Go to Post My crotchety old person opinion is that it should be illegal to try to win the award. Do things because you like doing them or because it helps others. Don't do things to win awards. - Madison [more]
Unread 21-01-2010, 23:10
jhersh jhersh is offline
National Instruments
AKA: Joe Hershberger
FRC #2468 (Appreciate)
Re: Cypress Layout (over wires?)
Originally Posted by Mark McLeod View Post
My mistake is confirmed. The Digital Outputs were reversed.
In the LabVIEW code the I/O counts begin at 0 not 1, so just be aware that Digital Output 1 is referenced in the code by "0". In C++ the reference matches as 1-8.
These labels are how the Driver Station sees them.
The pinout you show is accurate for the compatibility mode. However, if you click "Configure..." on the I/O tab, you can switch to enhanced mode at the bottom and then you can make all 16 digital lines input, or all 16 digital lines outputs or any mixture in between (in addition to a ton of other features).
I'm not sure what LabVIEW code you are referring to. If you mean that the array index is 0 for digital input 1, for instance, then you are correct, but that is simply because the index array primitive in LabVIEW is 0-based. Nothing in the API (compatibility or enhanced) is "0-based".
Unread 23-01-2010, 09:37
Randy Forgaard's Avatar
Randy Forgaard Randy Forgaard is offline
Parent 1729, former mentor 3126
FRC #7129
Team Role: Parent
Randy Forgaard is a splendid one to beholdRandy Forgaard is a splendid one to beholdRandy Forgaard is a splendid one to beholdRandy Forgaard is a splendid one to beholdRandy Forgaard is a splendid one to beholdRandy Forgaard is a splendid one to beholdRandy Forgaard is a splendid one to behold
The way I read the <R82> rule change in Team Update #4, posted yesterday, it appears that we are no longer required to use the breadboard with the Cypress PSoC 3 FirstTouch Kit I/O module, and we can now use the eStop Cypress Carrier and Enclosure available from AndyMark for more safe and robust mounting and I/O pin access. It would also appear that the Jan. 18 posting by the Game Design Committee on the FIRST Q&A Forum, saying that we can only use the breadboard, is now out of date. Does anyone disagree? (I am hoping to post this question also to the FIRST Q&A Forum through our Team Rules Expert, who has access.)
Please let me know if you read this rule change differently. Many thanks!
Unread 23-01-2010, 12:56
I believe that does obsolete the posting on Q&A.
Unread 23-01-2010, 18:09
AKA: Dr. Brooks
no team (WRRF)
It does appear that they have drawn a line through
"the breadboard," removing it as a requirement,
and refer to "carrier board" now. Clarification via
QandA would be important, but the plain English of
the reworded rules is what it is.
Eugene
Cypress board bls0620 Electrical 4 17-01-2010 23:22
Cypress Board Configuration Geek 2.0 FRC Control System 12 17-01-2010 04:23
Cypress IO board connect SteveD FRC Control System 12 16-01-2010 16:46
Cypress soc? sp33chy FRC Control System 2 15-01-2010 08:58
Legal? Hurdling Over Overpass and Over Lane Divider 7-11number1 Rules/Strategy 11 20-01-2008 14:58
