Go to Post The more you cling to the misfortunes that have already befallen you, the less you'll be able move forward from here. - Kevin Sevcik [more]
Unread 22-01-2010, 07:43
Jimmy Cao Jimmy Cao is offline
AKA: Jimmy Cao
Jimmy Cao has a brilliant futureJimmy Cao has a brilliant futureJimmy Cao has a brilliant futureJimmy Cao has a brilliant futureJimmy Cao has a brilliant futureJimmy Cao has a brilliant futureJimmy Cao has a brilliant futureJimmy Cao has a brilliant futureJimmy Cao has a brilliant futureJimmy Cao has a brilliant futureJimmy Cao has a brilliant future
Re: pic: 2108 Swerve Drive
Looks nice!
Just one little question. What reduction (if any) do you have going from the window motor to the wheel? [Looked at the picture again and it looks like its about 1:1] If its too much of a reduction, your wheel's turning will be so unresponsive that it will be difficult to truly utilize your swerve. On the flipside, if your reduction is too little, that poor little motor won't be enough to do the job.
The reason I mention this is because we used a window to steer last year. The wheels were extremely responsive (1:1 ratio off motor), but the motor did feel the beating, getting hot and eventually tripping the internal heat breaker (who knew it had one of these?). Granted, it was 1 window to steer 2 wheels at once, and it took at least 30 minutes of practice before we encountered this problem, but remember that it was also slick wheel on slick surface. I see that you plan on using a high traction wheel (on carpet).
The design looks extremely robust, although its a little difficult to tell how thick all those plates are. Maybe there's a little excess material? Of course, if weight isn't an issue, then who cares?
Overall very nice design. Out of curiosity, you don't plan on climbing the ramp, do you?
Jimmy Cao
Team 469 2006-2010 Student/Alumni
Team 830 2011-2012 Mentor
pic: Dual Wheel Swerve-Drive =Martin=Taylor= Extra Discussion 5 28-04-2007 01:21
pic: Team 108 - LEGO swerve drive zander_108 Extra Discussion 8 10-04-2007 22:36
pic: My first Lego Swerve Drive Ken Leung Extra Discussion 5 16-08-2006 23:56
pic: Coaxial Swerve drive, lightened. CraigHickman Extra Discussion 19 22-06-2006 15:00
pic: Lego Swerve Drive CD47-Bot Robot Showcase 14 26-06-2003 16:19
