Go to Post A Guru teaching batteries at Exide: "Do not draw your power from up here, by your terminals. You must reach down deep into your plates and pull the energy from your entire being! You must prove yourself worthy to be FIRST power cells!" - KenWittlief [more]
Unread 21-01-2010, 22:11
Phoenix Spud's Avatar
Phoenix Spud Phoenix Spud is offline
Everyone. Everywhere.
FRC #3132 (Thunder Down Under)
Phoenix Spud has a reputation beyond reputePhoenix Spud has a reputation beyond reputePhoenix Spud has a reputation beyond reputePhoenix Spud has a reputation beyond reputePhoenix Spud has a reputation beyond reputePhoenix Spud has a reputation beyond reputePhoenix Spud has a reputation beyond reputePhoenix Spud has a reputation beyond reputePhoenix Spud has a reputation beyond reputePhoenix Spud has a reputation beyond reputePhoenix Spud has a reputation beyond repute
5 amp circuit breakers
We are a little confused as to which circuit breakers we are supposed to use for the digital sidecar and the analog breakout. The rules tell us that we need to use 22 AWG wire, but doesn't say anything about what type of curcuit breaker we should use. We checked on-line, and the max load for 22 AWG wire is 7 amps. According to the wiring diagram, we are supposed to put the wires on the "max 30" amp curcuit breakers. But we found another wiring diagram (In Part 3 of the Controls System Manual) that says we should use a 5 amp circuit breaker. The problem is that this diagram comes with a disclamer "This Diagram may not comply with all FIRST rules." Can someone please help us?
Thank you!
Sarah Heimlich
Outreach Mentor | Business Mentor
FIRST® TEAM 3132
Unread 21-01-2010, 22:23
samir13k samir13k is offline
AKA: Samir Shaikh
FRC #4329
samir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant future
Send a message via AIM to samir13k Send a message via MSN to samir13k
Re: 5 amp circuit breakers
we have used the 20amp self resetting breakers supplied in the kit and had absolutely no problem with them...
Unread 21-01-2010, 22:32
AKA: Samir Shaikh
FRC #4329
***and we passed inspection with this configuration. I believe that is what you are supposed to use. Other breakers are illegal (i think)
Unread 21-01-2010, 22:38
timytamy's Avatar
timytamy timytamy is offline
AKA: Tim
Team Role: Electrical
timytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant future
We understand that this was true in past years but what about this year.
To clarify please go to part 3.13 in this document.
Thanks,
timytamy
Tim W
FIRST® Team 3132 - The Thunder Down Under
Sydney, Australia
Website | Facebook | Youtube
Unread 21-01-2010, 22:46
AKA: Samir Shaikh
FRC #4329
Yes, the document does imply a 22awg wire. But even in the image shown in 3.1.3, they use a 20amp self resetting breaker.
So overall, use a 20amp self resetting breaker provided in the kit. Do not use a standard 5amp breaker. The 20amp breaker is the legal breaker used for this.
Unread 21-01-2010, 22:56
Thank you!
Don't confuse the control system manual with the rules. The control system manual tells you how things can be connected and used, the rules (specifically section 8) tell you how things must be connected for FRC.
<R46C> says that the digital sidecar must be protected by a 20amp breaker. <R47C> says that everything protected by a 20amp breaker must use 18awg wire or larger.
If you were doing this for fun, you could use a 5amp breaker and 22awg wire safely. As you pointed out, it isn't safe to use a 20amp breaker and 22awg wire.
Unread 21-01-2010, 22:59
AKA: Samir Shaikh
FRC #4329
Joe is correct, look at the rulebook first. especially the sections he has quoted above. It is a good idea for your electrical person to print off the few pages with wire gauges and breaker requirements and keep them at his workstation while wiring.
Unread 21-01-2010, 23:03
Thanks everyone! We are about to wire up the board with the 20 AMP circuit breakers and get some more 18 AWG wire. We just got a little confused with the Control Systems manual.
Thanks again!
