Go to Post Mentors may not be the direct focus of FIRST, but they are just as involved as students are. They play a pivotal role in the success of FIRST and of the success of every team. - Dan Petrovic [more]
Unread 21-01-2010, 23:10
jhersh jhersh is offline
National Instruments
AKA: Joe Hershberger
FRC #2468 (Appreciate)
Re: Cypress Layout (over wires?)
Originally Posted by Mark McLeod View Post
My mistake is confirmed. The Digital Outputs were reversed.
In the LabVIEW code the I/O counts begin at 0 not 1, so just be aware that Digital Output 1 is referenced in the code by "0". In C++ the reference matches as 1-8.
These labels are how the Driver Station sees them.
The pinout you show is accurate for the compatibility mode. However, if you click "Configure..." on the I/O tab, you can switch to enhanced mode at the bottom and then you can make all 16 digital lines input, or all 16 digital lines outputs or any mixture in between (in addition to a ton of other features).
I'm not sure what LabVIEW code you are referring to. If you mean that the array index is 0 for digital input 1, for instance, then you are correct, but that is simply because the index array primitive in LabVIEW is 0-based. Nothing in the API (compatibility or enhanced) is "0-based".
Cypress board bls0620 Electrical 4 17-01-2010 23:22
Cypress Board Configuration Geek 2.0 FRC Control System 12 17-01-2010 04:23
Cypress IO board connect SteveD FRC Control System 12 16-01-2010 16:46
Cypress soc? sp33chy FRC Control System 2 15-01-2010 08:58
Legal? Hurdling Over Overpass and Over Lane Divider 7-11number1 Rules/Strategy 11 20-01-2008 14:58
