Go to Post IRI: it's FIRSTmas in July! - Alan Anderson [more]
Unread 21-01-2010, 19:02
rsegrest's Avatar
rsegrest rsegrest is offline
@ least I'm OVER the rock THIS time
FRC #2582 (PantherBots)
rsegrest has a brilliant futurersegrest has a brilliant futurersegrest has a brilliant futurersegrest has a brilliant futurersegrest has a brilliant futurersegrest has a brilliant futurersegrest has a brilliant futurersegrest has a brilliant futurersegrest has a brilliant futurersegrest has a brilliant futurersegrest has a brilliant future
Where is the red X
Ok, so we just downloaded all our LabView updates on the classmate. We logged into the driver account and the dashboard comes up but we cannot find a red X ANYWHERE. We looked under the Setup tab but no luck. We are not connected to the robot or anything wireless would that make a difference?
Impossible is just a big word for small men who find it easier to live in the world they've been given than to explore the power they have to change it. Impossible is not a fact. It's an opinion. Impossible is not a declaration. It's a dare Impossible is potential. Impossible is temporary. Impossible is nothing.
~ Unknown
Unread 21-01-2010, 19:08
Tanner's Avatar
Tanner Tanner is offline
FRC #1261 (Roblions)
Tanner is a splendid one to beholdTanner is a splendid one to beholdTanner is a splendid one to beholdTanner is a splendid one to beholdTanner is a splendid one to beholdTanner is a splendid one to behold
Re: Where is the red X
Red X? What do you mean by that?
-Tanner
Unread 21-01-2010, 19:11
rsegrest's Avatar
Sorry meant the red Exit button on the dashboard under the Setup tab. I looked in the manual and according to the photo there should be a red Exit button located in the bottom right hand corner...we don't have one...a red exit button that is...which means that we are having to Ctrl+Alt+Del to get out of the dashboard which is not recommended as we understand it...
~ Unknown
Unread 21-01-2010, 19:15
Tanner's Avatar
Check to make sure you have the latest DS version. I'm not sure what the latest version, but it should be within a few months or so (but not like September).
http://joule.ni.com/nidu/cds/view/p/lang/en/id/1535
Post the DS Version from the Diagnostics tab if that update is already installed/does work.
-Tanner
Unread 21-01-2010, 21:56
samir13k samir13k is offline
AKA: Samir Shaikh
FRC #4329
samir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant future
Send a message via AIM to samir13k Send a message via MSN to samir13k
you need the ds update, i could not find it at first either...
but i believe the combo of the "Windows button" and "L" should get you to the switch users screen so that you can access your developer account to update your DS.
By "windows button" i mean the little button with the windows flag, not exactly sure what its called
Unread 21-01-2010, 22:25
flameout flameout is offline
AKA Ryan Van Why
FRC #0957 (SWARM)
flameout is a name known to allflameout is a name known to allflameout is a name known to allflameout is a name known to allflameout is a name known to allflameout is a name known to all
You need to do the driver station update (do the LabView one first, it prevents a problem with nicyapi.dll.)
Using Windows Key + L should do a switch user operation.
I hope this helps.
Unread 21-01-2010, 23:02
rsegrest's Avatar
Thanks guys!! I really appreciate the quick responses. We are in the process of loading the updates now and I'll let you know what happens tomorrow.
~ Unknown
Unread 22-01-2010, 13:17
byteit101's Avatar
WPILib maintainer (WPI)
AKA: Patrick Plenefisch
Windows key or Win key on windows, Super on linux
Watchdog.Kill();
Unread 22-01-2010, 14:24
longrange longrange is offline
FRC #1070 (Royal Robotrons)
longrange is an unknown quantity at this point
Using windows L will allow you to log in to Developer but will not log you out of Drivers Station. Our Classsmate runs REALLLLLLLY slow if we do not log out of Drivers Station. Using the red exit button under setup seems to be faster than windows L and logging off, but maybe it's just an illusion.
Unread 22-01-2010, 14:34
Another way to run both is to stay logged into only the developer account, and launch the driver station from the Start menu. Don't do this for an official field, but for development on a single computer, this is the recommended method. If using two computers, it may be preferable to have one be developer and one driver.
Greg McKaskle
Unread 24-01-2010, 23:32
Wiz Wiz is offline
Wiz is infamous around these partsWiz is infamous around these parts
There are very specific directions for how to setup and run the Classmate, including Name and updates.
It would probably be wise (and save some time) to follow the directions.
Unread 24-01-2010, 23:39
Gary.C Gary.C is offline
OUTWORK US
FRC #1323 (MadTown Robotics)
Gary.C has a reputation beyond reputeGary.C has a reputation beyond reputeGary.C has a reputation beyond reputeGary.C has a reputation beyond reputeGary.C has a reputation beyond reputeGary.C has a reputation beyond reputeGary.C has a reputation beyond reputeGary.C has a reputation beyond reputeGary.C has a reputation beyond reputeGary.C has a reputation beyond reputeGary.C has a reputation beyond repute
Send a message via AIM to Gary.C
Or you can hold the Shift key while the classmate boots up and then it will take it to the login screen where you can choose the developer login.
Gary Chahal
Webmaster & Sales Representative, WestCoast Products || Twitter
MadTown Robotics Team 1323
Unread 25-01-2010, 01:01
Wiz Wiz is offline
Yes that works, regardless, but there is a mandatory update referenced in the manual, as well as two other updates referenced in the 2010 Controller web page:
http://www.usfirst.org/roboticsprogr....aspx?id=10934
The Red Alliance? whlspacedude Rumor Mill 47 18-09-2009 01:04
Who is ready for the Red Herring? yodameister Rumor Mill 19 13-12-2008 13:13
pic: Bottom view of The Red Dragon redbarron Extra Discussion 27 02-02-2007 10:20
Running the robot using Infa Red? Burg Robotics Education and Curriculum 7 30-12-2004 12:31
pic: Lovin' the Red Wings CD47-Bot Chit-Chat 8 28-10-2003 01:48