Sarah Heimlich
FIRST® TEAM 3132
Unread 22-01-2010, 08:11
I have been asking the GDC to add 5 amp circuit breakers to the rules for a few years now. That may have leaked into the Control Systems doc. For now
<R46> All active Power Distribution Board branch circuits shall be protected from overload with an appropriate value auto resetting Snap Action circuit breaker (from the KOP or identical equivalent).
A. Each speed controller branch circuit must be protected by one and only one 20-amp, 30-amp, or 40-amp circuit breaker on the Power Distribution Board. No other electrical load can be connected to the breaker supplying this circuit.
And...
<R47> All active Power Distribution Board branch circuits shall be wired with appropriately sized wire:
A. 12 AWG (2.052mm) or larger diameter wire must be used for all circuits protected by a 40A circuit breaker.
B. 14 AWG (1.628mm) or larger diameter wire must be used for all circuits protected by a 30A circuit breaker.
C. 18 AWG (1.024mm) or larger diameter wire must be used for all circuits protected by a 20A circuit breaker.
D. 20 AWG (0.8128mm) or larger diameter wire must be used for the power connection between the Power Distribution Board and the cRIO-FRC .
E. 20 AWG (0.8128mm) or larger diameter wire must be used for the power connection between the Power Distribution Board and the Linksys Wireless Bridge
F. 20 AWG (0.8128mm) or larger diameter wire must be used for the power connections between the Power Distribution Board and the Analog Breakouts and/or Solenoid Breakout if individual power feeds are used. 18 AWG or larger diameter wire must be used if a common power feed is used for multiple breakouts.
G. 24 AWG (0.5106mm) or larger diameter wire must be used for providing power to pneumatic valves.
Unread 23-01-2010, 22:16
spaztec's Avatar
spaztec spaztec is offline
Electrical Pit Crew
AKA: Luke
FRC #0069 (Hyper)
spaztec is an unknown quantity at this point
Send a message via AIM to spaztec
pretty much...
40 on cims
30 on other motors
20 amp breakers on everything else
2007 Boston Regional Champion
2005 California Regional Champion
2005 Connecticut Regional Champion
2004 California Regional Champion
2004 NH Regional Regional Champion
2002 Connecticut Regional Champion
2001 Connecticut Regional Champion
Unread 24-01-2010, 08:21
Not to confuse you even more, the rules on the breaker size relates to the wire each breaker is feeding. The breaker is a safety to prevent the wires from burning up not to protect the motors. CIM motors will still draw 129 amps at stall no matter the size of the breaker you install.
Unread 24-01-2010, 16:40
Andy A. Andy A. is offline
Getting old
FRC #0095
It may also be helpful for rookies to know that these breakers are thermally sensitive. They will allow current draws in excess of their rating before over heating and tripping. The higher the current draw the faster they will trip, but there is still a finite reaction time. The point is, they are only there to protect the wiring, which can handle brief current excesses, not components, which sometimes can't survive that. Fisher-Price motors have a wonderful ability to fry before the breakers will trip.
When they do reset they are now still quite hot, and will be more apt to trip. After a couple of trips they can be considered de-rated, and should be replaced.
Unread 24-01-2010, 17:41
RyanN's Avatar
RyanN RyanN is offline
RyanN
AKA: Ryan Nazaretian
FRC #4901 (Garnet Squadron)
If you want to just protect your circuitry, like you should, you could add a 5A inline fuse to the circuit for extra protection. Of course, use the 20A breaker as you normally would, but add the fuse for the extra protection. Refer to R46 G for my suggestion.
Garnet Squadron
FRC 4901
Controls Mentor
@rnazaretian
Previous mentor and student from Team Fusion, FRC 364
Circuit breakers? k4r3n2 Electrical 7 28-01-2008 03:36
speed controllers & circuit breakers deuceswild Electrical 2 15-01-2003 14:46
circuit breakers.... archiver 2001 2 23-06-2002 23:58
Circuit breakers archiver 2000 8 23-06-2002 23:30
Circuit Breakers ark_1230 Electrical 28 09-04-2002 23:16
