Go to Post "Recycle Rush? What's that, some sort of charity marathon?" - Chak [more]
Unread 21-01-2010, 19:12
1708xMr.Roboto's Avatar
1708xMr.Roboto 1708xMr.Roboto is offline
Eddie
AKA: Eddie
FRC #1708 (AMPED Robotics)
Team Role: Driver
1708xMr.Roboto will become famous soon enough
Send a message via AIM to 1708xMr.Roboto Send a message via MSN to 1708xMr.Roboto
pic: Team 1708 Idea #1 rev. A
Unread 21-01-2010, 19:17
yoshibrock's Avatar
yoshibrock yoshibrock is offline
Mechanical Magician
AKA: Brock
FRC #0540 (Talon)
yoshibrock will become famous soon enoughyoshibrock will become famous soon enough
Send a message via AIM to yoshibrock
Re: pic: Team 1708 Idea #1 rev. A
Excellent! I was hoping the revised version of this would be up. First of all, very impressive visually; I love the color scheme. I also like how you tackled the problem of going over the bump. It looks like you won't have any problems with that.
Unfortunately, it looks like your center of gravity will have moved up quite a bit, which may pose a problem with tipping, though that's just from looking at it, so don't take it as a fact.
And one more thing that Im just echoing from the first revision. You want to be careful with that suspension to make sure that if one wheel's springs are compressed and the others are in the normal position, it doesn't throw your chain off.
Other than that, it's an impressive design that looks quite promising. Good luck!
There is no charge for awesomeness.
Am I a hero? I really can't say, but yes.
Unread 21-01-2010, 19:20
gvarndell's Avatar
gvarndell gvarndell is offline
Software Engineer
AKA: Addi's and Georgie's Dad
FRC #1629 (GaCo)
Team Role: Parent
gvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond repute
Just curious -- not commentary and not criticism.
What is the purpose/adavantage of having 6 wheels?
Unread 21-01-2010, 19:24
ttldomination's Avatar
ttldomination ttldomination is online now
Sunny
Very Nice design. . With the background, it's even steallar.
I have a question though, what kinda of shox/springs are those? and what kind of "give" do they provide?
1648: 2013-2014
5283: 2015
Unread 21-01-2010, 19:31
Eddie
AKA: Eddie
Team Role: Driver
They are actually Valve Springs, from a diesel truck motor. A dodge to be exact. They can support about 125 - 145 per. spring, They are about 3 1/2 inches in length, and have about 2inches of give maxx.
Facebook 1 - Chief Delphi 19382193
Unread 21-01-2010, 19:33
Eddie
AKA: Eddie
Team Role: Driver
We are hoping that with a Andy Mark chain tensioner, when the springs sway the springs depress the chain will keep tension.. Thanks for all the great compliments, love the feedback.
Unread 21-01-2010, 19:34
Chris is me's Avatar
AKA: Pinecone
Looking good. My only criticism is that putting shocks on your wheels can mess up the tension of your chain. As the wheels go up and down, the distance from the drive will change, causing chain skipping and throwing potentially.
Unread 21-01-2010, 19:39
Eddie
AKA: Eddie
Team Role: Driver
The purpose of having six wheels (to us atleast) is having the wheels in the front are mainly for the "hump" purpose. The wheels in the back are all for power!
Unread 21-01-2010, 19:40
Eddie
AKA: Eddie
Team Role: Driver
Do you think a longer chain with a tight tensioner is going to work? We are hoping for it too.
Unread 21-01-2010, 19:44
GaryVoshol's Avatar
Cogito ergo arbitro
From the perspective it's hard to tell. If those are 8" wheels, it looks like the top of the angle would be somewhere near 13" off the floor, and thus could be where the center of the bumpers are. This provides a solid attachment point for the bumpers front and rear, but what about the sides? I assume the lowest rail is less than 10" off the ground so the bumpers could not attach there; can they attach to the upper rail on the sides?
(since 2004)
Unread 21-01-2010, 19:48
GUI GUI is offline
AKA: Gary
FRC #4183 (Bit Buckets)
GUI is a splendid one to beholdGUI is a splendid one to beholdGUI is a splendid one to beholdGUI is a splendid one to beholdGUI is a splendid one to beholdGUI is a splendid one to beholdGUI is a splendid one to behold
Send a message via Yahoo to GUI
Have you considered how having all six wheels flat on the ground will affect turning ability? 6wd is very maneuverable when the center wheel is slightly lower than the others (allowing one end to be slightly off the floor when turning), but with a suspenstion I don't see how you could get that affect. You may have already considered this, just trying to help you make sure there aren't any surprises when it gets built d:
Unread 21-01-2010, 19:50
Eddie
AKA: Eddie
Team Role: Driver
It's kind of funny you brought you up, we just talked about that at the meeting we are at right now. The center bar, of the robot will be moved up to provide a full bumper mouting area around the whole robot.
Unread 21-01-2010, 20:06
AKA: Pinecone
Spring loaded tensioner maybe? I've never tried a spring loaded chain tensioner so I have no idea how it would work. Most suspensions I've seen integrate the gearbox into the suspension so they move together, preserving the same relative distance. But that doesn't make sense for 6 wheels and 2 gearboxes.
Unread 22-01-2010, 18:53
Navid Shafa Navid Shafa is offline
FIRST Hiatus/Retired?
Navid Shafa has a reputation beyond reputeNavid Shafa has a reputation beyond reputeNavid Shafa has a reputation beyond reputeNavid Shafa has a reputation beyond reputeNavid Shafa has a reputation beyond reputeNavid Shafa has a reputation beyond reputeNavid Shafa has a reputation beyond reputeNavid Shafa has a reputation beyond reputeNavid Shafa has a reputation beyond reputeNavid Shafa has a reputation beyond reputeNavid Shafa has a reputation beyond repute
A) What size aluminum tubing is that?
B) What's your total weight?
2015 & 2016 Fantasy FIRST Champions [Rotten Fruit Alliance]
Elgin Clock Award Winners: '13, '15, '16
Team 1983 | Alumnus, Former Mentor| Team_ 360 | Former Coach | Team 5803 | Former Mentor
"Once a Skunk, Always a Skunk"
Founding Member
Unread 22-01-2010, 22:24
Eddie
AKA: Eddie
Team Role: Driver
A- One Inch
The team has decided as of today, we are going with the same chassis design but made out of BOSCH 3030 metal.
B- Unknown
pic: (RP) Team 1708 Idea #1 1708xMr.Roboto Extra Discussion 24 27-01-2010 12:01
pic: team 1708 D_Price Extra Discussion 2 06-03-2008 19:37
pic: Team 1708 Teaser robotboy11 Extra Discussion 2 15-02-2008 10:31
pic: Team 1708 Robot! robotboy11 Extra Discussion 3 13-02-2008 21:30
