on the valve to blink when fire the cylinder. A clicking noise also occurs. Yet, no air is redirected. We suspect that the solenoid is DOA (as per what has been noted about these solenoids in other threads). Before we mess with trying to replace it, any other ideas on how to make this thing behave itself?
Student on FRC 448: 1999-2003
College Advisor on FRC 461: 2003-2005
College Advisor on FRC 1646: 2005-2007
Coach - Hot Dog Robotics Club (VEX): 2007-2009
Coach on FLL 7939: 2011-12
Teacher/Mentor on FRC 2867: 2009-2011, 2014-Present
Last edited by Greg Needel : 25-01-2010 at 13:23. Reason: To change the title of the thread to be more representative of the intent-
Unread 21-01-2010, 20:29
DonRotolo's Avatar
Back to humble
FRC #0832
Re: Solenoid is teh fail
Are you firing it with air pressure? Make sure it's about 20 PSI or more.
Can you switch it manually? Those little blue buttons do that.
I trust that the plumbing is correct, and the exhaust hole doesn't have a plug in it. One guaranteed way to eliminate this possibility is to remove ALL the lines/connectors/plugs except the air input, then try it.
It is possible you got a bad one, but they are awfully reliable and rarely fail like that.
Got a photo of the plumbing and a drawing of the wiring we can check? (The light coming on is a good sign, wiring is likely correct)
Unread 21-01-2010, 21:42
ayeckley's Avatar
ayeckley ayeckley is offline
AKA: Alex Yeckley
FRC #2252 (Mavericks)
ayeckley has a reputation beyond reputeayeckley has a reputation beyond reputeayeckley has a reputation beyond reputeayeckley has a reputation beyond reputeayeckley has a reputation beyond reputeayeckley has a reputation beyond reputeayeckley has a reputation beyond reputeayeckley has a reputation beyond reputeayeckley has a reputation beyond reputeayeckley has a reputation beyond reputeayeckley has a reputation beyond repute
The "old" style FESTO valves used in 2009 and earlier did appear to have significant reliability issues. In most cases, the descriptions of the failures exactly matched the mode described above. This is the first evidence I've seen of any issue with the "new" style FESTO valves (which more closely resemble the SMC design, at least outwardly). Please report back and let us know if insufficient pilot air pressure was indeed the cause of the problem or not.
Unread 21-01-2010, 21:45
Numbers's Avatar
Numbers Numbers is offline
Cyberdemon
FRC #3238 (Team Red)
Numbers is an unknown quantity at this point
Send a message via MSN to Numbers
Team 3238 also has a defective model. Tried hooking it to the compressor and everything.
Unread 21-01-2010, 21:58
TD912 TD912 is offline
AKA: Chris Leung
FRC #1989 (Viking Robotics)
TD912 has much to be proud ofTD912 has much to be proud ofTD912 has much to be proud ofTD912 has much to be proud ofTD912 has much to be proud ofTD912 has much to be proud ofTD912 has much to be proud ofTD912 has much to be proud ofTD912 has much to be proud ofTD912 has much to be proud of
Same here. Clicking sound and lights up, but no airflow. We're 99% sure everything is connected correctly, including the 12/24v issue.
Hooking up an old SMC solenoid to the same wires works.
Unless there's a simple mistake we're all making...?
Unread 21-01-2010, 22:32
bladetech932's Avatar
bladetech932 bladetech932 is offline
Programmer of awesome
AKA: Jon
FRC #0932 (Circuit Chargers)
bladetech932 is on a distinguished road
make sure you are using the metal solenoid because the plastic ones break so easily,we had 4 defective ones.
Unread 22-01-2010, 09:51
Nick Seidl's Avatar
OK, here is some more information. First, we know that we have 60psi getting to the solenoid. We also realized we did have the plumbing wrong, however fixing this did not resolve the issue. We also took last year's solenoid (which we know works), and tried that instead, and got the same result. At this point we know that its not the solenoid itself that's not behaving. We'll defenestrate our programmer, and I'll report back our solution if we get anything working.
