Go to Post Ultrasonic sensors will allow you to do fundamentally the same thing that the bump sensors do...so you can slow down and smoothly stop your robot just before it reaches the end wall, instead of running into it at full speed and then figuring out "ohh! there is a wall there!" - dlavery [more]
Go Back   Chief Delphi > Technical > Electrical > CAN
Unread 22-01-2010, 01:39
Steven Sigley's Avatar
Steven Sigley Steven Sigley is offline
Electrical Mentor for Team 701
FRC #0701 (RoboVikes)
Team Role: Electrical
Steven Sigley is a name known to allSteven Sigley is a name known to allSteven Sigley is a name known to allSteven Sigley is a name known to allSteven Sigley is a name known to allSteven Sigley is a name known to all
Is it possible to use CAN, a camera, and the wireless without the 2Can adapter?
Is there a way to do that or do you need to use the 2CAN adapter. We're thinking about buying a Black Jaguar but would that take away the port on the cRio for our camera?
2013 Colorado Regional Champions!
2013 Sacramento Regional Champions!
Unread 22-01-2010, 03:31
Peter Johnson Peter Johnson is offline
WPILib Developer
Peter Johnson has much to be proud ofPeter Johnson has much to be proud ofPeter Johnson has much to be proud ofPeter Johnson has much to be proud ofPeter Johnson has much to be proud ofPeter Johnson has much to be proud ofPeter Johnson has much to be proud ofPeter Johnson has much to be proud of
Re: Is it possible to use CAN, a camera, and the wireless without the 2Can adapter?
The black jaguar method of getting CAN bus uses the serial port on the cRIO, not Ethernet port 2 (which is used by the camera). So yes, if you use a black jaguar you can get CAN and camera combined without needing a 2CAN adapter.
Unread 22-01-2010, 07:45
Bryscus's Avatar
Bryscus Bryscus is offline
EE, CpE
AKA: Bryce B.
FRC #0180 (SPAM)
Bryscus has much to be proud ofBryscus has much to be proud ofBryscus has much to be proud ofBryscus has much to be proud ofBryscus has much to be proud ofBryscus has much to be proud ofBryscus has much to be proud ofBryscus has much to be proud ofBryscus has much to be proud of
This is definitely possible. We did it last night!
The opulence of the front office decor varies inversely with the fundamental solvency of the firm.
Unread 22-01-2010, 09:17
Thank you.
Unread 22-01-2010, 16:50
Bryscus's Avatar
EE, CpE
AKA: Bryce B.
FRC #0180 (SPAM)
The CAN code currently only supports the voltage control mode (just like the PWM control), but it should support the closed-loop control functions soon...I hope. I have written some of the methods in C++ for this, but have not test them yet. If you search for woodk, he has posted some code.
- Bryce
Can we use the camera image on Dashboard this year? Jon236 Programming 1 11-01-2010 12:52
Axis camera without the cRIO CrazyCarl461 NI LabVIEW 12 17-01-2009 10:53
Does the camera use the OV6620 or OV7620 imager? Jared Russell Programming 1 15-01-2006 23:03
Can you use the spikes with the globe motors? Caleb Fulton Electrical 1 15-02-2003 20:13
Did you use the 802.11b wireless LAN at EPC@T? soap108 Championship Event 21 04-01-2003 11:03
