Go to Post Desperation is the mother of accomplishment. - Koko Ed [more]
Unread 01-22-2010, 01:47 AM
zombiezen's Avatar
zombiezen zombiezen is offline
AKA: Ross Light
FRC #0973 (Greyhound Robotics)
zombiezen is a jewel in the roughzombiezen is a jewel in the roughzombiezen is a jewel in the roughzombiezen is a jewel in the rough
Re: No Code Error
I ended up figuring out the issue on mine, hopefully this helps others:
My target install machine is running Windows 7. According to a Windows guy I know, Microsoft changed the security API for a few different things going from Vista to 7, especially concerning a feature called UAC. UAC does not allow programs to write directly to the C: drive, so certain programs will not function properly.
One of these programs that fails (silently) is the WindRiver installer.
The solution? Log into an adminstrator account, go to Control Panel -> User Accounts and Family Safety -> User Account. Choose "User Account Control" settings (the infamous UAC). Slide the bar to the bottom, and restart your computer. You have now disabled UAC; you can enable it later (probably after build season).
Now for the fun part. Remove WindRiver entirely (i.e. blow away the C:\WindRiver directory). Pop in the WindRiver install DVD and run the setup program. It should install significantly faster. After that, run the update program on the same disk, then install the latest WPI updates. Once you've done that, everything should work properly.
Hope that helps!
Cheers,
Ross Light
http://www.zombiezen.com/
Code error? niagra127 Programming 12 02-13-2008 08:35 PM
Code Error? darkdwarven Programming 1 02-08-2008 12:42 AM
Error in code light on, trouble finding error Bryan Herbst Programming 16 10-12-2007 09:59 PM
Code error on RC after downloading "bells and whistles" version of Kevins camera code DanDon Programming 6 01-10-2006 06:07 PM
C++ Code Error? Adam Shapiro Programming 9 01-20-2003 01:24 PM