Unread 22-01-2010, 09:59
ayeckley's Avatar
AKA: Alex Yeckley
But the light on the pilot valve is blinking when you energize it, yes? Just one pilot valve at a time, or both? Should only be one...
Unread 22-01-2010, 10:43
Since last year's solenoid is 12v I assume for your test you changed at least the Solenoid Bumper power supply from the cRIO 24v connector to the regular red/black 12v wago connectors on the Power Distribution Panel?
Hard to do a true replacement test without another 24v solenoid.
If the programming is correct the status lights on the cRIO Solenoid Module will light up - no solenoid required for a visual check.
Unread 22-01-2010, 17:17
jsasaki's Avatar
jsasaki jsasaki is offline
AKA: Jun Sasaki
jsasaki has a spectacular aura aboutjsasaki has a spectacular aura aboutjsasaki has a spectacular aura about
Does anyonw have the link to the old smc pneumatic solenoid valves because I look and look on their site and can never find it? Oh and its legal to use those right according to this?
<R72> C. Solenoid valves. All such valves must have a maximum ⅛” NPT port diameter, and a maximum Cv of 0.32 (if non-KOP valves are used, the team will be required to provide part documentation validating that the valves meet these constraints).
Unread 22-01-2010, 18:43
Any of the SMC SY3000 series are under the 2010 rules Cv requirement.
Do not get the SY5000 series. They are all above the legal .32 Cv
Oddly enough the Festos are not rated in Cv, but in something like ml/s. That's not going to be documentable for an inspector.
There are some links posted in other recent solenoid treads, or I'll hunt up some soon. I've got robotics now and a wireless bridge that's DOA.
Unread 22-01-2010, 19:55
DonRotolo's Avatar
Back to humble
FRC #0832
Good, maybe. Again, check those things mentioned in this thread.
Throw him out the window?
Unread 22-01-2010, 20:26
AndrewJS's Avatar
AndrewJS AndrewJS is offline
AndrewJS is an unknown quantity at this point
Just to clarify:
1) The old 2009 festo valve works when manually testing it. It was wired into the 12v power supply (not 24). When testing with the sample program "simple solenoid example," an orange light lit up on it, but it did not actuate. We double checked the wiring and the plumbing to no avail.
2)The 2010 valve was plugged into the 24v power supply. I was absent for most of it's testing and can't say much more.
3) Yes both had 60psi of pressure (sometimes a bit less) going to them via the regulator.
We meet tomorrow at 9am, so we'll test all other possible suggestions/options then. My guess is that it's just defective, but we'll double check as always.
Unread 22-01-2010, 23:33
Joe Finkel Joe Finkel is offline
FRC #0369 (High Voltage)
Joe Finkel has a spectacular aura aboutJoe Finkel has a spectacular aura aboutJoe Finkel has a spectacular aura about
Mark, when you mention the SMC SY3000 solenoid,you probably also meant
that it has to be 24v as well?
Unread 22-01-2010, 23:48
foote stepped in
AKA: E. Foote
FRC #0868
A guy I work with was telling me about one of the supervisors he had many years back. He quoted him as saying - "Gene, don't give me this bull about how you're absolutely sure. You're a goddang engineer, leave yourself some wiggle room. From now on when I ask you your name, you'd better say 'I'm 95% sure it's Gene.'"
Double-Triple check everything again, have an outside person look at it, and when you're 95% sure that its all correct and it still doesn't work, try replacing it.
Chances are if the replacement doesn't work, you shouldn't have been 95% sure.
Best of luck.
Be Healthy. Never Stop Learning. Say It Like It Is. Own It.
Like our values? Flexware Innovation is looking for Automation Engineers. Check us out!
IGES File of teh KOP MachineSMMC Inventor 14 22-01-2009 20:16
Slow down teh motors! brennerator Programming 21 18-01-2007 23:30
RED SOX FOR TEH WIN!!! Heretic121 Chit-Chat 56 28-10-2004 23:00
Opinions of teh TV feed Wetzel Chit-Chat 4 29-04-2002 00:46
teh funnah Zeinin Chit-Chat 1 15-04-2002 15:02
