Go to Post Grease your gearboxes folks! Gears need grease, otherwise they kerplode. - s_forbes [more]
Unread 22-01-2010, 01:39
dtengineering's Avatar
AKA: Jason Brett
Re: CRIO Shock rating
The CRIO is pretty sturdy, but I'm not sure about the shock rating on the Jaguars or Victors. Or the relays or any of that stuff, really.
I'm thinking that if you put about a 1" layer of foam between the control system and chassis that you'll absorb a fair bit of the impact.
It might also help to have a foam layer isolating the battery from the chassis, just to reduce loading on the frame, axles and wheels.
And if you're mounting a compressor, you might want something a bit sturdier than the little rubber standoffs (at least on their own) we've managed to shear them just by hitting a wall at high speed.
Jason
Unread 22-01-2010, 09:11
thefro526's Avatar
Mentor for Hire.
AKA: Dustin Benedict
no team (EWCP, MAR, FRC 708)
I was curious to how well the New Control System would handle the shock load of this year's game as well. I've been contemplating borrowing some equipment we have at my job for drop tests and wiring it up to our chassis once it's running and getting some data on how hard it's actually hitting the ground.
Also, if you're concerned with the amount of shock any part of your machine is taking you could get a few resettable shock indicators and put them on the components in the direction you think it's taking the highest shock. Here's the link http://www.mcmaster.com/#shock-indicators/=5hhdlq - You might have to scroll down the page a bit. These should help you figure out how well you need to protect your components.
-Dustin Benedict
Unread 22-01-2010, 10:51
I know a team that dropped one off a pickup traveling at 55mph.
It was "protected" by a robot, but it didn't survive,...
nor did the robot (RIP)
(3,000th post)
On board shock datalogger? ChuckDickerson General Forum 21 07-01-2008 08:10
Shock absorbers? ZoNeGuY Rules/Strategy 1 16-02-2005 11:19
FIRSTStar(TM) Rating Joe Johnson General Forum 36 03-05-2002 11:39
Rating Threads Tom Fairchild CD Forum Support 1 27-11-2001 12:42
