Go to Post Titanium is almost twice as heavy as aluminum. I can have the bragging aspect of making a bullet resistant robot, but if someone is coming into a competition and shooting my robot, I have more important things to worry about! - Andrew Blair [more]
  #46   Spotlight this post!
Unread 21-01-2010, 22:23
CraigHickman
Posts: n/a
Re: Robot Lifting
Originally Posted by gorrilla View Post
Is noone thinking about getting on the platfrom from the bump?
IMO, any reasonable drive system will be able to handle that without issue. We're going to see a lot of systems that cannot, regrettably. It would be best to have the ability to get up no matter what area is open.
  #47   Spotlight this post!
Unread 21-01-2010, 22:39
viper110110 viper110110 is offline
FRC #1325
viper110110 has a spectacular aura aboutviper110110 has a spectacular aura aboutviper110110 has a spectacular aura about
Re: Robot Lifting
we are currently thinking of some sort of arm idea with a winch assist. The arm alone will not be strong enough to pull us up, so the hook/clip we use will have a pulley system and we will winch ourselves up. The arm isfor getting to the pole first.
  #48   Spotlight this post!
Unread 21-01-2010, 22:40
gorrilla's Avatar
gorrilla gorrilla is offline
1557 alumni, 4639 mentor
AKA: adam spears
FRC #4639 (RoboSpartans)
gorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant future
Re: Robot Lifting
Most 4-6 wheels drivetrain with a reasonably low COG should be able to, if they have the ground clearance, or seperate mmechanism to give them a boost...its only a roughly 6" step.
Originally Posted by bobosalad View Post
problem with that is there is a lip from the bump to the tower, and geting centered on the bump isnt going to be easy anyways
A well designed drive-train should have no problems....
Adam Spears
Team 1557 2007-2011 student-Lake County FL
Current Team 4639 mentor- Houston TX
  #49   Spotlight this post!
Unread 21-01-2010, 23:35
Brett Elflord's Avatar
Brett Elflord Brett Elflord is offline
FRC #2471 (Team Mean Machine)
Brett Elflord is an unknown quantity at this point
Re: Robot Lifting
Here's a thought. Instead of trying to lift the bot from the very top bar, try lifting it from one of the side bars. It eliminates the possibility that you will get stuck in the tunnels while trying to lift up in the center. The only problem with this idea is the possibility of going side-to-side but with a world of engineers we can solve that.
Robots are fun!
Oops, robot broke!
Time for duct tape!
  #50   Spotlight this post!
Unread 21-01-2010, 23:44
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
Re: Robot Lifting
EDIT: I'm assuming we were talking about driving onto the platform from the bump. If this wasn't the intent then the following paragraphs will be sound confusing and be embarrassing for the poster.
I think you might be underestimating the difficulty of this task by just a little. Atleast if you're thinking of taking it straight on, straddling the bump. Consider:
If the bump was a 13.5" plateau as wide as your robot, you'd have a 7.5" vertical cliff in front of you to scale. A cliff of Teflon-like UHMW Polyethylene. Climbing it dead on is possible, but you'll need pretty sticky wheels to get enough purchase to get your front wheels up.
Of course, the bump's top isn't as wide as your robot. It's only 12" wide, so unless the inside of your wheelbase is 12", you'll actually start even lower and have an even taller cliff. Specifically, you'll have an inch more to climb for every two inches your wheelbase is over 12. Given that your bumpers start at a max of 11", the widest the inside of your wheelbase can be is 19". So all your reasonable drivetrain designers should keep their wheelbases reasonably narrow and resist the natural urge to make them wide.
So, I think climbing the platform straight on from the side is not something you can pull off with just a thrown together drivetrain. Now, I'll admit I haven't had a chance to look at how a bot could use the 45 of the bump to its advantage to get wheels on the top of the platform. It's possible that the correct approach vector will make the climb pretty easy for a multiwheel, very low CoM robot. Well, relatively easy, at any rate. I think you're pretty much certain to be pivot on 2 wheels for a fair amount of time during the attempt. Which is probably survivable for a multiwheel, low CoM robot. Which, unfortunately, doesn't sound quite like any reasonable drivetrain.
Last edited by Kevin Sevcik : 21-01-2010 at 23:58. Reason: Erm, what squirrel said
  #51   Spotlight this post!
Unread 21-01-2010, 23:48
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Re: Robot Lifting
Kevin, I wonder if Craig is suggesting that a robot should be able to climb up on the bump next to the platform, then hoist itself up from the horizontal bar that goes over the bump edge of the platform. If so, it make sense.
