Go to Post It's up to veteran teams and mentors to help keep the original spirit of FIRST alive. - It's up to us to make these boards exemplify the FIRST principals in every post. - Ben Mitchell [more]
Go Back   Chief Delphi > Technical > Kit & Additional Hardware
Unread 16-01-2010, 10:26
samcorp samcorp is offline
FRC #0486
samcorp can only hope to improve
USB Hub Defective
Our Targus USB Hub that came with the Kit of Parts seems to be defective. Are we allowed to use an outside USB Hub?
Thanks,
Sam
Unread 16-01-2010, 10:31
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
Re: USB Hub Defective
From the manual (emphasis mine)
DRIVER STATION - The collection of the Classmate PC, FirstTouch I/O Module and breadboard provided in the KOP, and a USB hub (either the one provided in the KOP, or a team-supplied USB hub device).
Unread 16-01-2010, 21:02
What seems to be wrong with it?
Ours didn't work properly either, until we plugged the mini-USB connector the rest of the way in. The last half millimeter makes a difference.
Unread 21-01-2010, 22:03
sundancekid92 sundancekid92 is offline
FRC #0056 (ROBBE XTREME)
Team Role: Driver
sundancekid92 has a spectacular aura aboutsundancekid92 has a spectacular aura about
My teams having a similar problem. The Targus Hub light turns on but data does not seem to pass through. (We get no recognition of joysticks or of the e-stop)
Unread 21-01-2010, 22:43
Make sure to use the black USB cable. The red one is power only.
Unread 21-01-2010, 22:48
big1boom big1boom is offline
Chains=Fun
FRC #2022 (Titan Robotics)
big1boom is a glorious beacon of lightbig1boom is a glorious beacon of lightbig1boom is a glorious beacon of lightbig1boom is a glorious beacon of lightbig1boom is a glorious beacon of lightbig1boom is a glorious beacon of light
Also, try booting up the computer with the USB hub/joysticks/e-stop plugged in. We had problems recognizing the joysticks until we just restarted.
Unread 24-01-2010, 21:58
Team Role: Driver
We just got a different hub and its working. I'm just gonna forget about the targus hub :/
Unread 11-02-2010, 11:28
Wiz Wiz is offline
Wiz is infamous around these partsWiz is infamous around these parts
Ours is dead too. It worked for a bit, but now the light comes on but no signal. Tried across multiple computers, PC and Mac.
So is Targus replacing??
Unread 11-02-2010, 11:38
Dave Scheck's Avatar
Dave Scheck Dave Scheck is offline
Dave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond repute
As Joe said above. You need to use the black USB cable in order to get data since the red one provides only power, not data. We used ours for the first time last night with no issues other than confusion on which cable to use. The instruction manual in the box made mention of the two colored cables and their use.
Unread 11-02-2010, 12:06
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
FRC #0095 (The Grasshoppers)
We've also noticed flaky performance of the Targus USB hub. I think we'll be replacing it with a more reliable one in the near future.
Unread 13-02-2010, 19:09
Wiz Wiz is offline
No need to reply with what was said earlier in a short thread.
We had both of our cables plugged in from day 1, as we read instructions. It worked for a while and then stopped. As others indicated, the light works but no response otherwise.
Unread 15-02-2010, 08:04
AKA: Lars Kamen's Roadie
FRC #0051 (Wings of Fire)
Our USB hub stopped working in the middle of testing yesterday. We've used it without trouble since week 2. After about two hours worth of testing yesterday, we got a "No Stop Button" message on the dash board. I looked at the setup page and noticed that all of the joysticks were also shown as being disconnected. I tried plugging each component into the free USB port on the Classmate and they worked just fine. We never got the hub to work again. It's safe to say that we won't be using that one anymore.
Unread 16-02-2010, 15:31
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
We've recently changed our USB hub and I don't think we've had any more failures since.
Unread 23-02-2010, 14:42
cpeister's Avatar
cpeister cpeister is offline
Mech Eng Student at Waterloo
AKA: Cale Peister
FRC #0781 (Kinetic Knights)
cpeister has much to be proud ofcpeister has much to be proud ofcpeister has much to be proud ofcpeister has much to be proud ofcpeister has much to be proud ofcpeister has much to be proud ofcpeister has much to be proud ofcpeister has much to be proud of
Send a message via MSN to cpeister
Our USB hub stopped working on Sunday. The power light no longer comes on. We purchased a new hub and it works just fine.
Cale Peister - Team 781 Alumni
Mechanical Engineering Student at Waterloo
Attended: WAT'07, WAT'08, GTR'08, WAT'09, GTR'09, WAT'10, GTR'10, WAT'11, GTRE/W'11, BUCKEYE'11, CMP'11, GTRE'12, WAT'12, GTRW'12, WAT'13, WAT'14, WAT '15
Unread 23-02-2010, 14:47
Wiz Wiz is offline
Any suggestions for what to replace it with?? I assume we won't have access to AC power at the driver station thus FIRSTs inclusion of a hub that included a special cable?
Defective Parts? BrandonD-1528 Electrical 0 31-01-2009 11:44
away around the USB chicklet for using USB Controllers Stobei Programming 2 26-01-2008 14:27
Gameport to Usb cable vrs. Usb Chicklet haywirerobotics Control System 4 25-01-2007 19:03
Defective Batteries? hemihead Technical Discussion 17 28-03-2002 22:24
