Go to Post ...never do something because it is comfortable, do something because you WANT to do it. - Andrew Schreiber [more]
Unread 21-01-2010, 14:08
tanguma26 tanguma26 is offline
FRC #3999
tanguma26 is an unknown quantity at this point
cRio problems
Hey guys I been trying to reimage the cRio but every time I try it saids that the cRio is not found, I all ready have all the updates and the right ip address and still does not work, should the stop button be conected I am using the classmate any help!
Unread 21-01-2010, 20:21
Re: cRio problems
No E-stop button is necessary.
How do you have the Classmate connected to the cRIO? By Ethernet cable?
Or are you using some other PC?
Unread 21-01-2010, 20:30
chsrobotics3283's Avatar
chsrobotics3283 chsrobotics3283 is offline
FRC #3283 (Clarksburg Robotics)
chsrobotics3283 is an unknown quantity at this point
Re: cRio problems
To connect the cRio to the Classmate, you have to use a crossover cable and there is a orange cable included in the kit of parts. Attach in port 1 of the cRIO and to the classmate. Power up the cRIO with a battery (I used a printer adapter at first). Then run Imaging tool and you should be able to pick up the signal if not refer to this:
http://usfirst.org/uploadedFiles/Com...ed-Rev-0.7.pdf
Page: 33-34
And make sure you updated the classmate software and updated everything else including Labview and driver station. Even though this is not the solution to the problem it is required to update everything
Unread 21-01-2010, 20:50
ehochstein's Avatar
ehochstein ehochstein is offline
Coach, Volunteer & Mentor
AKA: Evan Hochstein
FTC #5943 (ESGM)
ehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant future
Re: cRio problems
It tells you to use an IP address something like 10.xx.yy.5 that didn't work for us so we ended up using 10.xx.yy.0
Minnesota FIRST Senior Mentor | 2013-?
Stratasys Applications Engineering Technician | 2016-?
2009 Regional Win – 2470 @ 10k Lakes (Thanks 2826 and 1714)
2013 WFFA Recipient – 2470 @ 10K Lakes
2016 Ri3D: 'Snow Problem Reveal
2017 Ri3D: 'Snow Problem Reveal
The opinions expressed above are the personal opinions of the author and do not necessarily represent the views and opinions of any organization the author is affiliated with.
Unread 21-01-2010, 21:09
Phoenix Spud's Avatar
Phoenix Spud Phoenix Spud is offline
Everyone. Everywhere.
FRC #3132 (Thunder Down Under)
Phoenix Spud has a reputation beyond reputePhoenix Spud has a reputation beyond reputePhoenix Spud has a reputation beyond reputePhoenix Spud has a reputation beyond reputePhoenix Spud has a reputation beyond reputePhoenix Spud has a reputation beyond reputePhoenix Spud has a reputation beyond reputePhoenix Spud has a reputation beyond reputePhoenix Spud has a reputation beyond reputePhoenix Spud has a reputation beyond reputePhoenix Spud has a reputation beyond repute
Re: cRio problems
Our cross-over is pink not orange, I don't know which color your is, but hopefully that helps!
Sarah Heimlich
Outreach Mentor | Business Mentor
FIRST® TEAM 3132
cRio Code problems Aaron V FRC Control System 2 14-01-2010 12:59
Problems Switching to WR & Updating DS,cRIO Burmeister #279 Programming 7 14-12-2009 11:06
Problems reimaging cRIO ravena Technical Discussion 13 17-02-2009 20:19
cRIO update 3.0 problems Two-Face Programming 3 14-02-2009 10:06
cRIO Problems computerboi1503 C/C++ 7 11-01-2009 09:35