Driving up the bump, then onto the platform, is not something that many robots will be able to do.
  #52   Spotlight this post!
Unread 22-01-2010, 00:20
Jon Stratis's Avatar
Mentor, LRI, MN RPC
FRC #2177 (The Robettes)
Re: Robot Lifting
Originally Posted by amitz View Post
Has anyone managed to lift 120lbs with a 2.5" CIM Motor & 12.76:1 gearbox (TOUGHBOX)?
By my calculations it should be able to do the job. However, in a test I made, it managed to lift only about 55lbs...
Tonight we lifted one of the mentors with a CIM and a (slightly modified) off the shelf boat winch. We used a dewalt transmission, however, with an additional reduction between the sprockets. It was pretty quick, with no issues.
  #53   Spotlight this post!
Unread 22-01-2010, 01:38
CraigHickman
Posts: n/a
Re: Robot Lifting
Erm, yes, this. Apologies if I didn't make it clear, I an see how I mangled that.
Hanging from the floor is a much larger task than hanging from on a bump, but can be made simpler by using the vertical bars. Kudos to any team that can do a solid proof concept of it.
  #54   Spotlight this post!
Unread 22-01-2010, 06:13
amitz amitz is offline
amitz is an unknown quantity at this point
Re: Robot Lifting
What was the ratio of the transmission?
  #55   Spotlight this post!
Unread 22-01-2010, 10:41
BryantWebb BryantWebb is offline
FRC #1810
BryantWebb is an unknown quantity at this point
Re: Robot Lifting
Originally Posted by Tom Line View Post
I believe the difficulty hanging is disproportionate to the returns. Consider that if you didn't hang for those 20 seconds, you could probably get 1 more ball in the goal, rendering the hanging only really worth 1 point. Consider if non of your bots could hang, you could potential score 2 or 3 balls in that 20 seconds. Perhaps matches will be decided by a couple points, but this is NOTHING like 2007 where a single bot with a good ramp system could win 80% of it's seeding matches just by virtue of having those ramps.
The problem with scoring in the last 20 seconds is if your alliance has more than 2 points, you have 1 second to return the ball to play before you suffer a penalty. FIRST really wants teams to attempt to hang or elevate thamselves this year.
  #56   Spotlight this post!
Unread 22-01-2010, 10:44
EricH EricH is online now
Re: Robot Lifting
Wait, what? Where do you get this information?
The 11-second minimum is in constant effect. There is no way to get less than 11 seconds according to the algorithm.
  #57   Spotlight this post!
Unread 22-01-2010, 21:55
TubaMorg TubaMorg is offline
Programmermechanicalelect ricalcoach
AKA: Dan
FRC #1480 (Robatos Locos)
TubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond repute
Re: Robot Lifting
Here is the concept we are implementing to clamp a vertical pole.
Once clamped we will winch the back end of the robot up to the pole.
Initial tests are encouraging, though we will probably have a safety bar that can catch the platform to avoid sliding. Note the same mechanism that winches the robot also engages the clamp, using the robot weight to tighten the grip.
  #58   Spotlight this post!
Unread 22-01-2010, 21:59
Chris is me's Avatar
AKA: Pinecone
Re: Robot Lifting
Can you undo it by hand?
  #59   Spotlight this post!
Unread 22-01-2010, 22:09
AKA: Dan
Re: Robot Lifting
Yes, a simple flip of the winch ratchet releases everything.
Last edited by TubaMorg : 22-01-2010 at 22:50. Reason: I can't read so I answered the wrong question.
  #60   Spotlight this post!
Unread 23-01-2010, 00:53
bobosalad's Avatar
bobosalad bobosalad is offline
FRC #2518 (Spartans of St. Jude)
Team Role: Driver
bobosalad is an unknown quantity at this point
Re: Robot Lifting
hey thanks for the picture, this is a great help of concept. Im just wondering if it can be transferred to a robot.
1070's 2007 Robot Lifting AznPrincess3089 Robot Showcase 8 19-03-2007 19:37
Team 192, Robot Lifting Teaser Joobacca Robot Showcase 7 02-02-2007 17:46
Lifting one vs. lifting two jgannon Rules/Strategy 1 14-01-2007 17:37
robot lifting doomsdaytank Rules/Strategy 2 14-01-2003 16:41
Lifting goals patrickrd Rules/Strategy 6 17-01-2002 17:58
