Go to Post Judging the Championship CA must be the hardest thing to do in FIRST. I'd rather try to stop an alliance of 1114, 111, and 25 from scoring 3 pointers than to judge the CA between these teams. - Andy Baker [more]
  #31   Spotlight this post!
Unread 21-01-2010, 18:18
JohnFogarty's Avatar
AKA: @doctorfogarty
Re: Robot Lifting
Our idea was bungied Dual Telescoping Towers shooting up with crane hooks and a wench system with a cable strong enough to lift an elephant to pull us up and anyone who wants to hang on us.
John Fogarty
Former Student & Mentor FLL 1102, FTC 1102 & FTC 3864, FRC 1772, FRC 5632, FRC 4901
  #32   Spotlight this post!
Unread 21-01-2010, 18:31
Rick Wagner's Avatar
Rick Wagner Rick Wagner is offline
FRC #3008 (Kalani Robotics)
Rick Wagner is a splendid one to beholdRick Wagner is a splendid one to beholdRick Wagner is a splendid one to beholdRick Wagner is a splendid one to beholdRick Wagner is a splendid one to beholdRick Wagner is a splendid one to beholdRick Wagner is a splendid one to behold
Re: Robot Lifting
In '04 several teams used a bent fiberglass rod with a hook on the end and cable dressed to the rod with velcro. Rod is held bent by a servo or small pneumatic cylinder pin-puller. When released it snaps upward as it straightens to the right hight to hook the bar. Winding the winch raises the robot.
  #33   Spotlight this post!
Unread 21-01-2010, 18:45
Brian C's Avatar
Brian C Brian C is offline
Doer of Whatever
AKA: Brian Cholerton
FRC #1468 (J-Birds)
Brian C has a brilliant futureBrian C has a brilliant futureBrian C has a brilliant futureBrian C has a brilliant futureBrian C has a brilliant futureBrian C has a brilliant futureBrian C has a brilliant futureBrian C has a brilliant futureBrian C has a brilliant futureBrian C has a brilliant futureBrian C has a brilliant future
Re: Robot Lifting
Now that brings some interesting designs to mind
2017 Season; Game Announcer at
SBPLI Long Island Regional
  #34   Spotlight this post!
Unread 21-01-2010, 18:56
bobosalad's Avatar
bobosalad bobosalad is offline
FRC #2518 (Spartans of St. Jude)
Team Role: Driver
bobosalad is an unknown quantity at this point
Re: Robot Lifting
Originally Posted by CraigHickman View Post
It would be beneficial for teams to examine alternate lifting methods. Why is everyone so focused on hanging from the horizontal bar, when there are four vertical bars that would work just as well with a smaller, simpler mechanism?
this is the type of thinking we need, it may not work exactly as easy as sounded but this is what makes robotics cool and innovative.
if any teams come up with good ideas and prototype it, leave links for pics or something
  #35   Spotlight this post!
Unread 21-01-2010, 19:43
spiffyspleen's Avatar
spiffyspleen spiffyspleen is offline
FRC #2635
spiffyspleen will become famous soon enoughspiffyspleen will become famous soon enough
Re: Robot Lifting
Does anyone have any alternate ideas that are really compact?
Also, I'd just like to point out that (1) you only really need to extend a little over thirty inches during the finale, cutting time considerably if you can extend to about sixty inches beforehand.
And (2), anytime you touch the tower during the match you can extend to finale proportions. That way a slower lifter could get up ten or fifteen seconds before the twenty second finale and still score. If you're planning on lifting other robots as well, this would give much needed extra time, especially if the first robot could get to the top just as the finale period began.
Thanks for any ideas.
  #36   Spotlight this post!
Unread 21-01-2010, 20:24
CraigHickman
Posts: n/a
Re: Robot Lifting
I'll have my team put some images up here if they're interested in sharing.
(1) assumes you're maxing out your height, and won't be able to drive through the tunnel.
(2) I actually like the idea of a dedicated lifter playing defence and moving to the tower early. It would make for an interesting strategy, with the possibility of points that cannot be defended against, due to the penalties surrounding lifting/hanging.
  #37   Spotlight this post!
Unread 21-01-2010, 20:25
GaryVoshol's Avatar
Cogito ergo arbitro
Re: Robot Lifting
Those penalties only apply during the 20-second FINALE.
(since 2004)
  #38   Spotlight this post!
Unread 21-01-2010, 20:47
CraigHickman
Posts: n/a
Re: Robot Lifting
Yep. So as long as your bot can be in position before the FINALE, and can hang/hang others in less then 20 (or 15, for safety) seconds, you're guaranteed points for each match. Play defense for most, then go hang. Nice and simple, I like it.
  #39   Spotlight this post!
Unread 21-01-2010, 21:07
FrankN FrankN is offline
None #0903
FrankN is an unknown quantity at this point
Re: Robot Lifting
Hi, As I understand the rules the lifting is defined as "above the platform and in contact with the tower". It doesn't say the robot has to hang of the cross tube. So why can't the robot clamp to one of the vertical tower poles and pull itself up. It would not have to reach so far and also would not have to be concerned with the center of gravity wanting it to swing under the tower.
Frank
  #40   Spotlight this post!
Unread 21-01-2010, 21:23
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
Re: Robot Lifting
That is perfectly acceptable if you can design a mechanism that can lock in place without damaging the tower.
  #41   Spotlight this post!
Unread 21-01-2010, 21:29
bobosalad's Avatar
Team Role: Driver
Re: Robot Lifting
Frank
the hardest part of this is obviously attaching to the bar; how would you keep from sliding down the vertical tube?
  #42   Spotlight this post!
Unread 21-01-2010, 21:37
None #0903
Re: Robot Lifting
you have an arm that folds up past the tower, with a pivot above the platform. then you have a cross member at the tip of the arm and that is past the tower pole and a second on that is lower before the tower pole . If you then start retracting ( folding) the arm back it will clamp itself to the towerpol and the weight of the robot will lock it in. to support this function the crossmembers should have rubber surfaces.
  #43   Spotlight this post!
Unread 21-01-2010, 21:50
None #0903
Re: Robot Lifting
Like an adjustable
c-clamp
  #44   Spotlight this post!
Unread 21-01-2010, 22:16
gorrilla's Avatar
gorrilla gorrilla is offline
1557 alumni, 4639 mentor
AKA: adam spears
FRC #4639 (RoboSpartans)
gorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant future
Re: Robot Lifting
Is noone thinking about getting on the platfrom from the bump?
Adam Spears
Team 1557 2007-2011 student-Lake County FL
Current Team 4639 mentor- Houston TX
  #45   Spotlight this post!
Unread 21-01-2010, 22:20
bobosalad's Avatar
Team Role: Driver
Re: Robot Lifting
problem with that is there is a lip from the bump to the tower, and geting centered on the bump isnt going to be easy anyways
1070's 2007 Robot Lifting AznPrincess3089 Robot Showcase 8 19-03-2007 19:37
Team 192, Robot Lifting Teaser Joobacca Robot Showcase 7 02-02-2007 17:46
Lifting one vs. lifting two jgannon Rules/Strategy 1 14-01-2007 17:37
robot lifting doomsdaytank Rules/Strategy 2 14-01-2003 16:41
Lifting goals patrickrd Rules/Strategy 6 17-01-2002 17:58
