Go to Post And that's why we all need to consider reserving a "No! Bad robot!" button for the robocoach. :yikes: - vhcook [more]
Unread 21-01-2010, 16:52
Racer26 Racer26 is offline
Can't retract to go under TUNNEL?
http://forums.usfirst.org/showthread.php?t=13940
This Q&A seems to outlaw a ROBOT whose upper extremities collapse into its lower ones for the purposes of going through the TUNNEL. I can't see any good reason for the GDC to say this, nor a particular rule that such a ROBOT would break?
Unread 21-01-2010, 17:04
Jeff Waegelin's Avatar
El Jefe de 148
AKA: Midwest Refugee
FRC #0148 (Robowranglers)
Re: Can't retract to go under TUNNEL?
I was curious about that response, too. I have a sneaking suspicion that the GDC misunderstood the question that was being asked, because it wasn't worded very clearly. Perhaps someone with their team's Q&A access could ask that question again more clearly?
Jeff Waegelin
Unread 21-01-2010, 17:07
EricH EricH is online now
You're about the third one to notice...
My interpretation is that 1) Jeff is right about the wording being unclear and 2) they're asking about expanding the frame perimeter, which is illegal, not pulling a lift system down within the frame perimeter, which is legal.
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
My belief is that the GDC interpreted the question as extension and/or retraction in the length and width dimensions which is not allowed based on the definition of the NORMAL CONFIGURATION.
I see no rule that would prevent extension/retraction in the height dimension.
Last edited by Vikesrock : 21-01-2010 at 17:08. Reason: Oops, totally forgot about <R11>
Unread 21-01-2010, 17:16
Swens's Avatar
Swens Swens is offline
AKA: Robert Swensen
FRC #2892 (Hottie Botties)
Swens can only hope to improve
I think the answer was given as "no" because during the teleoperated period the robot is not allowed to go into any other section of the field besides were it starts.
Unread 21-01-2010, 17:21
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
Can you find a rule to support this hypothesis?
When answering rules questions here on Chief Delphi it is always best to cite and/or quote the rule or definition that led you to your conclusion.
Unread 21-01-2010, 17:42
...Really? Then why all the fuss about invertible robots and designing a "Shremech" as they used to be called on TV's Robot Wars (Self-Righting Mechanism) to right a tipped robot that failed going over the BUMP?
Unread 21-01-2010, 17:46
yoshibrock's Avatar
yoshibrock yoshibrock is offline
Mechanical Magician
AKA: Brock
FRC #0540 (Talon)
yoshibrock will become famous soon enoughyoshibrock will become famous soon enough
Send a message via AIM to yoshibrock
I think you mean during autonomous period, where the robot can't cross the middle line. In teleoperated, I'm pretty sure you can go wherever you want.
There is no charge for awesomeness.
Am I a hero? I really can't say, but yes.
Unread 21-01-2010, 17:48
Jon Stratis's Avatar
Mentor, LRI, MN RPC
FRC #2177 (The Robettes)
With one limitation - you can only have one of your alliances robot in the defensive zone at any given time.
Unread 21-01-2010, 19:11
yoshibrock's Avatar
Mechanical Magician
AKA: Brock
FRC #0540 (Talon)
Aha, that'd be what I was forgetting. Thanks.
Unread 23-01-2010, 01:01
LH Machinist LH Machinist is offline
LH Machinist has a spectacular aura aboutLH Machinist has a spectacular aura aboutLH Machinist has a spectacular aura about
<R10> During the MATCH, the ROBOT will assume one of two operating configurations. When in each configuration, the ROBOT shall fit within the limits of NORMAL CONFIGURATION or FINALE CONFIGURATION
I believe the definition of normal configuration is the reason for "NO"
NORMAL CONFIGURATION – The physical configuration and orientation of the ROBOT when the MATCH is started. This is the state of the ROBOT immediately before being enabled by the Field Management System, before the ROBOT takes any actions, deploys any mechanisms, or moves away from the starting location. This configuration is static, and does not change during a single MATCH (although it may change from MATCH to MATCH).
Unread 23-01-2010, 08:58
johnr johnr is offline
FRC #0910
johnr has a reputation beyond reputejohnr has a reputation beyond reputejohnr has a reputation beyond reputejohnr has a reputation beyond reputejohnr has a reputation beyond reputejohnr has a reputation beyond reputejohnr has a reputation beyond reputejohnr has a reputation beyond reputejohnr has a reputation beyond reputejohnr has a reputation beyond reputejohnr has a reputation beyond repute
Thoughts? You start as a tall bot in auto. At end of auto you drive over, touch pole and shrink down to go through tunnel. At other end of tunnel you expand. Legal or not? I'm going to say yes as long as you never lose contact with tower parts. The amount of time you spend lowering and raising might not be worth it.
Unread 23-01-2010, 09:57
Seems somewhat plausible per <G30>
Starting small in zone 1 or 3 you can extend in zone 2 and cannot contract to go back under a tunnel.
<G30> ROBOT Volume – During a MATCH, no part of the ROBOT shall extend outside the vertical projection of the FRAME PERIMETER, except as follows:
c. TOWER Contact ROBOT Volume - During a MATCH, ROBOTS in contact with their ALLIANCE TOWER may extend beyond their NORMAL CONFIGURATION volume but may not exceed the FINALE CONFIGURATION maximum volume.
Unread 23-01-2010, 11:20
spaztec's Avatar
spaztec spaztec is offline
Electrical Pit Crew
AKA: Luke
FRC #0069 (Hyper)
Team Role: Electrical
spaztec is an unknown quantity at this point
Send a message via AIM to spaztec
true
2007 Boston Regional Champion
2005 California Regional Champion
2005 Connecticut Regional Champion
2004 California Regional Champion
2004 NH Regional Regional Champion
2002 Connecticut Regional Champion
2001 Connecticut Regional Champion
Unread 23-01-2010, 11:49
ahecht's Avatar
ahecht ahecht is offline
'Luzer'
AKA: Zan
That rule prohibits extending outside the VERTICAL PROJECTION of the frame perimeter. In other words, if you extend the frame perimeter up towards the ceiling to make an open box, no part of the robot can extend beyond it. The only thing it says about height is that the robot cannot extend beyond 90 inches while in contact with the tower.
Zan Hecht
Tunnel Blockers??? Team 2811 Rules/Strategy 10 23-01-2010 17:36
Tunnel part of Tower GaryVoshol Rules/Strategy 10 19-01-2010 13:20
Tunnel Height JamesByrne General Forum 3 11-01-2010 17:46
pic: Wind tunnel Pat Major Extra Discussion 20 19-02-2009 19:41
Wind Tunnel Wayne Doenges General Forum 48 21-01-2005 19:22
